07-20-2013, 04:47 AM | #81 |
Rock Crawler Join Date: May 2012 Location: Australia
| Re: Bergsta
That's dedication to wiring Dan. Must say its a good idea. |
07-20-2013, 05:14 AM | #82 |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
Yep no need to worry about things unplugging or glitching costing my points like the last few comps.. And I loose a little weight too Only down side is if there is a fault or I want to upgdate firmware it's not so easy... You'll notice I soldered a join in the wires between esc's & rx, this is so I can unsolder and solder a plug for update firmware.. I'm looking at putting a second layout together so if there is a fault at a comp I can swap it all over and leave fault testing till I get home |
07-20-2013, 05:16 AM | #83 |
And all ready for a comp tomorrow... |
07-20-2013, 06:50 AM | #84 |
| Re: Bergsta
Retirement???? What's next? This thing is still pretty new. And what is that all over your tire? Suds? |
07-21-2013, 04:10 AM | #85 | |
Yeah I've got almost two years on the berg now, I know the rig has evolved over that time and many of the bits are very much like new but its time for a full custom MOA made in house | |
07-21-2013, 07:47 AM | #86 |
| Re: Bergsta Full-on custom made rigs...especially axle housings are going to be very common soon considering how sparse store-bought versions are. Looking forward to seeing what you come up with edit...after I posted that and read it again it made me think of the Super class. Interesting to think 2.2p is following in the steps of Supers now... Last edited by ittybitty; 07-21-2013 at 07:56 AM. |
07-21-2013, 09:15 AM | #87 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
| Re: Bergsta |
07-21-2013, 04:13 PM | #88 |
Haha you hit the nail on the head.. I've been quietly working on my next rig + super and xr10 ;) Sent from my iPhone using Tapatalk 2 |
07-21-2013, 06:13 PM | #89 |
| Re: Bergsta
Heres an old snapshot from solidworks of rear (super set will have super dedicated...... Sssshhhhh) but the 2.2 Hulk set I designed so guys that have spent there hard earned on nice upgrades like RCBros tubes/gears, Ti axles from me or Dlux tubes etc you can still run them The front however there is a second option I'll share once I have a production set in hands of testers. |
07-21-2013, 06:43 PM | #90 |
| Re: Bergsta |
08-13-2013, 05:16 AM | #91 |
Got brood goodness! Conflux stubbies, these new ones are crazy.... I was going to showcase them in a new build but I can't wait to have some fun on them so will comp this weekend with them Thanks EddieO for some killa motors!! |
08-16-2013, 06:38 AM | #92 |
| Re: Bergsta
New built shocks.... New brOOds in.... New rtr weight with voodoo's & SLW's................. |
08-17-2013, 12:07 AM | #93 |
| Re: Bergsta
The new brOOds.... Built up a new set of shocks... Thought I would try these Integy shafts, 2@40mm 2@45mm (stock scx is 50mm) This is them with a stock one next to them... In.. I changed to plastic scx, not sure on weigh advantage from these changes cause did weigh sorry... Well with team drivers running these gearbox covers for a while now I thought it best I fit them hey.. |
08-17-2013, 12:13 AM | #94 |
| Re: Bergsta
Oh I forgot to share the weight hey This is how I weigh.. the most accurate way IMO as ive seen many ways to fool the usual style of scales people use And the RTR with lipo etc.. this is with voodoo's on SLW rims.. Carbon wheels and boss claws would come up nice but ive finally got the voodoo's working now and 1710g is good in my books |
08-17-2013, 04:39 AM | #95 |
| Re: Bergsta
Did the shorter shock shafts lower your ride height or just allow you to remove some internal limiters?
08-17-2013, 07:04 AM | #96 | |
Guys with chassis not offering much/any height adjustment it might not be a good option.. Though if you do run internal limiting of 5mm or higher its a mod for you ;) There are other shock shaft options... So when looking the stock one is 3mm x 50mm and you'll need to think about the piston fitting too, in the case of the Integy ones I needed to shim them a little, other ones may need the same or be a direct fit, there is also ones requiring a captive nut but this is added weight IMO so I didn't bother with them | |
08-17-2013, 02:11 PM | #97 |
Had a quick test of the motors at home... WOW!! They have some punch, the rig was picking up the front wheels when I was gassing it on the carpet |
08-20-2013, 04:33 AM | #98 |
Something new turned up today |
05-10-2014, 07:45 AM | #99 |
| Re: Bergsta
Holy cow Its been a long time since this had an update Guess I need to fix that hey?? Heck I haven't even shared my foam tuning mod for shocks I best find some time and update while sitting in front of the heater So its also time to start swapping over to the new chassis... What crawls and needs 5 tuned shocks??? |
05-10-2014, 06:15 PM | #100 | |
| Re: Bergsta Quote:
Uh Oh... this sounds very interesting | |
Bergsta - Similar Threads | ||||
Hulksta's 2012 rig "Bergsta" | Hulksta | EnRoute Berg | 108 | 02-19-2012 06:08 PM |
