12-10-2012, 11:20 PM | #1 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
| New simple tube mod...
This isn't anything special. Just thought it up, and figured it would work great for the people who hand mod a set of axle shafts to fit a berg, but want to keep the shaft centered. |
12-11-2012, 07:32 AM | #2 |
| Re: New simple tube mod...
Smart idea. Did you just loctite it in place?
12-11-2012, 07:47 AM | #3 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
The case will hold it in place once bolted together. Good idea Chris.
12-11-2012, 07:52 AM | #4 |
RCC Addict Join Date: Jan 2010 Location: Dallas
Holy crap. How much weight did you just add!! Just kidding. Cool Mod. |
12-11-2012, 08:01 AM | #5 |
| Re: New simple tube mod... |
12-11-2012, 08:56 AM | #6 |
This mod places a bearing on the case side of the tube to center the shaft into the locker. A new bearing pocket would have to be milled in for best safety to keeping the bearing in. On the other side, knuckle side, there is a built in pocket bearing stop for when you install a bearing. Even if you do the Axial AX-10 C-hub mod you can include the outer tube bearing if you wish. |
12-11-2012, 10:42 AM | #7 |
| Re: New simple tube mod... I just ran in a #X drill bit on the lathe, just deep enough for the bearing to fit. The locker keeps it from going in on the other side. The hole going through the tube all the way is like 7mm. The OD of this bearing is 10mm. So it needs to be bored out to fit the bearing
12-11-2012, 11:16 AM | #8 |
Ahh....ok. I drilled out my stock tubes a long time ago....
New simple tube mod... - Similar Threads | ||||
simple tube bed mod | BigSki | Axial SCX-10 | 2 | 02-21-2011 09:33 PM |
Simple steering mod. | djjiz | Axial SCX-10 | 4 | 07-10-2010 12:35 PM |
BEC electronics: simple mod? | Oseetoo | Electronics | 1 | 04-12-2010 02:14 PM |
Simple Single Battery Mod | thunderwagn | Duratrax Cliff Climber | 5 | 01-08-2009 09:10 AM |
simple stealth mod | 4stAir | Newbie General | 9 | 09-06-2006 08:48 PM |
