07-07-2017, 09:42 PM | #261 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: 5Th Dimension Mark ll Chassis Swap to Dominator. |
07-08-2017, 07:32 PM | #262 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
| Re: 5Th Dimension Mark ll Chassis Swap. |
07-08-2017, 07:55 PM | #263 |
Pebble Pounder Join Date: May 2015 Location: The Rocky maintains
Are those CCD tubes on your old axles?
07-08-2017, 08:08 PM | #264 |
07-08-2017, 08:09 PM | #265 |
07-12-2017, 08:48 PM | #266 |
Rock Crawler Join Date: Jul 2013 Location: california
Tapped out, What parts did you get on your superlites? What width hubs are you running? |
07-12-2017, 08:54 PM | #267 |
07-12-2017, 08:58 PM | #268 |
Here's a pic of parts I received. My rear hubs are equal to slw 475. Sent from my SM-J320V using Tapatalk Last edited by tapped-out; 07-12-2017 at 09:00 PM. |
08-01-2017, 04:33 PM | #269 |
I'm going to try and make myself a few add-on knuckle weights for my Dlux brass knuckles. I need to make them the fit the ID of Ytown wheels.. I'm shooting for 2.1" looks like I need to buy a few new hacksaw blades to attempt to cut them out. I've never cut brass before so I hope a hacksaw blades will do the job. The brass drilled easy enough. Sent from my SM-J320V using Tapatalk |
08-01-2017, 04:47 PM | #270 |
Rock Crawler Join Date: Dec 2010 Location: Ct.
If you have a jigsaw, pick up a fine tooth metal blade. It will save you a lot of time and aggravation. You can cut them close then file them up nicely.
08-01-2017, 05:19 PM | #271 |
Thanks. I do believe my wife owes me a new jig saw.. mine died cutting plywood for her... |
08-01-2017, 05:24 PM | #272 |
08-03-2017, 09:59 PM | #273 |
RCC Addict Join Date: Jul 2008 Location: San Diego
How thick is the brass?
08-03-2017, 10:47 PM | #274 |
1/4"thick.
08-07-2017, 09:45 AM | #275 |
I've had a sloppy Hitec 7950th servo for at least a yr I thought it was because of worn out bushings. I decided to open it and found that the center plastic case (sits on top of alum heatsink and under the gears) was broken where the lower main output gear bearing sits. I thought all yr it was sloppy bushings. Should be an easy fix $10.00 shipped from tower hobbies for new servo case. Just thought I'd share because when I searched 7950th servo slop.. I wasn't finding much about the subject. Sent from my SM-J320V using Tapatalk |
08-07-2017, 07:37 PM | #276 |
Yup got the same on mine after much use. Does yours wiggle a little when sitting still like its trying to find center? I know the hum at neutral is from it being digital but Im assuming its a sign of life coming to its end lol.
08-07-2017, 07:40 PM | #277 |
I had no other issues with my servo other left to right slop. My servo is 4-5 yrs old too. My rig has been close to a 5 pounder for most of that time also. Last edited by tapped-out; 08-07-2017 at 07:45 PM. |
08-09-2017, 02:49 AM | #278 |
08-27-2017, 12:00 PM | #279 |
08-27-2017, 03:43 PM | #280 |
Finished up my homemade knuckle weights. I drilled them and had a friend of mine rough cut them out. After cleaning them up a bit each weight is 2oz. Sent from my SM-J320V using Tapatalk |
5Th Dimension Mark ll Chassis Swap. - Similar Threads | ||||
Tapped-out's 5th Dimension Sucker Punch | tapped-out | Axial AX-10 Scorpion | 109 | 08-11-2015 03:17 PM |
5TH Dimension Minimal berg rebuild | tapped-out | EnRoute Berg | 70 | 10-01-2013 02:40 AM |
Tapped-out's 5th Dimension Sucker Punch | tapped-out | Videos! | 0 | 08-11-2013 01:37 PM |
