04-14-2013, 07:36 PM | #281 | |
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg Quote:
I only run one-two 450mah packs on this rig now before a comp. Before this past Friday, I hadn't drove it in a month. It just works. Yeah, we decided if we do it again, the gates will be a little tougher, less time and not make it a normal course but a "bonus" course. It was fun trying to see how many gates I could get through in 4 minutes. | |
04-17-2013, 09:06 AM | #282 | |
Arcc comp #5 gulpha gorge Last edited by Szczerba; 04-17-2013 at 09:10 AM. | |
04-21-2013, 09:44 AM | #283 |
Something is missing from this picture. What ever shall I VooDoo? |
04-21-2013, 07:14 PM | #284 |
Which compound are you going to run?
04-21-2013, 07:22 PM | #285 |
| Golds= Ultra Soft Silvers= Extra Soft Blues= Soft www.ottsix.com I ordered the Ultra Softs (Golds) and the Softs (Blues). They will be mounted up on both sets of my DLux beadlocks. Should have them mounted up tomorrow afternoon for some testing. They will both be ran on my 2.2s and 2.2 Pro at ECC. Last edited by Szczerba; 04-21-2013 at 07:26 PM. |
04-22-2013, 06:14 PM | #286 |
Golds mounted up on DLux CF 0.78" wheels and 5.25" Crawler Innovations Foams. 79grams for a tire! Next to a narrowed and shaved Khaos-Rover at 90 grams for tire only. Khaos Rovers mounted up. Gold VooDoos mounted up Standby for more info. Rig is 4lbs 2oz now. Last edited by Szczerba; 04-22-2013 at 06:17 PM. |
04-22-2013, 06:19 PM | #287 |
Nice Shane! Mine will arrive at the house WHILE I am at ECC... Something to look forward to returning too!
04-22-2013, 06:29 PM | #288 | |
Tire still performs good on the sidehills though. Last edited by Szczerba; 04-22-2013 at 06:33 PM. | |
04-22-2013, 06:32 PM | #289 |
They look way tall for 5.25" foams.
04-22-2013, 06:33 PM | #290 |
04-22-2013, 06:36 PM | #291 |
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg |
04-22-2013, 08:00 PM | #292 |
Swapped out the 5.25" DD's with some Single Stage 5.75" foams. Gold compound is all I tuned with tonight. I do like this combo better! I ran the soft single stages up front and the medium single stages out back for a battery back. My rig is 4lbs 2 oz the front end folded over too much on sidehills but grabbed ledges like no other. So I put some medium single stages up front and got my sidehilling back with just enough forward bit to still work. I have ran the closed cell inner foams since I got one of the first prototype sets from Eddie in 2010. I did not notice any ill effects of the oversized single stage foams just yet. ignore the camera angle in the last picture. Last edited by Szczerba; 04-22-2013 at 08:05 PM. |
04-22-2013, 08:04 PM | #293 |
Couple notes from 5 battery packs of testing. 1. The VooDoo's are a taller tire. So you will have to adjust your driving style and shock external and internal limiters. At least I did. 2. The Gold compound is really nice and soft but still holds its shape. Too short and soft of a foam will cause tire wading which effects contact patch. 3. Get your foam tuning hat on. These tires are going to work with several foam setups you'll just have to find the one that suits you and your rig. 4. These tires are lighter so you may need to move some weight around on your truck. 5. Thanks to Ottsix for the new tire. |
04-22-2013, 08:40 PM | #294 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
What's the tire height hold the weight of the truck up. Looks more then 5.5"
04-22-2013, 08:49 PM | #295 |
04-22-2013, 09:10 PM | #296 |
How come you went from a 5.25 straight to a single stage? I guess what I am really wondering is, why didnt you naturally want to step up to a 5.5 inner and then from there if it was too soft, step up to a 5.5/medium outer?
04-22-2013, 09:25 PM | #297 | |
Just crossed my mind that I was getting too much tire wrap and I figured I needed to fill the tire more. The 5.75" single stages caught my eye on my foam shelf. The 5.5's may work but I am thinking this bigger single stage may be the setup to keep that wrap down. I'll try the 5.5's in the future. I still have the Blue VooDoo's to mess with too. They are the firmest of the VooDoo line. | |
04-22-2013, 09:27 PM | #298 |
Really looking forward to your expert pin tuning advice I messed around with my cut pins tonight on some chunky granite...much MUCH better than uncut pins. My rig is around 3.5lbs and I haven't really had any bunching as long as I use tuning rings. Even without tuning, not too bad...but I've mostly been on smoooooth granite and sandstone. I did catch a few edges where I thought I ripped the front end off my rig. Three basic things that made big improvements for me were: - a good break in - going back to 1" wheels (better side hilling) - pin pattern ...and two weeks later, I'm STILL playing around with foams The one thing I have noticed about this rubber is that it's slightly more temperature dependent then "S" type compounds. The factory is working on that category of compound for us... Last edited by crawl-o-matic; 04-22-2013 at 09:31 PM. |
04-22-2013, 09:31 PM | #299 | |
04-22-2013, 09:38 PM | #300 | ||
Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg - Similar Threads | ||||
Rowdys XR, BJV4, SA, Now Team Y-Town "Double Agent" | ROWDY RACING | Axial XR10 | 888 | 06-14-2014 07:50 PM |
Szczerba's 2012 Secret Agent'd 4.0 Berg | Szczerba | EnRoute Berg | 139 | 07-06-2012 02:31 PM |
Featherweight Secret Agent 3.5 Bodiless Build | 4xFord | Axial XR10 | 241 | 06-20-2012 05:43 AM |
Y-town Secret Agent 3.5 Bodiless XR10 | klabeaume | Axial XR10 | 38 | 04-10-2012 08:27 PM |
