06-01-2012, 12:33 PM | #141 |
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg They got here in good shape. You did a great job at narrowing these up for me Couple pictures. Ran a couple packs through them and really like the narrowed Khaos. The main thing I like is the reduced weight and the new lugs 5oz shaved inside and sidewalls with pins trimmed, DLux Carbon fiber wheels with 600 hubs. Crawler Innovations Closed Cell Inners all around with soft outers up front and medium outers out back. Truck is now 4lbs 9oz with the new tire setup and 2oz knuckle weights on each side. Also, working on a new knuckle weight holder. If you wanna space the dlux knuckle weights out, just turn the knuckle weight around (Last Picture) and drill and tap them to the knuckle. Depending on hub size, you'll have to trim the inside a bit. Started on a VP Zero Ackerman mount for brass. Last edited by Szczerba; 06-01-2012 at 06:45 PM. |
06-01-2012, 01:08 PM | #142 |
That tierod is pimp-tastic.
06-01-2012, 01:11 PM | #143 |
Wow. 6 ounces all at once is pretty significant. Is 4lb 6oz with or without the battery? Nice job Shane!
06-01-2012, 01:41 PM | #144 | |
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg Not bad for me yelling at you while you were making it, "hurry up, I still have to drive 5 hours" . Quote:
I dropped off 1.6oz of knuckle weight the other night when I was messing with link geometry. With the narrowed Khaos, I dropped about 3-4 oz of total tire weight. Crazy! I was at 4lbs 11.5oz before the tire swap. But yea, 4lbs 9oz now. I'll have to double check back in the thread for the normal khaos weight. Yep, normal khaos with CF wheels was about ~5.9oz each. Now 5.0oz. Narrowed tires by themselves were 97 grams each. Last edited by Szczerba; 06-01-2012 at 06:44 PM. | |
06-01-2012, 01:51 PM | #145 |
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg |
06-01-2012, 05:04 PM | #146 |
06-01-2012, 06:44 PM | #147 |
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg If you mean free part and labor for me, then yes! More Tequila you mean. I mis-quoted my last RTR weight. With 2oz knuckle weights and the narrowed Khaos, it's 4lbs 9 oz. |
06-01-2012, 08:33 PM | #148 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
Hows the rig feel at 4.9? Ive gotten mine to about 4 11 and it seems to do better and better the lighter i get. Thats running 4.3oz per side on mine in knuckle weight. I think i will drop about 1.5 per side and see if its still on par! Keep up the great work on your berg, i hope i give you a run for your money at state!!! |
06-02-2012, 08:34 AM | #149 |
06-02-2012, 10:12 AM | #150 |
RCC Addict Join Date: Oct 2009 Location: Council Bluffs
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg You know they look factory man. Thats awesome work there. Rig is looking really good man. Hopwfully I can compete with you guys soon, either at Nationals or Crawlapalooza
06-02-2012, 10:52 AM | #151 | |||
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg Quote:
I plan on attending both comps | |||
06-02-2012, 09:02 PM | #152 |
Whatcha think of the "additional" sanding?
06-02-2012, 09:48 PM | #153 |
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg You sanded them on the inside after your glued them back together? I looked on inside and thought you might have. I really like these tires narrowed up. Szczerba Innovation's Homemade knuckle weights. 2.0oz total weight for one side. Might need to hit these with some black spray paint Ol' school Brass paper weight egg cut up, drill press and drill. Moved out as far as possible. Added 3 of my old knuckle weight washers to the inside. Finish up the other side tomorrow. |
06-02-2012, 09:55 PM | #154 |
Yeah...take another look inside when you get a chance...there's something missing from the sidewalls |
06-03-2012, 06:08 PM | #155 | |
Finished up the other side knuckle weights. Got in a little practice time in with the new 2.0 oz each weights. All the knuckle weight up front and all the way outside = 4lbs 8oz RTR right now. Couple guys have asked about links with the berg axles. These are what I am running. Made them for the Y-Town 4.0 and they were a direct swap for the Y-Town Secret Agent 3.5 Also, in POST #2 of this thread. Front Uppers: Straight Links- 75mm (unthreaded distance) http://www.lunsfordracing.com/mm5/me...y_Code=GRINDER Bent eye to eye: 109mm (Revo-Revo) Front Lowers: Straight Links- 75mm (unthreaded distance) http://www.lunsfordracing.com/mm5/me...y_Code=GRINDER Bent eye to eye: 115mm (Jato-Revo) Rear Uppers: Straight Links- 105mm (unthreaded distance) http://www.lunsfordracing.com/mm5/me...y_Code=GRINDER Bent eye to eye: 144mm (Jato-Revo) Rear Lowers: Straight Links- 115mm (unthreaded distance) http://www.lunsfordracing.com/mm5/me...y_Code=GRINDER Bent eye to eye: 140mm (Revo-Revo) Last edited by Szczerba; 06-03-2012 at 06:10 PM. | |
06-03-2012, 08:12 PM | #156 | |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
Nice tires, when are you guys gonna start going for patterns that don't bounce so much? | |
06-03-2012, 08:21 PM | #157 | |
I was going to to stagger the leave rows but didn't. Where do I need to glue some pins back on at? Or cut out. | |
06-03-2012, 08:44 PM | #158 |
Let's try a set of slicks next...maybe in pink compound? |
06-03-2012, 08:47 PM | #159 |
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg These are working awesome on my sportsman |
06-03-2012, 09:49 PM | #160 |
Rock Crawler Join Date: Jul 2008 Location: grand rapids, bay area, nyc.
| Re: Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg Interesting. What kinds of patterns? |
Szczerba's 2012.2 Secret Agent'd 3.5 Bodiless Berg - Similar Threads | ||||
Rowdys XR, BJV4, SA, Now Team Y-Town "Double Agent" | ROWDY RACING | Axial XR10 | 888 | 06-14-2014 07:50 PM |
Szczerba's 2012 Secret Agent'd 4.0 Berg | Szczerba | EnRoute Berg | 139 | 07-06-2012 02:31 PM |
Featherweight Secret Agent 3.5 Bodiless Build | 4xFord | Axial XR10 | 241 | 06-20-2012 05:43 AM |
Y-town Secret Agent 3.5 Bodiless XR10 | klabeaume | Axial XR10 | 38 | 04-10-2012 08:27 PM |
