04-10-2013, 08:26 AM | #1 |
RCC Addict Join Date: Jun 2006 Location: spotting for jeepsohigh
| Snipers Berg
I figure its time to show old reliable some love from the fab shop. specs **** Tubes 300 front axles Axle masters Rear Straight Axles MannOmann 3rd and 4th Gears Gunner Pins Everywhere RC Bro Lockers 86 Jeep steering setup, Tubes are not ground thou Hitec 7950 Castle Bec at 7 volts 2 Sidewinder Micro Esc's, Switch is removed Vanquish Knuckles Lunsford Steering Links Holmes powered Traxxas big bores turned down at the fab shop with losi Mini Springs and Jeepin Doug Retainers I think its an T1E stage chassis, Ti rear lower links, carbon front lower/rear upper links. Tore up shaved rovers lightened Mayhem rims |
04-10-2013, 08:33 AM | #2 |
| Re: Snipers Berg
What...no independent suspension using Berg cases?
04-10-2013, 08:59 AM | #3 |
| Re: Snipers Berg |
04-10-2013, 09:24 AM | #4 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| Re: Snipers Berg
Now those are vent holes! Keeps good air flow for the foams right! |
04-10-2013, 09:28 AM | #5 |
| Re: Snipers Berg |
04-10-2013, 10:21 AM | #6 |
Rock Stacker Join Date: Oct 2011 Location: middle of Mo. where
| Re: Snipers Berg
Don't change anything with a score like -117 in 4 courses you might loose your mojo!
04-10-2013, 11:21 AM | #7 |
| Re: Snipers Berg |
04-10-2013, 08:45 PM | #8 |
Rock Crawler Join Date: Apr 2009 Location: Saint Charles
| Re: Snipers Berg
This thing will never work......................... shit, I only had a -97 Sunday I guess it will work after all Looks and works great Rick, I look forward to seeing you work on your own rig for a change |
04-11-2013, 10:16 AM | #9 | |
| Re: Snipers Berg Quote:
I know right, Starting slow, the truck performed well last time it was out, so i dont want to make too many changes just yet. I made some carbon upper links today, mounted up it saved 14g. | |
04-11-2013, 05:45 PM | #10 |
Rock Crawler Join Date: Feb 2009 Location: LaGrange
| Re: Snipers Berg are you going to pin the rod ends in .. i used .55 piano wire with a .54 drill bit for mine
04-11-2013, 07:25 PM | #11 |
| Re: Snipers Berg
Yes they are pinned
04-12-2013, 05:54 AM | #12 |
04-12-2013, 07:33 AM | #13 |
| Re: Snipers Berg |
04-12-2013, 07:47 AM | #14 |
| Re: Snipers Berg Thats great Shane, my first front lowers did not last long, the rock rash tore them up bad, the second set with the aluminum lower half sleeved are still on the truck, with many runs on them.
05-26-2013, 06:49 PM | #15 |
| Re: Snipers Berg |
05-27-2013, 02:26 PM | #16 |
| Re: Snipers Berg
Also made new beadlock rims 5 piece design, carbon centers,delrin beads, aluminum beadlocks, Going to make a set of carbon beadlocks as well, |
06-15-2013, 06:01 PM | #17 |
Congrats Buddy on your 2nd in the State championship. Way to earn your National Spot!!! That $20 chassis really works for ya. Hehe |
06-16-2013, 08:06 AM | #18 |
| Re: Snipers Berg
Thanks, truck really performs well , I hate to even tear it down for a rebuild, but it's going to happen, still not sure what chassis I am going to run, but leaning towards something similar to the current one.
06-16-2013, 09:39 AM | #19 |
| Re: Snipers Berg
Tear down begins, truck weighs 5.39 lbs right now, the plan is not to be superlight, but just clean up the truck, replace what's broke,worn,
06-16-2013, 10:52 AM | #20 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
Congrats on 2nd place Sniper!!!
Snipers Berg - Similar Threads | ||||
Snipers Berg | sniper | EnRoute Berg | 20 | 06-24-2012 04:17 PM |
