03-21-2012, 09:27 PM | #41 |
Quarry Creeper Join Date: Feb 2011 Location: Wood
| Re: My dlux hall style berg rebuild
Man that thing is nice.good job with webs, paint looks good.sooo your car has multiple functions,were can I get some of that action.
03-22-2012, 05:37 PM | #42 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
| Re: My dlux hall style berg rebuild |
03-22-2012, 06:24 PM | #43 |
Rock Crawler Join Date: Sep 2009 Location: The BYB Compound
03-22-2012, 10:08 PM | #44 |
Did those small TI links not work out on the front?
03-23-2012, 12:35 AM | #45 |
03-24-2012, 01:09 PM | #46 |
So after driving the car for a few days it seems to be performing off the charts. I do think though i need to change the length of my upper links again as well as the springs iv been running. I noticed the rollover ability on this chassis is way better than on the old one. I may also try taking a min amount of weight out of the knuckle weights to see how it works since im about a ounce and a half lighter than i was before. Ill get some pics up of the new links later. Need to start on this so the car will be done for tomorrows comp.
03-26-2012, 11:38 PM | #47 |
The Hall Style chassis took all three podium finishes yesterday at the event. My DLUX Hall Style worked rather well in the wet weather. On another note here is a pic of some new 18g wire i put on running through my upper link wire holder things. the 18g wire was about 6g lighter over the 16g i had on there. |
03-26-2012, 11:41 PM | #48 |
needed to make some new longer links so i decided to use some 3/16 hollow tubing that i turned down and ran a 4mil die on for threads. I decided to do this so i didnt have to run a grub screw in the rod end. these are for the rear still need to do fronts.
03-27-2012, 06:09 PM | #49 |
Wow, that is cool! I can see them on the scale but i can't see the numbers! |
03-28-2012, 07:52 AM | #50 |
03-28-2012, 11:41 AM | #51 |
LOL. Do you know how much lighter that tube was over solid? Looks like it could be a great way to have a pilot hole drilled and drill it out some more. |
03-28-2012, 06:52 PM | #52 |
| Re: My dlux hall style berg rebuild Looks like 3/16 solid rod weighed 11g for bother and the hollow 3/16 that I used weighed 7g for both. This is without rod ends.
04-02-2012, 09:27 PM | #53 |
Rock Crawler Join Date: Jan 2006 Location: Vacaville, CA
I have to admit, This thing is pretty bad ass... liking the new design over the old.
04-03-2012, 08:43 AM | #54 |
04-03-2012, 08:47 AM | #55 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
04-06-2012, 10:06 PM | #56 |
One day... My daughter is 8 months old now and a handful.
04-27-2012, 10:19 PM | #57 |
Got some new carbon faces for my wheels from DLUX. They are a great addition to the rig. Not only do the look cool but they weigh less than my solid faces by 12g. Thanks Erik for another great part. These arnt the best pics maybe someone will take better ones this weekend at the comp.
04-27-2012, 10:40 PM | #58 |
Looks good! You will need to figure out how to get some spare motor cans so I can turn those down for you. I can feel a pretty big difference from the weight loss, especially where you're losing the weight. |
04-28-2012, 04:24 PM | #59 |
| Re: My dlux hall style berg rebuild Thanks Erik. I'll see what I can do in the motor can dept. Thanks again for the DLUX parts and the excellent customer service.
04-30-2012, 11:59 PM | #60 |
Just changed out my standard nylocks for some low profile aluminum nuts.. These 12 nuts saved me 5g.
Tags |
bybrcc, dlux, hallstyle, rc country, vanquish |
My dlux hall style berg rebuild - Similar Threads | ||||
DLUX Berg axle parts | Erik D_lux | Axles, Trannys, T-case | 144 | 11-18-2019 10:50 AM |
Dlux Berg Build | Erik D_lux | EnRoute Berg | 1696 | 05-22-2018 10:10 PM |
~53 willys DLux Style Super Berg~ | 53 willys | Superclass Crawlers | 112 | 01-27-2012 01:05 PM |
My DLUX Hall Style Berg | CrAwLeR13 | EnRoute Berg | 27 | 08-03-2011 10:56 PM |
