11-26-2012, 08:56 AM | #41 |
| Re: Alex's berg take I
Nice work Alex! now let's see that chassis. I have seen the drawing a while back and it looks good |
12-05-2012, 03:18 PM | #42 |
Rock Crawler Join Date: Oct 2009 Location: Brussels
Got my chassis in the mail today I'm calling it the REBEL. Also I just got these two little puppies, I got them in a trade for 3 set of SC tires, I dig the hudy lathe. |
12-05-2012, 04:58 PM | #43 |
Gold Star Baby! Join Date: Jan 2011 Location: SOUTH JORDAN, UT
That is just badass!!!!!
12-05-2012, 05:32 PM | #44 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
Wow... Tomi made that for you? He did an amazing job!
12-05-2012, 05:32 PM | #45 |
Chassis turned out fantastic Is the tail section of the cab plats gonna pinch in to the shock support or stay spaced out? |
12-05-2012, 05:41 PM | #46 | |
| Re: Alex's berg take I Thanks Jason He offered me his cutting service, I supply the cf and the design. Well worth the wait, I have two custom wheel set aswell, I'll post pic later. Nothing fancy tough. Quote:
Thanks Travis. The tail will be slightly spaced out, this should reduce flex I think. The chassis is a mix of 1mm and 2mm cf, I was concerned about flex, but everything feels stiff and light. In terms of strength the only parts that may fail I think is the front shock mount but at this point it feels stiff enough and will be even more with the shocks bolted on I guess. | |
12-05-2012, 06:05 PM | #47 |
Nice work Alex I have been waiting to see this cut, the drawings do not do it justice! |
12-05-2012, 06:31 PM | #48 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
| Re: Alex's berg take I alex, that is just killer! just have nothing more to say than bravo man |
12-06-2012, 12:15 PM | #49 | ||
| Re: Alex's berg take I Quote:
Thanks man I aggree, but these pics aren't either. Quote:
Thanks Pete I appreciate. Chassis weight with ALL hardware, just missing panels. I had to beat you 47g - 1.7 oz, I'll try to keep it under 2 oz with panel. These pics looks better with the green background. Also I wanted to know how much my electronic package was weightin. | ||
12-06-2012, 03:57 PM | #50 |
Chassis is sick man! I cant wait to see it mounted up |
12-06-2012, 05:20 PM | #51 |
| Re: Alex's berg take I |
12-06-2012, 06:00 PM | #52 |
Awesome! Can't wait to see it all together |
12-06-2012, 07:47 PM | #53 |
Nice work on that chassis! And you are gonna dig that Motor Master....I use mine all of the time!
12-07-2012, 08:39 AM | #54 | |
Thanks Jeremy At first the Motor Master wasn't reading rpm so I thought the sensor unit on the board was busted but I tried to glue some shiny strip of aluminum on the rpm bushing and it started working again. But readings are not consistent so I started to look for a spare bushing on the web and they're all out of stock, I finally an Orion bushing witch looks to be same and they're sold in pair | |
12-11-2012, 01:59 AM | #55 |
Pebble Pounder Join Date: Dec 2008 Location: Belgium
Hi Alex, That chassis is awesome!!! I'm curious how the rear links will be. |
12-11-2012, 07:28 AM | #56 |
Very nice build! I love how your servo is re-wired... Is that a thicker gauge or was it just a repair?
12-11-2012, 12:16 PM | #57 |
12-13-2012, 07:17 AM | #58 | ||
Thanks Man I appreciate they re the same gauge but way more flexible and stealth the only colored wire is the signal wire on my homade by-pass adapter Awesome news Well the chassis broke after a small fall straight on the roof. I've updated my design and added more material around the holes and I'll make the cab out of 1.5mm cf this time. Should be one week or two before I put my hand on it. The chassis will gain 5 to 7g but I'll make some cf crossbrace ala Dr Frank, maybe they will be lighter than 3/16'' al tube. Right now rtr with 6.6oz worth of brass on the front axles my truck is weightin approx 3.8 lbs | ||
12-13-2012, 08:17 AM | #59 |
Pebble Pounder Join Date: Mar 2006 Location: Placerville
Looks good. I would think if the inner/lower part of the chassis came forward to the front shock mount. it would add alot of strength, without much weight.
12-13-2012, 04:34 PM | #60 |
Rock Crawler Join Date: Sep 2009 Location: dartmouth ns
"The chassis will gain 5 to 7g but I'll make some cf crossbrace ala Dr Frank, maybe they will be lighter than 3/16'' al tube." I'm just waiting on 3mm threaded inserts from Dr Frank to make cf braces for my Secret Agent also. Truck looks great btw Alex. |
Alex's berg take I - Similar Threads | ||||
Alex's sporty aka The Stormtrooper | AlexG | Team Losi Comp Crawler | 105 | 07-03-2013 03:22 AM |
Alex's featherweight Sniper | AlexG | Team Losi Comp Crawler | 40 | 10-04-2012 02:20 PM |
Alex's first ever crawler build | axeten | Axial AX-10 Scorpion | 8 | 03-24-2010 08:24 PM |
Alex's Axial | whitty | Axial AX-10 Scorpion | 6 | 08-07-2008 02:57 AM |
