12-04-2012, 08:41 AM | #1 |
Quarry Creeper Join Date: Sep 2009 Location: Detroit
| The Pinnacle
I've begun collecting parts for my next car since my first attempt at a berg is showing promising results. So rather than tear up what is working very well, I'm just going to build another one from the ground up. Chassis- some derivative of the SA 3.5 and RT2 in a bodiless config. Front axle- stock berg cases, my tubes, VP outers, lots of steering and Super 300HD's Rear axle- stock berg cases, my super light/super scronny tubes (looking for close to 1/2 the weight of the current 1.4 oz rear pair, not sure if its possible but I'm going to try!), my one piece 7075 rear axles with integrated wheel hex's and somewhere around 1" wider than a stock axle. HH's new puller motors, the rest is pretty undetermined at this point, it all depends on how the roller shapes up. Low to even 4 LBS RTR with more metal than nearly (note, I did not say all) any other car of similar weight. It will be roughly 8 oz less than my current car which could still have a lot of weight shed but not without strong considerations to the side effects. Nothing will be consumable or a planned point of wear/failure as a broken car for any reason doesn't finish a course with the least number of points. Stay tuned to see some progress as parts arrive and chips get made. This thread is going to be for documentation purposes only so others can get some ideas and turn them into their own. If you have anything to say relative to how something will or won't hold up, hold your tongue because you might be suprized! Enjoy my thread of nothing for the next few weeks and speculate if you care to. |
12-04-2012, 12:45 PM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: Fenton, Mi
| Re: The Pinnacle
I like the sounds of this man... Making me want to start another build myself! (Still may once the 300's show up since the current setup is working well) good luck with the build man, I will be watching closely for sure! Talk to you/see you soon man! |
12-04-2012, 12:56 PM | #3 |
| Re: The Pinnacle
No pics? I like the sounds of your axles...your tubes...especially the 7075 shafts with integrated hexes |
12-04-2012, 01:04 PM | #4 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
| Re: The Pinnacle
I hope you need a tester! Later, Farmer |
12-04-2012, 01:21 PM | #5 |
| Re: The Pinnacle If anyone ever takes me up on my offer to design parts for them to manufacture, you're in! But....... I think simply talking about making something is enough cause to join the band! O'well, good thing I have no interest in making parts to; uhhhh.... Test. |
12-04-2012, 01:28 PM | #6 |
Quarry Creeper Join Date: Nov 2010 Location: livermore california
| Re: The Pinnacle
Has your ck chassis shown up yet?
12-04-2012, 01:31 PM | #7 |
| Re: The Pinnacle
Negative.
12-04-2012, 01:37 PM | #8 |
| Re: The Pinnacle
That sucks, you ordered yours a week before me too. Not too impressed with dhl paket.
12-04-2012, 02:40 PM | #9 | |
| Re: The Pinnacle Quote:
Later, Farmer | |
12-04-2012, 02:59 PM | #10 |
Rock Crawler Join Date: Jul 2008 Location: grand rapids, bay area, nyc.
| Re: The Pinnacle
cool |
12-04-2012, 03:06 PM | #11 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
| Re: The Pinnacle
"The Pinnacle" Setting the bar pretty high right off the bat. I'll be watching. p.s. I do better with pictures, reading comprehension is not so good. |
12-05-2012, 03:46 PM | #12 | |
Most of the chassis's out there that I've seen are not balanced and have several undesirable traits that leave a lot to be desired, I'd spill the beans on what traits will make a neutral and predictable car with good behaviors but where would the fun in that be?! All I will say is that some chassis designs are closer to that goal than others. | |
12-06-2012, 05:59 AM | #13 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| Re: The Pinnacle |
12-06-2012, 12:17 PM | #14 | |
no talent hack Join Date: Feb 2007 Location: Redwood City
12-06-2012, 02:22 PM | #15 | |
I have actually been bouncing the idea around of not using springs on the shocks, simply letting the suspension characteristics and external forces dictate where in the range of travel it will be at any given time. This will also make getting the car flipped back over much easier because the springs won't be pushing the axles away from the ground, they'll remain in contact and have more traction. But in order for this to be possible the suspension will need to be VERY neutral, if not, it'll be a crap shoot and probably a large disadvantage. Anyways, that's enough spilling of the ideas for me. | |
12-07-2012, 06:25 PM | #16 | |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
12-08-2012, 05:35 PM | #17 | |
I have a week off between the holidays and I'm going to be using some of that time to make the models needed to create a majority of the car. I just hope I get the one key piece in time to make all of this happen, the RT2! Would you prefer a car that stays neutral (front and rear) on steep climbs so the suspension can stay functional to maintain traction, or one that makes the front suck down and the rear lift slightly, or make the front stay neutral and the rear suck down? This is with traction obviously, when traction is lost the traits will go away. And which ever style you prefer, the opposite effects will show up in reverse. Currently I'm leaning towards a completely neutral design that will be stable and free of most odd behaviors and one that is very dynamic throughout its range of travel. In other words, when the suspension is drooped out it will want to compress itself into a neutral zone, when it is bottomed out it will want to extend itself back into that neutral zone. And whichever way it ends up, it'll probably only have about 12mm of sprung bump travel from ride height. To make all of those behaviors function as desired the roll axis location and angle along with the wheelbase change, will all need to be spot on. | |
12-09-2012, 07:22 PM | #18 |
| Re: The Pinnacle
I've found that I like a fairly neutral suspension setup. Combining this with a somewhat lower roll center makes the suspension feel more free and compliant without adding much weight. I'm not a fan of having a lot of front dive. It might help with climbing, but it seemed to make my truck a lot less stable in every other situation. |
12-09-2012, 08:39 PM | #19 |
| Re: The Pinnacle
Cool, thanks for the input!
12-09-2012, 08:47 PM | #20 |
Pebble Pounder Join Date: Mar 2006 Location: Placerville
| Re: The Pinnacle
"I'm not a fan of having a lot of front dive" Are you referring to dive, as in diving under power or digging? |
The Pinnacle - Similar Threads | ||||
Pinnacle Mountain 10-13-12 | mmatthews | Arkansas | 0 | 10-13-2012 08:18 PM |
wraiths at pinnacle mtn | ROLANDROCKSHOP | Scale Videos! | 0 | 08-10-2011 01:12 PM |
K.O.H. trail at pinnacle mtn | ROLANDROCKSHOP | Arkansas | 3 | 07-11-2011 12:16 PM |
anyone use pinnacle for vids , Ive got ?'s | RockRacer1 | Chit Chat | 6 | 05-29-2007 12:35 AM |
