12-05-2012, 07:12 PM | #1 |
Rock Crawler Join Date: Nov 2011 Location: Asheville
| Hub size?
I just ordered my first set of berg axles and ive got some SLWs on the way. I need some advice on what size hubs to order.
12-05-2012, 07:26 PM | #2 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
| Re: Hub size?
Depends on alot of variables such as how wide you want it. Do you want the front the same as the rear? Berg 225 = 9.5, 350 = 9.750, 475 = 10.00, 600 = 10.25, 725 = 10.50 |
12-05-2012, 08:31 PM | #3 |
Rock Crawler Join Date: Apr 2009 Location: Saint Charles
| Re: Hub size?
Hello, welcome to the berg club. On my berg I run mostly 600's in front and 475 in rear. I sometime will change them out depending on the courses. When the gates have tight turns but few side hills I will narrow the rear up a bit and when there are allot of side hills I will make the width the same front and rear. Its all kind of personal preference and how your rig is setup IMO. Check out the build threads in and see what others are running and play around with it. The hubs are pretty inexpensive really. Hope that helps some |
12-06-2012, 07:42 AM | #4 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
| Re: Hub size?
I think it would depend on if it is a set of V1's or V2's
12-06-2012, 08:21 AM | #5 |
| They are v1's So typically running the same front and rear is better for sidehilling? If thats the case should I go 600's or 475's all around? I plan on get a variety later to tune with but I want a good starting point for now. Thanks for everyones input. Its greatly appreciated. |
12-06-2012, 08:26 AM | #6 |
| Re: Hub size?
My berg runs 350 in front and 225 in rear.......................... |
Hub size? - Similar Threads | ||||
Hub size for bully | craddock35 | RC4WD Bully | 4 | 07-27-2012 08:32 PM |
VP hex hub size | painter4x4 | Axial Wraith | 8 | 03-05-2012 09:36 PM |
hub size? | dynamaxxed | Axial XR10 | 5 | 12-16-2010 06:39 PM |
hub size | lizard017 | Newbie General | 5 | 12-06-2008 03:25 PM |
Tire and hub size | mudrinner4ever | Tires and Wheels | 2 | 05-18-2005 07:00 PM |
