04-01-2012, 06:28 PM | #21 | |
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Berg Thanks, Thommy. Quote:
Yea, the 4.0 was working good. Then Y-Town had to go and make a better chassis. Got about 6-7 packs in the rig today. Still crawling good. I was running 40wt up front and 55wt out back. During the heat of the day the oil got thinner. Might have to bump up some wt. I like a little thinner oil for those rock racing times. Truck will grab on sidehills and the servo does alot more work on moving the rear around. I have always been a slow crawler due to the pin tires I run. The light weight setup likes slow speeds, "bumps" on some verticals and turning the rear motor mix up and down a little more. Got some videos uploading now. Might take a while. Last edited by Szczerba; 04-01-2012 at 09:01 PM. | |
04-01-2012, 06:34 PM | #22 |
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Berg Why yes. You like carbon fiber? Had some scraps left over from the FF-SZ and made two rear wheel faces. So I figured I would cut some up. reduced the weight by ~0.2 oz overall. or ~12 grams. Doing so moved the balance point forward 1/32" Probably could drill out some more weight but it's good for today. Last edited by Szczerba; 04-01-2012 at 06:37 PM. |
04-01-2012, 06:38 PM | #23 |
Is that 5 lbs 3 oz, or is it really 5.03 lbs? If it's 5.03, you are only 1 gram away from a 4 lb rig.
04-01-2012, 06:50 PM | #24 |
Those big ol tires just look wrong on there You know you could drop a at least 2 more ounces by running shaved claws. just sayin .. Waiting for the video.... waiting waiting BTW... its looking great Shane. |
04-01-2012, 06:51 PM | #25 |
Pebble Pounder Join Date: Feb 2008 Location: 801rcc
What springs you running?
04-01-2012, 07:59 PM | #26 |
Faces looked like they turned out pretty good! Everytime I cut CF I think of all the hardcore guys cutting things out of CF by hand or with a dremel. I cannot imagine hand cutting this stuff. I think the dust alone would kill me! Thanks for posting up total weights with the tires. I knew they weighed more but I thought I read that they were much more than what you have so I have never even given them a chance. |
04-01-2012, 08:10 PM | #27 | |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Berg Quote:
He is right, I just dropped 3.1 oz with the my new shaved boss claws I put on my old dinosaur bjv4. Last edited by Tgreer; 04-01-2012 at 08:14 PM. | |
04-01-2012, 08:10 PM | #28 | |||
It's 5.03 lbs And thanks for the comm cuts last weekend. The Holmes Hobbies 2012 Team TorqueMaster Pro's are zipping like crazy! Quote:
Switching to the DLux wheels (1/2" Spacers, ~0.9" wheel width) it did tall them up a touch. Having GoPro video conversion issues. Losi MRC silvers on all 4 corners. SCX pre-load adjusters cranked all the way down. Quote:
I cut outside, use rubber gloves, long sleeve shirt, safety glasses and painters mask. A metal cutting disk on the dremel makes quick work of carbon fiber. And a hard sanding bit to clean everything up. Been crawling with the Khaos-Rovers since Oct 2010 Last edited by Szczerba; 04-01-2012 at 09:03 PM. | |||
04-01-2012, 09:26 PM | #29 |
Nothing fancy. Just a fun little line. GoPro mounted on the 4pks |
04-02-2012, 05:50 AM | #30 |
Couple more of some light practice. This rock is pretty darn slick and had a light covering of pollen. Last edited by Szczerba; 04-02-2012 at 08:08 AM. |
04-02-2012, 08:09 AM | #31 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
Lookin GOOOOOD Shane!! Those 3.5 Bodiless rigs sure do sidehill!!! |
04-02-2012, 09:06 AM | #32 | |
The video doesn't show good but some of the sidehills are pretty steep. Knock the rear down to 95% or 90% and it sidehills for days. I am amazed when sidehilling, I can dig, and it will pull up the face, if some traction is available. I really like that about the lighter setup. It would push off the side and fall down with previous setups. The 4.0 chassis sidehilled well too. With other chassis I ran, previous to the YTC 3.5 and YTC 4.0, I was nervous on sidehills but that could have been my setup. Just seemed they would unload and loose traction and then go tumbling. Also, I was worried about my foam setup but I am running the same foams as before with the 5.4lb setup. Crawler Innovations Closed cell 5.5" inners all around with softs outers up front and medium outers out back. No tuning rings. Sanding the sidewalls on the khaos helped that out. Still very little bounce. that is what the "rock racing video " is for. To kinda show that. ... Last edited by Szczerba; 04-02-2012 at 09:14 AM. | |
04-02-2012, 09:09 AM | #33 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
yes,the sidehills are impressive... |
04-02-2012, 09:57 PM | #34 |
RCC Addict Join Date: Jul 2009 Location: Shreveport, LA
That looks like some pre running. The new set up is looking good! Can't wait to get up there to comp with you guys!
04-03-2012, 07:10 AM | #35 |
heres some pics of shanes rig i took.. |
04-03-2012, 07:56 AM | #36 |
Nice pics! Shane...I'm surprised you haven't worked on your transmission cases yet...I don't mean removing the screw hole at the front...I'm definitely a fan of leaving those front and rear, but you can still shave them and the rest of the cases down... |
04-03-2012, 08:10 AM | #37 |
video : up3 GATE! |
04-03-2012, 08:45 AM | #38 | |
Might tear them apart this weekend and grind on them a little bit. yea but you still think a bonus gate is worth 2 points. (Hint, it's 8 more points than that in 2012) On a separate note, since I flipped the skid around, like I did on the Secret Agent 4.0 with the body, the chassis is very close 3.75" tall or just over. It was meant to be turned the other way to meet the 3.75" spec but I didnt really think about it until some pm'd me about the berg setup and he mentioned the spec when the skid was flipped. Thanks Erin! It's my fault, the skid was meant to be run the other way. but looking at my picture the top piece I used for measurement is not level. I'll need to recheck later day. ... Last edited by Szczerba; 04-03-2012 at 09:13 AM. | |
04-03-2012, 08:53 AM | #39 | |
I pretty much just ran lines that we have setup before. Just to see how the new setup handled. Then Josh and I made 3 more courses just to get some practice in. The pollen definitley added a slip factor to the already slick rock. Maybe it will rain a couple days before the comp and wash it way. | |
04-03-2012, 09:09 AM | #40 |
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Berg |
Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg - Similar Threads | ||||
Rowdys XR, BJV4, SA, Now Team Y-Town "Double Agent" | ROWDY RACING | Axial XR10 | 888 | 06-14-2014 07:50 PM |
Szczerba's 2012 Secret Agent'd 4.0 Berg | Szczerba | EnRoute Berg | 139 | 07-06-2012 02:31 PM |
Featherweight Secret Agent 3.5 Bodiless Build | 4xFord | Axial XR10 | 241 | 06-20-2012 05:43 AM |
Y-town Secret Agent 3.5 Bodiless XR10 | klabeaume | Axial XR10 | 38 | 04-10-2012 08:27 PM |
