07-04-2015, 08:00 AM | #61 |
Pebble Pounder Join Date: Jun 2011 Location: Le Mas Petit 81 France
| Re: A new BERG Tracer V3 |
10-30-2015, 03:24 AM | #62 |
Hi! Some news about Berg TGS Evo, because berg front axle made me freak out. I made high clearance universal joints, modify the axle with holes to put long screw, but nothing can resist and I lost the last two competitions because of it The solution: AR60 axial CVD Let's go New tubes are needed, and modification of axle pinion to receive the new alu spool After some measures, a lot of time in front of CAD, and after a while milling, my new spool And as V3 has 12mm bearing balls, I need to turn 2 delrin rings in replacement The more difficult is pinion milling. The Vanadium protection is really hard and carbure tools get out. But it's done And delrin tubes, with aluminium Chub and hub and 8° and AR60 cvd I need a new servo support and it's done http://youtu.be/vDHmDul14P8 Yes !! |
10-30-2015, 10:12 AM | #63 |
10-31-2015, 10:38 AM | #64 |
10-31-2015, 04:57 PM | #65 |
Rock Crawler Join Date: May 2012 Location: Australia
Instead of using the delrin bushings on your locker, could you not machine the outside of the locker down where the bearings sit and use a bearing with a smaller ID?
11-01-2015, 12:51 AM | #66 |
Hi ! there are many reasons: first: I prefer to leave matter second: I haven't got any bearing with smaller ID third: delrin is self lubricated plastic and is good to replace bearing ( bearings were exchange against delrin rings in the rear axle: zero noise, 50% weigth earned. You only hear the engine noise=nothing ) Self lubrification is the delrin spec |
11-01-2015, 01:32 AM | #67 |
| Re: TGS Evo BERG Tracer V3
And the last operation: screwing C-hubs I thought to not screw, but Pat13 has advised me not to do that, and with his experience, I prefer to listen. Thank you Pat Like delrin does not have much resistance to the thread, I decided to drill tube from side to side, just on rear. Like that, screw has 10 mm of delrin to screw and C-hub can't move in rotation or lateral translation Whouuhouuuuu ! |
11-01-2015, 02:17 PM | #68 |
the first run http://youtu.be/XtHzeL-nZ70 |
11-02-2015, 12:37 AM | #69 |
11-02-2015, 06:43 AM | #70 |
| Re: A new BERG Tracer V3 Last edited by tgenial58; 11-02-2015 at 06:47 AM. |
11-14-2015, 05:24 AM | #71 |
Hi! Some news, again Today is ( a sad) day of conception and realisation of weights's supports for rear axle. Support are made in delrin . Weights are made with Pb Conception and milling preparation the result Domed head screws will replaces current screws I'll go to test tomorrow Front weights's supports will be made, but I want put Chub and weight's support in 1 block, so some drawing and working are needed. |
11-14-2015, 12:30 PM | #72 |
11-16-2015, 12:40 PM | #73 |
I was a bit optimistic about the strength of Delrin. With a stroke of saw, I've recycled materials links below. It allows well clear the space under the bridge and has a better behavior. And here are the new supports weights. There is more material and have replaced the break by a slope, which will hang less. And with domed screws, it's better |
02-17-2016, 12:31 PM | #74 |
Hi! Now, it's slimming cure time I have changed all alu links by titan 4mm (grade 5) 1/3 weight earned new steering link uppers and lowers rear links I've changed shocks too I replace 130mm shocks by reversed wraith shocks, mounted with small springs and alu cup and rod end replace cap fixation to limit height of chassis and twist of rear axle Soon, the steel rear shaft will be replaced by Ti, too Now, I'm wondering if I change my vapors for pullers (i've already them) or if I stay in this configuration. Pullers are lighters than vapors of ~30g |
06-08-2016, 04:16 AM | #75 |
Quarry Creeper Join Date: Dec 2015 Location: Norway
Nice build. Any updates?
06-08-2016, 05:12 AM | #76 |
07-25-2016, 02:09 AM | #77 |
Hello !!! It' done! My new rig is ready I've choose the green reinforcement a central carbone plate gives rigidity and support for Rx, easy to wire and fix Just to unscrew one and skid opens and let an easy access I had to convert my V3 axles for 4 links chassis So I've milled an alu lower link and shock support and a delrin part for the upper I've reduced it on front, because it was really too long Building of a marble to do links Upper links are builded with carbon tube 4mm and the lower links with Ti grade 5 4mm Up Down 1074g for front, 704g for the rear, repartition weight is good. Result is an extra rigid chassis, will be extra precise (tested with Lizard) |
08-16-2016, 07:08 AM | #78 |
Hi! Some news Steering servo is really not at the right place but I can't move it on this axle. The solution is a new gearbox and new tubes and like some fancy not kill servo support in 3mm CF It's mounted in delrin with brass inserts ;) I've add some weight on front axle, but I need to mold news, to be in good position I have to test and run a lot and it'll be ready |
09-18-2016, 06:42 AM | #79 |
the first training session on terrain http://youtu.be/fFrGsCvxNhY New Losi springs are arrived and I milled 2mm delrin spring cups |
09-18-2016, 09:17 AM | #80 |
RCC Addict Join Date: May 2012 Location: Folsom
You missed poting about your front gear case.......
A new BERG Tracer V3 - Similar Threads | ||||
My new Berg Tracer 2.2 | Grump | EnRoute Berg | 28 | 11-06-2013 06:29 AM |
new berg tracer v3 | jaxandjokers | EnRoute Berg | 11 | 02-27-2013 12:23 AM |
Berg 2.2 vs tracer ? | NullMind | EnRoute Berg | 5 | 05-05-2011 02:13 AM |
Berg Tracer 2.2 | gon4lo | EnRoute Berg | 9 | 12-10-2009 08:18 PM |
