Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > EnRoute Berg
Thread: A new BERG Tracer V3
Old 10-03-2016, 12:56 PM   #81
Default Re: A new BERG Tracer V3
Ok!
So
3D CAD with the lightest strain and as thin as possible
Some settings to generate milling code
and the milled piece
To close gearbox, I use 4mm alu surfaced at 3mm
(the rear is on progress ;) )
screws fixe delrin part on alu plate which is threaded
and it works really good
tgenial58 is offline   Reply With Quote
Old 10-03-2016, 01:21 PM   #82
Why don't you use Carbon Fiber to close the box?
Great looking parts by the way ;)
xkill is offline   Reply With Quote
Old 10-03-2016, 01:58 PM   #83
because aluminum does not delaminate
Thanks
Old 10-03-2016, 05:22 PM   #84
True about the delaminating part.
But still I think you should make it an option on your berg axles...
Others used it without major problems.
Old 10-03-2016, 05:23 PM   #85
Old 10-04-2016, 02:18 AM   #86
Yes, it could be an option.
I have some 3mm CF in stock, used to build servo support, but my gearbox will begin full black.
A bit of gloss is cool ;)
The first reason is that I think violent impacts are better absorbed by alu than CF
and it' changes a little bit of others gearboxes
Old 01-09-2017, 01:41 PM   #87
Default Public Enemy, new wheels
Hi!
And happy new year
New season, new wheels
the BioHazard model for front and BioHazard 1/2 for the rear
Milled in strong 2 mm aluminium
Old 01-09-2017, 08:17 PM   #88
cabron's Avatar
tres bien
cabron is offline   Reply With Quote
Old 01-18-2017, 03:31 AM   #89
Merci
Another step of my public enemy evolution
I've mounted TGS alu shocks mounts
It permits to have really good move of shocks, without hard point , without modify the shocks
Long version on front (17mm) and short on rear (14mm)
I love it: it is really smooth, super reactive, than happiness!
Old 01-18-2017, 06:10 AM   #90
Wow!! Very impressive!
richardgarrett56 is offline   Reply With Quote
Old 02-15-2017, 02:04 PM   #91
Hi!
Finally, my public enemy gets his weights on front axle.
It had been a long time that he deserved it
Now, it's done
I used tungsten slugs, 4 by wheel
I milled 3mm CF with pockets to insert slugs and have 6mm left for delrin support
to be sure that it never touches spacers, I've milled flat spacers in 7075 alu, 2mm thickness
I'm really happy because it just missed this to be perfect
Old 03-06-2017, 08:43 AM   #92
Hi!
Those are the last sessions
Old 12-10-2017, 11:36 AM   #93
Hi!
Some news
For 2017 season, the rig has got the final version with good CF (exit the prototyping CF, ugly and bad quality) and a new color for the 3D part
1/2 bio hasard rims in 2mm are a little bit light. they were changed by a new version in 4mm, stronger, and nicer too
I build Dlux style knuckle with alu weight holders, that gives ~40g more than the VP on each wheel, 100g in total with tungsten slugs
You can see brass inserts in the hub.
they begin to be old and after lot of unmountings/mounting, screws's threads are tired.
This is a good solution to keep them
I add 4mm alu spacers to enlarge the front axle and get more steering (tires can turn more without touch the lower links)
A friend drew and offered me 3D cover guards to protect my pullers, a really cool gift
If you want to print it, you can find the STL file here (for puller 400)
it's free
https://www.thingiverse.com/tgenial/designs
this year was poor in comps for me but I invested for the next years with the building of my margo , a super and a mini to make profitable the trips
The mini will be finished soon
Old 01-26-2018, 05:27 AM   #94
You make cool staff dude
BTW, do you have a construction thread of your superclass?
gonper is offline   Reply With Quote
Old 01-26-2018, 12:27 PM   #95
thank you
Not yet,but it should arrive soon
Old 01-26-2018, 02:19 PM   #96
nice rig,
great parts those you made!
congratulations
skypyt is offline   Reply With Quote
Old 05-16-2018, 04:20 AM   #97
Default Re: Public enemy
Hi!
Here is the last training session with the public enemy
And the throttle potentiometer finished to die after the first lipo
A bunch of new potentiometers arrive soon (the steering should die soon, I suppose)
A new BERG Tracer V3 - Similar Threads
My new Berg Tracer 2.2 Grump EnRoute Berg 28 11-06-2013 07:29 AM
new berg tracer v3 jaxandjokers EnRoute Berg 11 02-27-2013 01:23 AM
Berg 2.2 vs tracer ? NullMind EnRoute Berg 5 05-05-2011 03:13 AM
Berg Tracer 2.2 gon4lo EnRoute Berg 9 12-10-2009 09:18 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
