12-09-2012, 03:34 PM | #1 |
Quarry Creeper Join Date: Apr 2011 Location: Estonia, Europe
| Heido's Berg build
Hi everybody, I'm starting my next seasons rig build. Till now I've had AX10 and Losi, now moving on to Berg. Specs: Berg V1 axles VP Berg knuckles Axial c-hubs Topcad Axial rear lockouts Super 300 CVD's Axlemaster rear shafts Alumec axle tubes and derlin rear upper link mount by tarmo120 Fast Eddys bearings BWD motor savers Dlux's no slop bushings Electronics: 2x Mamba Micro Pro CC Bec 2x Holmes Crawlmaster 20T Hobbyking HV servo Made the 2mm pin mod to gears Had to see how the tubes look... Rear axle is coming together Special thanks for parts: Chris_The_Battery_Man ittibitty Arctik1 klabeaume tarmo120 |
12-09-2012, 05:50 PM | #2 |
Rock Crawler Join Date: May 2009 Location: Calgary
| Re: Heido's Berg build
Those tubes look great. Keep the pics coming. |
12-20-2012, 06:27 AM | #3 |
Can anyone say how deep are the axle slots on the RcBros locker? My shorter CVD doesn't fit with the stock locker. It sits too out. Also does anyone have a spare gear box half you are willing to let go (motor side)? |
12-20-2012, 08:47 AM | #4 |
RCC Addict Join Date: Jan 2010 Location: Dallas
Great looking parts. That spacing issue does not sound good. If you buy the RC bros, which I do recommend, you might be leading yourselve to the next issue with is an uneven front width. |
12-20-2012, 08:59 AM | #5 |
Very nice start, where can I pick up some of those tubes? I really like! |
12-20-2012, 11:16 AM | #6 |
Quarry Creeper Join Date: Jan 2009 Location: Estonia
Every custom machined part you see is made by me. So since I am not going to get a blue star just yet, please PM me for more info. Also Heido what is wrong with the plastic motor side gear case I made? You can use that as a drilling reference. |
12-20-2012, 11:31 AM | #7 | |
| Re: Heido's Berg build Quote:
12-20-2012, 11:36 AM | #8 |
| Re: Heido's Berg build |
12-21-2012, 08:33 AM | #9 |
Newbie Join Date: Apr 2009 Location: Newark
Looks like this is going to be one hell of a bad ass rig! Looking forward to seeing this build.
12-21-2012, 09:08 AM | #10 |
Pebble Pounder Join Date: Nov 2007 Location: Arnold
ive encountered this with the super 300sthe short side was almost a .10" to long
12-21-2012, 01:59 PM | #11 |
| Re: Heido's Berg build These are the 300's and yes that's about what it is longer. What you did with it, grind down?
12-21-2012, 07:55 PM | #12 |
Rock Stacker Join Date: Jul 2008 Location: Herky
You will have that problem with the newer berg lockers. They redesigned them and the slot isn't as deep as the old ones. You can cut the slot deeper or use the rcbro lockers
12-22-2012, 03:37 PM | #13 |
01-14-2013, 04:26 PM | #14 |
Had a bit time and managed to complete the rear axle Tomi from NCD hooked me up with new chassis plates |
01-18-2013, 01:03 AM | #15 |
RCC Addict Join Date: Oct 2008 Location: Finland
Looking good, Heido! Look forward to see axles and wheels mounted. |
01-18-2013, 04:06 AM | #16 |
01-18-2013, 04:13 AM | #17 | |
If he does and he likes it, I might have a few request for him. | |
01-18-2013, 12:09 PM | #18 |
03-25-2013, 02:38 PM | #19 |
For a long time I have some update to show. The front axle is complete and links done. The steering and lower links are made of 5mm TI rod, uppers 4mm. For the body I'm going to use my Proline Crowd Pleazer, just need to be trimmed. Next up - electronics |
Heido's Berg build - Similar Threads | ||||
My first berg build (my first build thread) | jdacus | EnRoute Berg | 106 | 07-26-2009 07:29 PM |
Berg running HaVoc.... Jp's Berg Build | run2jeepn | EnRoute Berg | 52 | 06-19-2009 11:32 AM |
First berg build | bajajam | EnRoute Berg | 16 | 04-12-2009 03:59 PM |
Berg Build | bearcat263 | EnRoute Berg | 5 | 11-14-2008 05:11 PM |
