11-21-2012, 01:10 AM | #21 |
Pebble Pounder Join Date: Dec 2008 Location: Belgium
| Re: Alex's berg take I
Hi Alex, I can't wait to see your chassis on the axles. I really like the chassis that you have designed. ps: The comp was great. A good start, but ended up from second to the 4 place. Hope to see you soon at the comps. |
11-21-2012, 11:53 AM | #22 | ||
Rock Crawler Join Date: Oct 2009 Location: Brussels
| Re: Alex's berg take I Quote:
Thanks mate, I loved my lomoa, but I felt it was time to moove on. Quote:
Hi Steven, I was wondering how was it, too bad I wasn't able to come See you soon Hacked my Rowdy electronic mount. Tomorow I'll work on wiring and fitting everything on the plate. | ||
11-21-2012, 12:54 PM | #23 |
Pebble Pounder Join Date: Dec 2011 Location: françe
| Re: Alex's berg take I superbe
11-21-2012, 12:59 PM | #24 |
| Re: Alex's berg take I |
11-21-2012, 02:24 PM | #25 |
Interesting holes in the cases have you backed them with .015 lexan to keep dirt out? ohhh idea I guess I am NOT going straight home after work.... |
11-21-2012, 02:35 PM | #26 | |
I don't have a mill so that's my ghetto mod to remove as much as I can I'm planning on putting some simple clear tape inside to keep the dirt out. | |
11-21-2012, 02:49 PM | #27 |
| Re: Alex's berg take I I only have rare access.. but I have a drill press I am going to pick up some .01 lexan and glue it over holes I will drill this weekend. Thank you for the idea!
11-22-2012, 10:40 AM | #28 |
I'll see if I can find some polycarb that thin arround sounds like a better solution as dirt will not stick on it. This is what rcc is all about, sharing, learning and laughin' This morning I got a package from Erik with some Ti rod and tinkered my steering. The draglink is parallel to the servo during all the travel and at full lock parallel to the ground, I had to remove the bump under the servo arm. I use a locknut under the VP arm they act as the perfect bump stop for the HD's Got my lowers also, front are DLux rockshow link and I'll tweak the rear one to get the right wheelbase but so far it seems that it's almost dead on. I got some 3/16'' al tubing, 5mm al rod and 5mm carbon tube for upper I'll see witch one will suits my needs once I got my chassis. Last edited by AlexG; 11-22-2012 at 10:48 AM. |
11-22-2012, 10:53 AM | #29 |
It's coming along nicely Perhaps just run clear tape on the outside of the gear case holes? That'd be the lightest, and the sticky part will face the gears so no dirt to build up. |
11-22-2012, 11:51 AM | #30 | |
My LHS was closed yesterday, but thay have some stuff, may be acrylic or clear pvc. but is about the thickness of a thin transparency sheet or scotch tape Last edited by DickyT; 11-22-2012 at 11:54 AM. | |
11-22-2012, 01:32 PM | #31 | |
Thanks Travis , that's a good idea actually but what he said .................................V | |
11-22-2012, 02:03 PM | #32 | |
11-22-2012, 05:14 PM | #33 |
Rock Crawler Join Date: Sep 2009 Location: Orangevale
Try cold lamination sheets, You can get it at any staples or office supply store. It's very sticky, light and strong.
11-22-2012, 06:14 PM | #34 |
Rock Crawler Join Date: Jul 2008 Location: grand rapids, bay area, nyc.
very nice set up man. the steering looks amazing. could you post a few shots from the bottom of the axle? thanks
11-22-2012, 06:20 PM | #35 | |||
Thanks Both F/R? | |||
11-22-2012, 10:45 PM | #36 |
That steering set up is sick! Angle is rediculous and just looks clean! Links look very good as well. She is coming along Cherry! |
11-23-2012, 09:11 AM | #37 |
the front so we can see the flip side of the steering setup thanks
11-23-2012, 04:52 PM | #38 | ||
The HD's are badass , I gave my motors a quick spin today, at full lock they DONT wooble Quote:
Here are two shot of the belly of the front axle Wiring is done, the unit is slightly bigger than I'll like also I forgot to take my 4s cap with me 549g or 19.4oz 320g or 11.3oz | ||
11-23-2012, 05:47 PM | #39 |
thank you sir |
11-24-2012, 02:13 PM | #40 |
Alex's berg take I - Similar Threads | ||||
Alex's sporty aka The Stormtrooper | AlexG | Team Losi Comp Crawler | 105 | 07-03-2013 03:22 AM |
Alex's featherweight Sniper | AlexG | Team Losi Comp Crawler | 40 | 10-04-2012 02:20 PM |
Alex's first ever crawler build | axeten | Axial AX-10 Scorpion | 8 | 03-24-2010 08:24 PM |
Alex's Axial | whitty | Axial AX-10 Scorpion | 6 | 08-07-2008 02:57 AM |
