Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: Shock cap extenders
Old 07-06-2013, 06:32 PM   #1
Default Shock cap extenders
I see a lot of crawlers with shock cap extenders making their installation a lot easier in tight axle shock mounts. Where does one find these shock cap extenders?
Thanks
Marshall_S is offline   Reply With Quote
Old 07-06-2013, 06:34 PM   #2
sniper's Avatar
Default Re: Shock cap extenders
Do you mean the shock cap mod, where a revo rod end is put in place of the aluminum stock mount?
sniper is offline   Reply With Quote
Old 07-06-2013, 06:53 PM   #3
Fifth dimension
Crawllife's Avatar
You have to do the cap mod bud. Then you'll get the room ya need. Google, rcc or YouTube search " big bore cap mod". You'll be good to go. If you don't want to do it, dlux sells them.
Crawllife is offline   Reply With Quote
Old 07-06-2013, 06:57 PM   #4
Yep, that's one I'm talking about .... thanks, I'll look it up.
Old 07-06-2013, 07:17 PM   #5
sniper's Avatar
You just cut off the current top,drill a clearance hole for a 4mm screw, and put a rod end on it.
Maybe put a dab of silicone on the inside to prevent any oil leaks
Old 07-07-2013, 07:24 AM   #6
Yep, watched a couple YouTube vids on it ... easy enough.
Thanks again guys.
Old 07-07-2013, 10:25 PM   #7
Wanna get? Gotta want.
Erik D_lux's Avatar
I prefer a 3mm screw as 4mm can be really heavy especially in anything but aluminum.
If you get any oil in that part of the shock, its time for a rebuild.
Erik D_lux is offline   Reply With Quote
Old 07-08-2013, 08:09 AM   #8
2013 2.2P Nat. Champion
SkaldidDog's Avatar
Use a Traxxas Revo GTR shock end for the cap mod and a stock Traxxas shock end for the bottom. Like EDL says, use 3mm. Thread the cap too to reduce wobble if the screw should come loose. This has never happened to me but maybe that's why.
J
SkaldidDog is offline   Reply With Quote
Shock cap extenders - Similar Threads
Shock cap mod Deezul General Crawlers 24 08-09-2011 08:56 PM
!!!!!!!!!!!!!!!shock cap mod!!!!!!!!!!!!!!!!! gatecreeper Newbie General 5 08-01-2011 10:31 PM
Lower shock cap.... HRDROKN Venom Creeper 6 12-09-2009 04:47 PM
shock cap keep poping off hdcherokee Axial AX-10 Scorpion 3 12-31-2007 09:27 AM
