06-18-2013, 12:26 AM | #1 |
Rock Stacker Join Date: Dec 2011 Location: canada
| setting your c's
anyone have a tip or tool for setting the angle on c's evenly between both sides? old school protractor?
06-18-2013, 12:48 AM | #2 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
| Re: setting your c's
Eyeball it
06-18-2013, 01:12 AM | #3 |
no talent hack Join Date: Feb 2007 Location: Redwood City
1. use 2 objects that are the same height. (parts boxes, cigarette packs, machinist blocks, etc) 2. set the chubs flat on object 3. rotate gear box to desired angle 4. drill and install |
06-18-2013, 02:09 AM | #4 |
Eyeball it while doing the following: 1 use 2 objects that are the same height. (parts boxes, cigarette packs, machinist blocks, etc) 2. set the chubs flat on object 3. rotate gear box to desired angle 4. drill and install |
06-18-2013, 02:44 AM | #5 |
RCC Addict Join Date: Mar 2009 Location: The REAL Nor-Cal
I used a protractor. |
06-18-2013, 05:46 PM | #6 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
| Re: setting your c's |
06-19-2013, 06:10 PM | #7 |
Rock Crawler Join Date: Feb 2009 Location: LaGrange
I use 3mm grub screws to set them Sent from my SAMSUNG-SGH-I337 using Tapatalk 2 |
06-20-2013, 01:48 PM | #8 |
06-20-2013, 03:09 PM | #9 |
I drilled and tapped the c-hubs to 3mm clocked them to where I was comfortable and tightened down the grub screws with blue lock-tite,put a sharp end on the grub screw also ao it will set itself in the aluminum or plastic Sent from my SAMSUNG-SGH-I337 using Tapatalk 2 |
setting your c's - Similar Threads | ||||
setting up for g6 n | zonkerd | Vaterra Twin Hammers | 3 | 02-12-2013 10:00 AM |
Setting the DX6 up? | run2jeepn | Electronics | 36 | 07-21-2007 10:04 AM |
Need help setting up profile! | Snake_01 | Comments, Suggestions, and Help | 3 | 06-10-2007 10:10 PM |
setting up CFNN | joesbruiser | Tamiya Clod Buster | 4 | 12-24-2006 08:53 AM |
