Norwegian Berg, Hall style After a couple of years with my XR10 it was time to do some thing new. I decided some time a go that I was going with Berg axels, but couldent decide witch chassis to choose. But for x-mas my wife gave me a Hall style chassis with ti lins and sliders, so thats what im going to build "thumbsup" Progress so far has not been great, but I,m getting there slowly. The axels got new tubes and a needed make over. http://i233.photobucket.com/albums/e...IMG_0020-1.jpg http://i233.photobucket.com/albums/e...o/IMG_0041.jpg http://i233.photobucket.com/albums/e...o/IMG_0044.jpg |
Re: Norwegian Berg, Hall style I like the red or dark orange gear cases you will love that chassis it works great! |
Looks like a great start to a great rig. I really like the color of the cases and chubs . Sent from my HTC One X using Tapatalk 2 |
Re: Norwegian Berg, Hall style Thanks, the colour are Orange. I finaly managed to make some upper links that i think will do the job. http://i233.photobucket.com/albums/e...508_669151.jpg http://i233.photobucket.com/albums/e...574_938217.jpg http://i233.photobucket.com/albums/e...714_091389.jpg Made a elektro package, 2 x esc + bec. http://i233.photobucket.com/albums/e...860_175763.jpg This is getting heavy fast, I'm afraid this may be heavier than 2 kg which was the target. http://i233.photobucket.com/albums/e...385_737363.jpg |
2 Attachment(s) |
Re: Norwegian Berg, Hall style It looks better than mine!"thumbsup" |
4 Attachment(s) |
5 Attachment(s) So close :-( Attachment 226377 Any thoughts about the caster angle ? Attachment 226378 Attachment 226381 Attachment 226382 |
Re: Norwegian Berg, Hall style Looks good :) I like all of the orange "thumbsup" The front upper links look a little bit long... I'm guessing you did that to get some more motor clearence? |
Re: Norwegian Berg, Hall style Quote:
Good looking build. I love the orange, and the way the color scheme flows through the entire rig. "thumbsup" Castor looks good. You probably could get away with a little more if you like how it handles with what you have. |
Re: Norwegian Berg, Hall style First in door test yesterday, but unfortunatly it did not go as smooth as I would have wished. It lived its own life, the esc,s are setup to the radio and the esc,s are setup with the Castlelink. I run 2 x CC micro, bec and a Hitec servo. I run a PL4 and i had the antenna cable tucked inside the receiver to get it out of the way, tryed to take it back out and I think this may have been the problem but I am not sure. Any one else experienced the same problem ? |
Re: Norwegian Berg, Hall style Once bound to the 4PL, you actually should not need the antenna's. Learned that from a Pro level driver. And I coil all mine and never had an issue. I'm running the 4PK, but I would not think the 4PL would be much different. |
It may seem strange, but it seems like it was the tucked in antennawire that made some kind of truble for me. |
Re: Norwegian Berg, Hall style I did when I had a 4pl. I coiled my wire up in the rx box and it went crazy. I took the wire off the rx completely and it worked fine and never went crazy after. |
Re: Norwegian Berg, Hall style Disappointed !!! After running the Hall for 6-8 batteries the chassis are cracking everywear, whitout any massive falls or hard running. http://img.tapatalk.com/d/13/04/26/ygu6ades.jpg http://img.tapatalk.com/d/13/04/26/y2ety6uv.jpg Not the first one to have this expirience I can see :-( Got a local guy to make me some new plates in something called CAW PVC, this feels alot tougher and I can bend it quite much. http://img.tapatalk.com/d/13/04/26/9ygyqara.jpg Allso got a massive weight reduction :-) http://img.tapatalk.com/d/13/04/26/yhy4e3yz.jpg http://img.tapatalk.com/d/13/04/26/dubevusa.jpg |
Re: Norwegian Berg, Hall style Lexan in the sun, dealing with temperature changes, and the abuse these crawlers take just isn't going to hold up anything like some Carbon Fiber or Delrin. It looks "neat" and allows you to paint it like you did, but is inherently prone to failure of this type. |
Re: Norwegian Berg, Hall style locktite and lexan dont mix well either |
Re: Norwegian Berg, Hall style The cracking has not happened for us that have been running them for a while now. Every once and a while someone will brake a side plate but I haven't seen that kind of cracking. I think the brand of lexan really makes a difference. |
Re: Norwegian Berg, Hall style A little update "thumbsup" I have modified the chassis to a total height of 3 ". Allso I got the motors and gearboxes serviced, painted some parts and fitted new skins. Ready for the Spanish nationals in February 8) http://i233.photobucket.com/albums/e...psaa20f4cb.jpg http://i233.photobucket.com/albums/e...pse6e0ae2b.jpg http://i233.photobucket.com/albums/e...psea220bc1.jpg http://i233.photobucket.com/albums/e...psd3cf7adb.jpg http://i233.photobucket.com/albums/e...psec11ec33.jpg http://i233.photobucket.com/albums/e...ps4721e72d.jpg |
