10-12-2012, 07:05 PM | #1 |
Quarry Creeper Join Date: Jan 2008 Location: Citrus Heights
| New hall Style chassis+ 300 HDS
I had one of the original Hall Style Chassis(sold here DLUX FAB | Products ) and wanted to update it, Here is the New chassis. I also Got a set of Super 300HDs from John (SDS Customz Super 300/300HD's ). In order to run the 300 HDs I had to order a custom set of tubes from Eric at Dlux fab to fit the raith chubs. I also used raith knuckles, both chubs and knuckles are from Vanquish Products(axial wraith exo ax10 xr10 honcho crawler wheels titanium accesories, beadlock wheels ). I used Tomi's knuckle weight system. So now I have a Berg that turns as good or better than my Xr ever did, and a chassis that is super stable and climbs like nothing else I have driven. |
10-12-2012, 08:31 PM | #2 |
| Re: New hall Style chassis+ 300 HDS
Looking good man! Do you have a shot straight on with steering at full lock (not from above)? |
10-12-2012, 08:41 PM | #3 |
Here ya go |
10-13-2012, 11:34 PM | #4 |
Yeah, thats quite a bit of steering. Lots of caster too. Thanks for the pics, I wanted to see what effects that much caster with 8* stuff had on the axle. Its almost like its back to the NON 8* stuff which is interesting.... |
10-14-2012, 01:00 AM | #5 |
Quarry Creeper Join Date: Mar 2009 Location: fair oaks ca
looks gd but why didnt u post ur rig in the berg section u silly sally
10-14-2012, 07:51 PM | #6 |
Quarry Creeper Join Date: Feb 2011 Location: Wood
Ya silly sally i found this through a diff thread. So u can only get as much steering as the shocks will alow .is that correct
10-14-2012, 07:57 PM | #7 |
The shocks are not the reason. The links are the reason I cant get any more steering. I have them shimmed in and the links are touching the motor on one side and is even on the case side.
10-14-2012, 09:21 PM | #8 |
So with all this new found steering i bet ur still going to. take the revo
10-14-2012, 09:40 PM | #9 |
Gold Star Baby! Join Date: Jan 2011 Location: SOUTH JORDAN, UT
Wraith*
10-14-2012, 11:03 PM | #10 |
| Re: New hall Style chassis+ 300 HDS |
10-15-2012, 08:13 AM | #11 |
Quarry Creeper Join Date: Oct 2010 Location: san ramon
what size big bores are good with the new hall chassis and berg axles |
10-15-2012, 09:08 AM | #12 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
10-15-2012, 11:21 AM | #13 |
Ya I use the 4 in. Shocks too.
10-15-2012, 12:02 PM | #14 |
| Re: New hall Style chassis+ 300 HDS A 4" shock will be easiest but you can use anything from a 3.5" with long rod ends to the 4" with smaller rod ends. You will probably want to limit the shocks with the 3.75 or 4"' shocks though.
10-15-2012, 12:14 PM | #15 |
thanks |
10-15-2012, 04:48 PM | #16 |
Rock Crawler Join Date: Sep 2009 Location: Orangevale
Looking good Josh.
New hall Style chassis+ 300 HDS - Similar Threads | ||||
My dlux hall style berg rebuild | CrAwLeR13 | EnRoute Berg | 247 | 09-22-2013 07:48 AM |
Hall Style chassis *** National Champion PROVEN *** | Erik D_lux | Chassis and Suspension | 57 | 01-01-2013 04:26 PM |
Jacobflyin's XR10 Hall Style | jacobflyin | Axial XR10 | 31 | 12-03-2012 05:15 PM |
My DLUX Hall Style Berg | CrAwLeR13 | EnRoute Berg | 27 | 08-03-2011 10:56 PM |
