Re: New gearbox and gear options Alright. There was a bit of dragging the feet but things look like they are in motion. I was told I should expect the adapters this coming Monday and the price should be about $3 ea, needing 1pc for each small gear you want to adapt. You will also need new bearings (I will go over this later). I am thinking I will put a "kit" together and sell the bearings and adapters for $11. That will do 1 3rd gear and 1 2nd gear. IMO, you would need all new bearings for the MT cases, is this something that you guys would like to see in the kit? In summary: I could do all brand new bearings and the 2 adapters for about $16. I could do just the necessary replacement bearings and 2 adapters for about $11. Also, I had it brought to my attention that they are wanting to charge $50 to ship these parts over seas. If any of you guys want some without the expensive shipping I could stock these. Even for the domestic guys, I could stock these parts for 1 stop shopping. I just need to know if there is interest. Edit: I am out of tubes right now but the next batch is almost done so, all tubes bought from here out will have the bearing pocket that will fit the MT box and the Berg box "thumbsup" |
Re: New gearbox and gear options I say a kit with all the bearings needed! It's really not that much more!"thumbsup" |
Re: New gearbox and gear options Id say a kit with all the bearings as well. Well worth the extra money to not have to source the bearings. I was looking for a parts list/manual for the MT online, to find the bearing sizes without any luck anyhow. I was just about to pm about the tubes anyway. Would it be possible to buy just the rear tubes? How hard would it be for those of us with just a drill and dremel to mod the 4th gear? |
Re: New gearbox and gear options Quote:
Speak up if $5 matters to you. I suppose I could always carry the two options.... Quote:
Here is the response to your PM. Quote:
See above for my response on the 4th gear. |
Re: New gearbox and gear options Don't mind the post at all! You brought up a good point about the 4th, there's no point in milling the metal fourth since its so heavy! I think if you just reduce the width of the peice that attaches to the case, then that should do it on aligning the upper link mount!"thumbsup" |
Re: New gearbox and gear options Awesome Erik! I personally think there should be 4 total options. Conversion bearings and adapter for all berg gears, all bearings and adapters for all berg gears, conversion bearings and adapters for mt large gears and berg small gears, all bearings and adapters for mt large gears and berg small gears. |
Re: New gearbox and gear options Yep. I would say the bearings and adapters sold together. |
Re: New gearbox and gear options X3 Eric, do you have the small mt gears? When I ordered the cases and plastic gears I was under the impression I could use my small Berg gears:oops: Later, Farmer |
All this has me super excited as well! |
I dont have any small gears. I contacted them and they said some were on the way and sitting in U.S. customs so they dont have a clue how much longer it will be. You can use the Berg 3rd with the plastic gears but you will have to run the Berg 4th until you can get an MT small 3rd. As Tgreer said below, you will also need a bigger pin in the Berg 3rd. IMO, if running plastic, its just much easier to not mod the Berg stuff and run all MT stuff. However, 2.5mm pins in the Berg stuff is the only way to go anyway, IMO. Quote:
The adapters will make it so that you can run Berg small gears in the MT case. The problem he would face is that the MT 4th gear is 6mm vs Berg at 3.5mm. That means that the MT large 3rd will not be spaced far enough away from the MT 4th. To fix this, you either run: Berg 4th, Berg small 3rd (with bigger pin mod), MT large 3rd, MT style adapter Berg 4th, MT 3rds All MT gears with milled out MT 4th for a Berg locker. You always need a Berg locker no matter what. I think thats confusing enough? So confusing that I am only 75% sure I am right. :lmao: Just refer back to this post and if youre running a different combo than what is listed in that post, let me know and I will try to help. Again, please post in this thread, not a PM so others can see the answer. http://www.rccrawler.com/forum/enrou...ml#post4133623 |
Re: New gearbox and gear options I could be wrong, but it looks like to me the best two options are run 100% berg gears with the MT case, or if the plastic gears hold up run all MT gears with a berg locker and MT case!"thumbsup" |
All berg gears, all plastic or a combo of berg/plastic. The best part is that if the plastic does not work, in theory it should not work starting at the final 4th gear and work its way back. By doing this, you could start running all plastic, then if that does not work, you will probably strip the 4th gear so just run Berg 4th with the rest plastic. If that does not work it will probably be the 3rd gear that strips, so, now Berg 4th and 3rd but plastic 2nd. If that does not work, back to all Berg :D |
Re: New gearbox and gear options Nice work my friend, I will be in touch very soon"thumbsup" Somewhat distracted with my daughters Wraith build right now:twisted: Especially since she wants all the "Tough" parts:lmao: Later, Farmer |
Re: New gearbox and gear options Erik count me in for the hole package were you get everything in the kit, makes life easyer,thanks"thumbsup" |
Later, Farmer |
Re: New gearbox and gear options Just got all my parts in to try and contribute to the pile of knowledge on this. I have some idears rollin around. My complaint is that the locker is larger then even the axial drive tangs. So that will force some mods.... But I think I might order in some VP VVD's or RC4WD wraith XVD's to test a little on. I think the plastic gears will do fine actually. At least in the rear if youre nice. I may be making all delrin tubes for mine, pick up some D_Lux berg lower link mounts, and of couse the XR knucks/chubs..... Stay tuned"thumbsup" |
Re: New gearbox and gear options Just got a set of plastic gears in that mail today, only ended up using the large 2nd gear. The 4th gear wouldn't come off of the locker (they use some super thread locker) and the large 2nd gear is taller than the steel gear so it rubs the case and makes an awful noise. I'll report back after I do some bashing when my rigs finally done. |
