06-01-2013, 03:56 PM | #1 |
I wanna be Dave Join Date: Dec 2006 Location: here
| 5TH Dimension Minimal berg rebuild Uploaded with ImageShack.us 5TH Dimension Minimal berg rebuild I'll start off by saying thanks to Travis @ 5D for offering me a spot as a 5TH Dimension Team Driver... My plan is to build this today basically as a chassis swap. So I can run the Minimal chassis @ the AZ Shootout next sat. My first impressions of the chassis out of the box ( besides the ear to ear smile) well packaged, has all the hardware, shock rails look really strong. looks like Travis has put a lot of work/time in to these chassis... now to start building. Uploaded with ImageShack.us http://www.rccrawler.com/forum/chass...a-chassis.html Last edited by tapped-out; 06-03-2013 at 01:30 PM. |
06-01-2013, 04:22 PM | #2 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
| Re: 5TH Dimension Minimal berg rebuild
Cool to see you join the 5th D team Matt! Put that sucker together and get some pics up for us!
06-01-2013, 05:06 PM | #3 |
Woohoo! The Fifth Dimension will be ripping hard in AZ! Glad to have you on board Matt. Hopefully you don't run into any hiccups with the short time you have before the comp. |
06-01-2013, 05:43 PM | #4 |
5D is coming up. Congrats Matt. I'll be eye baling that rig in AZ. |
06-01-2013, 07:47 PM | #5 |
Quarry Creeper Join Date: Jul 2008 Location: Hesperia ca.
Congrats Matt! Is it together yet.
06-01-2013, 08:56 PM | #6 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
Welcome aboard Matt. I honestly think with the right gear...you & Ryan can consistently finish in the top 5. Im looking forward to seeing what you guys in the dez come up with. Congrats brutha. JD Last edited by HARDKNOCKZ; 06-01-2013 at 09:44 PM. |
06-02-2013, 01:15 AM | #7 |
Thanks guys.... tweaked on this for a few hrs. today. The chassis swap went rather easy with minimal link adjustment I was able to use my old links. my upper links are robbing of some articulation, good enough for now. I'm really happy with the look and feel of the chassis once all braces and hardware was bolted together chassis is Solid. Hope to get out tomorrow for a shake down. JD... thanks for hooking me up with 5th Dimension/Travis. Rig specs: 5th Dimension chassis Berg axles front drilled gears, Rcbro locker, turned down alum tubes, super 300's. Rear drilled gears, Rcbro locker, Dlux tubes, CreeperBob ti inner axles. Shocks SCX10 W/losi green F/R Motors HH red label 16T motors. Elec. CC Mamba Micro pro esc x2, CC BEC, 5995 servo, 4pl radio. wheels VP DH & V4 RIG weight 4lbs 140z I'll let the pics finish this post.. Uploaded with ImageShack.us Uploaded with ImageShack.us Before rebuild Uploaded with ImageShack.us after Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Last edited by tapped-out; 06-02-2013 at 06:24 AM. |
06-02-2013, 06:13 AM | #8 |
I've been scared to drill out my gears went ahead and bit the bullet the other day...F/R gear sets = -17g Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Last edited by tapped-out; 06-02-2013 at 06:31 AM. |
06-02-2013, 02:38 PM | #9 |
Pebble Pounder Join Date: Feb 2010 Location: Apple Valley
Nice Matt!!! It is Looking good Hit me up if you want to go practice sometime.
06-06-2013, 01:11 AM | #10 |
Went out today for a shake down glad I did needed to make a few tweaks on the rig before AZ shootout. |
06-06-2013, 01:17 AM | #11 |
Need to get rid of that rear wheel hop. Other than that, it looks good. |
06-06-2013, 01:33 AM | #12 |
| Re: 5TH Dimension Minimal berg rebuild |
06-06-2013, 01:39 AM | #13 |
06-06-2013, 03:28 AM | #14 |
Im pretty impressed with how she did outta the gate there Matty. Looks like you have some minor tweeks to settle her down a touch. We'll be seein you, D Wray, Chaz & the other West Coasters on that killer Prescott rock in a bit. Im excited to see how she does for you man. Like I said before...I honestly believe that with the right rig...you gotsta skills to consistently finish top 5 on ANY day brutha. So bring that game you got & make us proud. JD |
06-06-2013, 06:29 AM | #15 |
whats your rear foam setup? and how wide are your rear wheels?
06-06-2013, 11:32 AM | #16 |
Thanks guys... rear wheels hopping....I'm thinking rear foams need changed.. Jim... ... Old style DD firm inner & soft outer. Wheel width It's a VP V4, 1" wide. Last edited by tapped-out; 06-06-2013 at 11:49 AM. |
06-06-2013, 12:02 PM | #17 |
| Re: 5TH Dimension Minimal berg rebuild aybe you need more breathers too? And I'm thinking the greens are a little too stiff and/or your piston speed is too fast
06-06-2013, 01:41 PM | #18 | |
| Re: 5TH Dimension Minimal berg rebuild Quote:
(if you look close you can see them) I thought greens might be to stiff also. After my test run yesterday here's my set-up for AZ shootout. Before test run I already made some new upper links from 6061 alum tube.. lost 1oz of weight. not sure if they will hold up???? links Moved rear upper links down a hole @ Chassis (middle hole). Front upper links are in top hole. Shocks.. swapped out Losi greens springs. W/ Losi mini-t silver FRONT & Losi MRC silver REAR 35wt oil. foams Left them alone DD firm inner/soft outers. Uploaded with ImageShack.us | |
06-06-2013, 02:32 PM | #19 |
You may have the wheel vented but then the closed cell foam is blocking the vent holes. You might try venting the tires to settle some of that bounce.
06-06-2013, 02:45 PM | #20 |
| Re: 5TH Dimension Minimal berg rebuild He's using the old style open cell inners so it should vent fine. I really think it was hopping mostly due to being over spring.
5TH Dimension Minimal berg rebuild - Similar Threads | ||||
BOOSTED's 2014 build The 5th Dimension: MKII begins:pg 11 | boosted4lyf | EnRoute Berg | 239 | 10-10-2013 12:08 PM |
My Berg Rebuild # ? | joesbruiser | EnRoute Berg | 135 | 02-21-2010 08:27 AM |
I need a TXT chassis plate dimension (any hole to hole dimension) | NickRummy | Tamiya Txt-1 and Juggernaut | 1 | 11-28-2008 01:36 PM |
