04-17-2012, 08:08 PM | #101 | |
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg Quote: Oh yeah, nice driving to the man in the big yellow hat.... | |
04-17-2012, 08:08 PM | #102 |
RCC Addict Join Date: May 2006 Location: enid
Shoot.....you guys outta see me drive one of Shane's rigs....lol
04-20-2012, 11:20 AM | #103 |
Quarry Creeper Join Date: Sep 2010 Location: In the pre-game lobby
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Berg
Good stuff! Those shocks look more like xr10 units than scx. I run the same on my berg.
04-20-2012, 11:45 AM | #104 | ||
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Berg Quote:
You know the saying, you trim the bushes and the sidewalk gets bigger. Quote:
Probably cause the preload spacers wrenched all the way down? I am running the aluminum bodies as well. The SCX's work great for me. | ||
05-13-2012, 08:10 AM | #105 |
Just saw a few more ECC videos of mine post up, so here are a few of the courses. Thanks to RolandRockShop for the video. And my spotters! Truck worked good but my decisions could improve. Wasn't really feeling it the first 2 courses. In some sort of funk. I dunno. Anywho, ended up 31st for the day. Going to make some foam adjustments and I have a set of Boss Claws in my possession now. 2012 ECC 2.2 PRO COURSE 2 SZCZERBA - YouTube 2012 ECC 2.2 PRO COURSE 5 SZCZERBA - YouTube http://www.youtube.com/watch?v=pUZjLmTeOHc Edit. Attached the wrong link in one. ... Last edited by Szczerba; 05-13-2012 at 02:30 PM. |
05-13-2012, 04:29 PM | #106 |
Swapped out to aluminum hardware on the chassis where I could and on the axles. Pulled the Medium outer tuning rings out of the rear tires. Was 4lbs 14.8oz Now 4lbs 13.4oz Did some tire weighing too. Rovers sidewalls shaved and siped = 2.9oz Boss Claws untouched = 3.6oz Khaos Rovers, Internally sanded, sidewalls sanded, no lugs cut = 4.2oz Last edited by Szczerba; 05-13-2012 at 04:33 PM. |
05-13-2012, 04:38 PM | #107 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
Just watched one of your vids. What was wrong with your antenna on your TX? Good driving BTW |
05-13-2012, 04:43 PM | #108 | |
Ha. The plastic elbow joint broke last year so I put a paper clip piece to act as the pivot point. Hit it again just before ECC and it broke all the way. Just too lazy to buy a new flex joint or fix it. Thanks. The truck works great. I just need to keep working at tuning it for me and picking better lines. I am going to try some 5.25" foams in the khaos this week hopefully. Going to see how the truck reacts versus the 5.5" setup. And I will try to get some Boss Claws tested as well. I have swapped to Zero Ackerman knuckles since ECC. | |
05-13-2012, 06:43 PM | #109 |
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg |
05-13-2012, 07:19 PM | #110 |
...and 8* will come back next I'm curious what you find with the different foam setup and then when you switch to the Boss Claws. I won't be switching back to them, but I'm interested to see what you have to say about them after running the Khaos tires for so long. Tire weights...my current front tires are Khaos Rovers that have been narrowed and sanded internally only along with a pattern cut. They weigh in at 90g or 3.17oz... I built a set of narrowed Block-Rovers for a customer before ECC and with moderate internal sanding and NO pattern cut they came out to 95g or 3.35oz Last edited by ittybitty; 05-13-2012 at 07:24 PM. |
05-13-2012, 07:42 PM | #111 | |
05-13-2012, 08:50 PM | #112 | ||
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg I've had the zero ackerman knuckles for a while. Just didnt have a steering link for them. Ashton made me one out of 1/4" hex right quick when we got back to his house from ECC. Just wanted to see how the zero ackerman was without the 8* again. Jury is still out on if I still like it versus the ackerman knuckles. I was used to the outer tire turning harder, good and bad traits.. Now they both turn the same. Good and bad traits. Quote:
Good to know on the weights. I like the look of the narrowed Khaos but just too lazy to cut mine apart. And I'm just waiting on my foam guy to send me the 5.25" setups. Quote:
The Khaos do act up sometimes due to the firmer sidwalls with the joint. I have just learned to deal with it . I am really looking forward to trying the 5.25" foam setup in them. | ||
05-14-2012, 08:34 AM | #113 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
I think you will like the boss claws. I made the switch after running the khaos up front and block in rear, and they just seem to work better. More predictable and seem to have a little better bite. I think I will still us my 5.5 setup for spots that have riprap or gaps for floating over better. |
05-14-2012, 08:52 AM | #114 |
Quarry Creeper Join Date: Jun 2010 Location: Road Trippin
05-14-2012, 12:26 PM | #115 | ||
Front - Closed cell inners with soft outers Rear - Closed cell inners with medium outers Just remember, my tires are super worn from almost 2 years of comps. I was running a medium tuning ring out back but pulled it out yesterday. That setup worked good at ECC. The rears were a little firm with the tuning rings but I left them in there for the height. Also, I usually switch to memory foam outer in the warmer months. Might give those a test before the comp this weekend. It's still 50's in the morning and mid 80s in the afternoon. Might have to wait another month for my liking with memory outers. Shipping out the new Khaos tires I made to Ryan at EastCoast R/C to narrow them up for me. Going to give those a try too. Last edited by Szczerba; 05-14-2012 at 01:08 PM. | ||
05-15-2012, 08:34 PM | #116 |
Drove the truck yesterday and spent last night and tonight trying to tune what removing 1.2oz of weight did. For some reason the rear of the truck was really loose and flippy now. Waving the crowd. So I started firming up the rear springs. No luck switching from MRC silvers to blacks. So I jumped the shock oil up to 70wt out back. Still flippy and acting weird overall. So, I stood the rear shocks up one hole. No luck. Then I switched the front springs from MRC silvers to MRC blacks. Helped tone down the weirdness a bit. Had to phone a friend. Then I saw the RC4WD dual rate spring separators on my work bench. They fit snug against the bottom of the SCX shock and don't go further than pictured. Added a orange mini-t spring and voila! Truck is settled and acting right. So after two nights of scratching my head. Black MRC's up front and Orange Mini T's out back. 40wt up front and 70wt out back. Rear oil will get changed to 55wt tomorrow. That Iswhat I was running before. ... Last edited by Szczerba; 05-15-2012 at 09:15 PM. |
05-15-2012, 09:26 PM | #117 |
That seems odd. Those are the firmest short MiniT's. Whenever I have trouble with that rear waving to the crowd issue, I up the preload on the spring instead of increasing the spring rate. Mine had the issue when switching between the Blitz wheels and heavier wheels. I just made a preload collar out of the same thing you are using (the spring seperator) and trimmed off the lip for looks. Last edited by Harvo; 05-15-2012 at 09:32 PM. |
05-16-2012, 05:28 AM | #118 | |
I think the lighter the truck gets, running these heavier Khaos, the more leverage the tires have hanging out there on the ends of the axle. My SCX preload was all the way down. Didn't have many options for more preload until I saw the RC4WD spring guides. I knew the rear springs needed to be firmed up cause the front end lift. and the fronts could use firmer springs as well do to the rear doing some odd things. Kinda odd that removing ~1.5oz of chassis weight (screws) would do all this. I am about to reduce the weight by swapping tires. As well as changing the battery location. Stay tuned .... Last edited by Szczerba; 05-16-2012 at 05:35 AM. | |
05-16-2012, 09:13 PM | #119 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
I noticed a lot more stability in my 4.0 when I dropped from 6lbs to 5lbs even with no changes in spring rates. It felt like a "stiffer" spring made for a more stable car in every situation. Have you ran any lines similar to that off camber gate at ECC to compare the rear settling?
05-16-2012, 09:23 PM | #120 | |
Been practicing getting the front tires and rear tires in holes, sidehill-off-camber. Much better now. Got in some Boss Claws. Lightly sanded sidelugs and pins to knock the new off and cut skipped 2 rows cut one (stole the cut pattern from Almighty Malach). Set them up with some Crawler Innovations 5.25T Double Deuce Inner Foam Pair (2) Softs up front and medium out back. Erik D-Lux Carbon Fiber wheels @ .~0.78" wide DLUX 2.2 AND 1.9 wheels The just taller than my khaos right now. Khaos have 5.5" foams and boss claws have the 5.25". But BC's and 5.25" are new. Probably not a good comparison since the BC and foams are new and the Khaos tires and foam setup are ultra worn. Ran a pack on the BC's and they lack the forward bite compared to the Khaos. I know they are new. I did lightly sand the pins down a bit. The BC's do work awesome on my shafty right now. Going to stay on that truck for now. Berg was 4lbs 10zs with BC's. Last edited by Szczerba; 05-16-2012 at 09:26 PM. | |
Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg - Similar Threads | ||||
Rowdys XR, BJV4, SA, Now Team Y-Town "Double Agent" | ROWDY RACING | Axial XR10 | 888 | 06-14-2014 07:50 PM |
Szczerba's 2012 Secret Agent'd 4.0 Berg | Szczerba | EnRoute Berg | 139 | 07-06-2012 02:31 PM |
Featherweight Secret Agent 3.5 Bodiless Build | 4xFord | Axial XR10 | 241 | 06-20-2012 05:43 AM |
Y-town Secret Agent 3.5 Bodiless XR10 | klabeaume | Axial XR10 | 38 | 04-10-2012 08:27 PM |
