09-25-2012, 11:57 AM | #1 |
Quarry Creeper Join Date: Jan 2008 Location: Citrus Heights
| HD 300 question
What is the small ring for that comes with the axles. I Installed them and I can't figure out what its for. Also because we have to use raith knuckles and Chubs I am now over 11 in. wide with 1 IN. wheels. What with are you getting with the set up you are running?
09-25-2012, 12:00 PM | #2 |
| Re: HD 300 question
The rings are shims for inbetween the knuckle bearing and knuckle, not needed for all setups.
09-25-2012, 12:22 PM | #3 |
| Re: HD 300 question
Ya that's what I thought. I just shimmed it a different way.
09-25-2012, 03:39 PM | #4 |
Quarry Creeper Join Date: Sep 2009 Location: Detroit
| Re: HD 300 question
I'm perfectly happy with where the width ended up, I couldn't have planned it any better if I started from scratch. I may even try to end up a little wider so I can run the smallest hub possible. And no, it wouldnt be for weight reasons.... Time for some new hubs! |
09-25-2012, 03:53 PM | #5 |
| Re: HD 300 question So I take it you came up with the same with?
09-25-2012, 05:38 PM | #6 |
| Re: HD 300 question See your luck is not all bad. |
09-25-2012, 06:03 PM | #7 |
| Re: HD 300 question
Those shims are meant to go behind the larger knuckle bearing in order to align the u joints with the kingpins within 1 or 2 thousandths...per SDS.
09-25-2012, 06:25 PM | #8 | |
| Re: HD 300 question Quote:
On my axle, the outside of the tires with flat face 1" wide wheels with shaved boss claws and a .600" or .725" hub (can't remember what I put on them right this minute) is right at 11" overall. With similar hubs on the rear and Dlux aluminum shafts the rear matches the front just about perfectly. | |
09-25-2012, 06:29 PM | #9 |
| Re: HD 300 question They go between the big bearing and the knuckle. With the shim installed on mine if I tighten the wheel nuts down the tires will not turn, take the shims out and all is good.
09-25-2012, 06:38 PM | #10 |
| Re: HD 300 question Which wheel hexes are you using? Do they still have the rib around the backside that spaces them off of the outer knuckle bearing? If not that could be why you're having that issue...
09-25-2012, 06:42 PM | #11 | |
It's really not a big deal, without the shims they seem to be money. PM coming at ya. Last edited by ROWDY RACING; 09-25-2012 at 06:46 PM. | |
09-25-2012, 08:34 PM | #12 |
Rock Crawler Join Date: Dec 2008 Location: dallas
| Re: HD 300 question
Sorry guys just saw this one. If everyone would still post the questions in the general thread its easier to keep up on!! The shim should go in between the large bearing and the knuckle. Agian a machinist issue that im not going to get into. just wastn in the cards to redo 600 stubs over, since it would have delayed us even further.. simple fix to add the shim. If you arent maxing out in the 60+ degree steering range you prob. dont need it. If its used and the hex binds when tightening the wheel nut, the simple solution is to sand the back of the hex a little. I have a set that worked w/ the shims in and several that didnt. Either way not a huge deal. As far as width My new Ti-Fighter is acctually slightly wider at the kingpins then a berg, and Im 10 3/4" at the outside of my shaved boss claws Last edited by SDS Customz; 09-25-2012 at 08:44 PM. |
12-31-2012, 03:05 PM | #13 | |
Also, in order to ensure the shafts are installed properly to get the most life out of them, the wheel hex does not need any modifications. What does need to happen is to shim the small bearing out on the shaft so when the wheel hex is tightened, it does not bind the bearings up when tightening the wheel nut. If your HD's are installed properly, you should have almost no movement in the stub shaft and you MUST be able to tighten the wheel nut down a significant amount WITHOUT the drive pin and end up with a nice free spinning stub shaft. It is best to do this shimming/adjusting with the shaft out of the car but still attached to the outer knuckle. With this type of precise setup you will not be able to run an outer tube bearing as the inner shaft needs to wiggle a small amount when it's at higher steering angles. I placed a delrin bushing in place of the tube bearing and it works well to keep the shaft centered but not too centered as to bind things up. If anyone has questions about how to set the 300HD's up so you can get the most life and strength out of them, feel free to send me your questions and I'll do my best to help out. | |
12-31-2012, 07:03 PM | #14 | |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
Later, Farmer | |
01-01-2013, 02:57 PM | #15 |
| Re: HD 300 question
Try putting some sort of lubrication on them, either the same stuff you use on your gears or something heavier.
HD 300 question - Similar Threads | ||||
Hk-300 Question | WestTxRc | Electronics | 3 | 10-23-2011 12:30 PM |
Super 300 Install question | Nonsonic | Axial AX-10 Scorpion | 13 | 05-08-2011 01:32 AM |
Super 300 question | dustin keeler | EnRoute Berg | 6 | 02-23-2010 11:15 AM |
300 cvd question | KingGee | EnRoute Berg | 18 | 02-09-2010 05:48 PM |
Super 300 CVD question... | BigB_117 | EnRoute Berg | 8 | 01-17-2010 08:41 PM |
