04-16-2013, 01:29 PM | #181 | |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
| Re: Alex's berg take I Quote:
So I am thinking there is a chance that the large fall you took might have did the shaft in. I have broken plenty on smooth river rock when landing hard on throttle. So I have a feeling that is what broke them. The fact that you were able to have about a dozen hard runs on em is a good sign. NOW I will say that I am not thinking these shafts will be the strongest option out there. But a great budget shaft that will hold up to moderate-mild crawling conditions. Nothing I would feel comfortable saying a guy could compete at a national level comp on high traction rock How high is the traction where you are? Got any pics of the rock you use out there? In regards to the RCbro locker... I think the smaller drive tang is what helped do it in. In my head, it's kind of like a gear reduction thing. A wider tang would have been harder to rotate in that housing, much like a larger diameter gear would be harder to rotate as a pinion. I wish there was more meat on those shafts to that the tang was at least 5mm wide. I may try and get my hands on a set of VP VVD's for the wraith and see if it is 5mm wide. They may be a bit more expensive, but at least I will know that I am working with a higher strength steel to begin with. Which side was it that broke? The long or the short? I may be able to get you out a replacement if youre comfortable taking apart the uni to replace the inner section. | |
04-16-2013, 03:13 PM | #182 | |||||
Rock Crawler Join Date: Oct 2009 Location: Brussels
I'm considering some dlux cf goodness this summer and I'm wondering if I should run some dlux shafts. But I'm not really sure yet because I like the 8* stuff. So I'll try to make them work first, I still have a trick in my sleeve when I get back in belgium. Quote:
This is what I was thinking. Your locker is a proven product, no doubt about it but the tang is too small and if tolerance and the machining on the shaft is not top notch they will never work. As Erik said his shafts are even smaller. Quote:
That was not a large fall, about 1ft 1/2 but just the day before I took big fall in a pond I'm digging near the rock pile. Again I hitted the ground running and the truck did a couple backflip. I kept my finger on the throttle just for the heck of it and because I was confindent about steel locker and your shaft. So I was really stunned when they broke during a totally controlled situation. Right now I'm in congo and traction is pretty high everywhere. Sorry no pictures, It took me about an hour just to upload the 2 previous pictures. As you said that's a mixed feeling, they work, are cheap and are not stated as the strongest shaft out there but there's some improvement that need to be done and then maybe they will be evenmore reliable. I'll start by some longer shafts, both can be easily 2mm longer. The pinion resoning is how I'm seeing it too, and more contact area would help to fight the lever. I broke the short side, I'm not really confortable with taking them appart. So far I broke 3 shafts on just trying to take them appart. How are you doing it? | |||||
04-18-2013, 11:00 AM | #183 |
I simply put them in my vice, and punch the small pin out with a small punch and a hammer. Once that comes out, the rest just falls apart. I can get a picture of how I am holding it if that helps any You think a deeper tang engagement would help? I am not seeing why it would since the break is likely to be near the edge of the locker. But perhaps Im wrong. |
04-18-2013, 11:20 AM | #184 |
RCC Addict Join Date: Nov 2004 Location: union
How did you cut the flats? Was it machined or ground?
04-18-2013, 02:22 PM | #185 |
A little of both. I mill them to really close, then finely shave the last hair so they fit tightly into the locker. From there, I home-brew harden them with a torch and used motor oil
04-18-2013, 04:37 PM | #186 |
| Re: Alex's berg take I I would think your "case" hardening is the cause for his failure in the picture. It probably made it brittle. Why try to change the hardness? If you keep the part cool while cutting you should effect the materials properties.
04-23-2013, 10:11 AM | #187 |
Probably a good point. I certainly am no expert in metal hardening. I just had a non treated set break, but it did have a hard edge rather than a tapered one. I just am used to hardening stuff from back when I was shoving universals in berg axles a couple years ago. The 4340 was too soft, and hardening it like that helped |
04-23-2013, 01:13 PM | #188 | |
05-02-2014, 01:36 AM | #189 |
Bump all the way to the top Here's a vid from last year I've finally had a chance to edit. Running wraith shaft up front with some TAG proto adapter. These shaft are strong, they did hold up very very well. Last edited by AlexG; 05-02-2014 at 01:42 AM. |
05-02-2014, 08:27 AM | #190 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
Back from the dead! Good to see you on here again!
05-03-2014, 01:37 AM | #191 |
Newbie Join Date: Sep 2013 Location: italy
sedona front and rover rear ............?
05-03-2014, 10:52 AM | #192 |
| Re: Alex's berg take I |
05-22-2014, 10:12 AM | #193 |
05-22-2014, 02:57 PM | #194 |
Pebble Pounder Join Date: May 2014 Location: SF
that is one fine rig!!! really need to get on it with my berg |
06-05-2014, 01:11 PM | #195 |
| Re: Alex's berg take I Thanks First time lathing some "Delrin". Also I made some 7mm pistons for my shocks. I'm working on a new rear axle case and tube. I'm just waiting for some 7075 then the fun will start. Not sure about the tube, the finish on the radius is crappy. The OD is 12mm, they felt just a bit too flexy on the lathe but hopefully that's enough material for the job. Only testing will tell. Any tips or advice are welcom off course. Lathing is pretty new to me, been learning in a formation center the last 4 months Last edited by AlexG; 06-05-2014 at 01:17 PM. |
06-07-2014, 07:09 AM | #196 |
Did you see the slight mods I did to the chassis?
Alex's berg take I - Similar Threads | ||||
Alex's sporty aka The Stormtrooper | AlexG | Team Losi Comp Crawler | 105 | 07-03-2013 03:22 AM |
Alex's featherweight Sniper | AlexG | Team Losi Comp Crawler | 40 | 10-04-2012 02:20 PM |
Alex's first ever crawler build | axeten | Axial AX-10 Scorpion | 8 | 03-24-2010 08:24 PM |
Alex's Axial | whitty | Axial AX-10 Scorpion | 6 | 08-07-2008 02:57 AM |
