10-30-2015, 01:35 PM | #81 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: 5Th Dimension Mark ll Chassis Swap. |
10-31-2015, 07:33 PM | #82 |
11-08-2015, 03:24 PM | #83 |
Quarry Creeper Join Date: Jul 2008 Location: Hesperia ca.
Nice axles Mathew.
11-09-2015, 05:22 PM | #84 |
Video's from Rumble On The Rocks in ceader city UT. this weekend. this comp was a blast thanks to Erik & everyone that helped out Do to the placement of my gopro the view of my rig gets blocked.. |
11-10-2015, 08:46 AM | #85 |
Thanks for the videos!
12-06-2015, 06:08 PM | #86 |
I've been looking for a set of CCD Berg tubes for awhile, I finally found a set. Thanks to Cboggs, thanks Chris. Swapped out the tubes in the process I managed to bust my titanium tie-rod. The Delrin Tie-rod will be replaced by a D-lux titanium tie-rod and drag link. They should be here Thursday just in time for a double comp day with BLC & BYB clubs at Horsemans Park apple valley ca. This Saturday . |
12-07-2015, 09:22 AM | #87 |
12-07-2015, 09:42 AM | #88 |
12-07-2015, 01:49 PM | #89 |
Rock Crawler Join Date: May 2009 Location: Calgary
12-07-2015, 02:05 PM | #90 | |
| Re: 5Th Dimension Mark ll Chassis Swap. Quote:
I think its just USPS website not updating? I have a couple of packages I am waiting on and they have not moved since the 6th either... I could be wrong. Funny part is that I feel guilty for shipping the next day. I really like to ship the same day if possible. I know what its like waiting for toys in the mail! | |
12-17-2015, 10:51 AM | #91 |
I've noticed my rigs rear wheel seems to lift a lot.. in different situations in video below are three examples @ 3:32 and 5:02 and 5:44 Any ideas how to stop this from happening? Easy enough to correct with driving most of the time. One suggestion was to space rear upper shocks out more on chassis. Not really wanting to make shocks stick out anymore looking for other ideas. https://youtu.be/iPrwGm1konk Last edited by tapped-out; 12-17-2015 at 10:56 AM. |
12-17-2015, 11:22 AM | #92 |
Not too sure what to say Mr. Out. I will keep an eye on my truck to see if it is doing the same thing. What shock oil are you running? Springs? Can you post an updated side angle photo? Good driving BTW. What a talented field to have to compete against. |
12-17-2015, 11:36 AM | #93 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
Has it always done that or just recently? My sporty used to do that until I spaced out the rear upper links at the axle. I've never have had the pro lift a tire like that and its not spaced out, not sure what you got going on there to cause it.
12-17-2015, 11:48 AM | #94 |
My XR was doing that for a while, felt stiff and wouldn't let the dog leg down unless I worked the front dig. I did space the links at the axle a bit more and it helped but big change was raising the links at the chassis one hole helped too. |
12-17-2015, 11:56 AM | #95 | ||
Might try spacing upper links @ the axle for next comp... | ||
12-17-2015, 12:07 PM | #96 |
RCC Addict Join Date: May 2012 Location: Folsom
12-17-2015, 01:15 PM | #97 |
| Re: 5Th Dimension Mark ll Chassis Swap. Where are your links @ on chassis top hole or ? Mine is 1 hole down from top... so I could rise my rear links up 1 hole..
12-17-2015, 01:46 PM | #98 |
12-17-2015, 09:52 PM | #99 |
| Re: 5Th Dimension Mark ll Chassis Swap. Last edited by tapped-out; 12-17-2015 at 09:54 PM. |
12-18-2015, 08:13 AM | #100 |
I've noticed from pictures of other rigs, my rear axle is clocked up kinda high. Maybe this is part of the issue? So besides the 2mm spacers I've twisted my rodends in a hair to bring front of axle down a bit.. hopefully I'll be able to test before next comp. |
5Th Dimension Mark ll Chassis Swap. - Similar Threads | ||||
Tapped-out's 5th Dimension Sucker Punch | tapped-out | Axial AX-10 Scorpion | 109 | 08-11-2015 03:17 PM |
5TH Dimension Minimal berg rebuild | tapped-out | EnRoute Berg | 70 | 10-01-2013 02:40 AM |
Tapped-out's 5th Dimension Sucker Punch | tapped-out | Videos! | 0 | 08-11-2013 01:37 PM |
