10-16-2012, 09:17 PM | #61 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
| Re: So, I guess I'm a Chump..............
Nice build farmer. I like the jeep in the back ground too |
10-17-2012, 06:34 AM | #62 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
| Re: So, I guess I'm a Chump.............. Thanks Camo I really like the way the rig works. Getting ready to overhaul the front end and redo all the links. When I see ya again you can beat on the Jeep Oh and by the way the Chumper got me a second at our State Championship. Not to bad for never running 4s and this chassis Later, Farmer |
10-17-2012, 06:40 AM | #63 |
Couple pics of rear links. Thinking I want to come off the skid straight then get into the big bend toward the rear a bit more to follow the case somewhat. It's a start though. Rear uppers need a bit of tweaking, but it's getting me more to where I want to be. Later, Farmer |
10-17-2012, 11:49 AM | #64 |
no talent hack Join Date: Feb 2007 Location: Redwood City
rear links look really good like that. btw, if you take the tip of your soldering iron and slightly melt one section of the internal threads of the preload collar they wont back off Last edited by Nabil; 10-17-2012 at 12:45 PM. |
10-17-2012, 12:35 PM | #65 | |
| Re: So, I guess I'm a Chump.............. Quote:
And seeing this RT makde me wanna knock the dust off of mine. | |
10-17-2012, 12:59 PM | #66 |
| Re: So, I guess I'm a Chump.............. |
10-17-2012, 04:53 PM | #67 |
Rock Crawler Join Date: Apr 2009 Location: Saint Charles
Glad you switched Farmer I know it was a much needed change for ya buddy The build looks great and congrats on the 2nd place |
10-17-2012, 05:15 PM | #68 | ||||
Later, Farmer | ||||
10-26-2012, 09:43 AM | #69 |
I have a package waiting for me at home from McMaster carr Looks like I can get the final version of my links done this weekend hopefully. Also decided to redo the whole front end......should be a fun little project. Although it will be well worth it I will post pics as I make progress. Later, Farmer |
10-26-2012, 12:04 PM | #70 |
Quarry Creeper Join Date: Feb 2011 Location: Fenton, Mi
Dude I can't wait to get going on the front axle project!!! It's going to be sick!!!!
10-26-2012, 12:34 PM | #71 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
You gonna find a way to run those 300HD's? I guess once my 300's die I'm back to dogbones and axial stubs.
10-26-2012, 12:58 PM | #72 |
10-26-2012, 06:19 PM | #73 | ||
Later, Farmer | ||
10-26-2012, 06:55 PM | #74 |
10-26-2012, 09:12 PM | #75 |
Pebble Pounder Join Date: Dec 2010 Location: clio mi
Can't wait to get down there and learn the way to grow my bergs like a true FARMER |
11-09-2012, 10:40 AM | #76 |
Small update......Figured while I'm waiting for HD 300's and tubes I would get back on this build. Went ahead and clocked the front gear case up and threw some more caster on my c's. Decided to run the drag link to the passenger side knuckle instead of bolting to my tierod. I have been running a non clocked front ever since my first 86 jeep setup which seems like forever ago. After driving 95geo's rig I knew I had to do it. While drilling and tapping my tubes I hit a shit spot and ended up having to do one 4mm hole. Yah I know kinda a hack job, but it will be fine for tomorrow's GTG. Limited my "TraxxialFest" shocks a bit, but may be a little to much. I will find out tonight on my practice pile. I also got my links pretty much dialed, just need to redo my front and rear uppers in 3/16" 6061 solid aluminum rod. I will wait for my new front end parts before I do that though. Now on to a couple bench shots. Sacked out Fully drooped out Later, Farmer |
11-09-2012, 11:29 AM | #77 |
Nice man, that screw looks awful close to that boss claw. I couldn't convince myself to do that sadly.
11-09-2012, 11:58 AM | #78 | |
Later, Farmer | |
11-09-2012, 01:49 PM | #79 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
You might try drilling a 3rd hole in the knuckle arm using the same hole spacing. With as much caster as you have it should help with all of your clearances unless it causes you to get into the servo at full lock. If is does hit you could always go to a smaller diameter tie-rod.
11-09-2012, 02:02 PM | #80 | |
Thanks man, Farmer | |
So, I guess I'm a Chump.............. - Similar Threads | ||||
I Feel Like A Chump | highlandcrawler | EnRoute Berg | 19 | 01-29-2012 09:35 AM |
V2 Chump PRoto | Almighty Malach | Axial XR10 | 4 | 03-14-2011 07:44 AM |
Just another Chump | Almighty Malach | EnRoute Berg | 29 | 01-22-2010 10:24 PM |
