06-23-2013, 12:29 PM | #1 |
I joined the Band! Join Date: Jun 2013 Location: rohnert park
| rear axle play
i finished my tracer 2.2 and noticed that the rear axle has a little play where the wheels bolt on, it can move side to side about 1mm to .5mm. it clunks when i steer left to right. is this normal?' here is a video berg 2.2 rear axle play - YouTube Last edited by ncampos976; 06-23-2013 at 01:41 PM. |
06-23-2013, 02:35 PM | #2 |
DravTech Join Date: Aug 2012 Location: Sweden
| Re: rear axle play
I had the same in my old V3. I solved it with some shims on the axle in the gear box. First I tried to use shims between the outer bearing and the e-clip, but found that it worked better to shim it inside the gear box instead. Depending on how much play you want to remove you have to pay attention so the gears still mesh properly when you shim it. |
06-23-2013, 02:46 PM | #3 |
| Re: rear axle play
ok, is it fine to leave it like this? i can shim it out. but its just doesnt seem right.
06-23-2013, 02:52 PM | #4 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
| Re: rear axle play
I have tried to solve slop issues to no end. There is always going to be some. Even if you get it just right, one nasty bind up and right back where you started. I wouldn't sweat it.
06-23-2013, 02:57 PM | #5 |
| Re: rear axle play
ok, thanks guys.
rear axle play - Similar Threads | ||||
Rear axle play? | (Greg) | Axial XR10 | 10 | 03-27-2011 03:49 PM |
Rear axle upper 3-link play (worn) | Avalanche | Axial AX-10 Scorpion | 10 | 01-14-2009 10:43 AM |
less axle play | bigblazerboy | Tamiya TLT Crawlers | 7 | 03-20-2008 04:14 PM |
Slight play in rear axle | procraft98 | Newbie General | 10 | 09-20-2007 08:19 PM |
