12-18-2015, 09:39 AM | #101 |
Rock Crawler Join Date: May 2009 Location: Calgary
| Re: 5Th Dimension Mark ll Chassis Swap.
I am running my rear uppers one hole lower than you right now and I can't remember this happening. I'll keep an eye out for it and report back. FYI - Your rear clocking doesn't look too extreme. |
12-18-2015, 09:42 AM | #102 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: 5Th Dimension Mark ll Chassis Swap. |
12-18-2015, 12:10 PM | #103 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
| Re: 5Th Dimension Mark ll Chassis Swap. Same here, one hole lower on the rear uppers at the chassis and all the way up on the axle.
12-31-2015, 07:21 PM | #104 |
I have checked and I don't seem to be having the same issue. I am running Dlux super lites so my upper links have zero separation at the axle. This chassis sure is awesome though. |
12-31-2015, 08:05 PM | #105 | |
| Re: 5Th Dimension Mark ll Chassis Swap. Quote:
Can you post a pic? My thoughts are: your shocks might be wider on the axle? Or spaced further off your chassis? @ Tapped.. Will your shocks mount on the outside of your shock/link mounts? Just to see if that helps. | |
12-31-2015, 08:39 PM | #106 |
| Re: 5Th Dimension Mark ll Chassis Swap. I'll look to see.. yes I can but will try this after next comp, if the adjustments I've made haven't fixed the the issue.
12-31-2015, 08:43 PM | #107 |
About the lifting problem ... Can you space the rear uppers out just a little more at the chassis? That solved the same problem i had with aT1e chassis once.
12-31-2015, 08:55 PM | #108 |
12-31-2015, 11:04 PM | #109 |
Spaced shocks out at chassis & spaced upper rear links at axle. I'll post up if this help/stops rear tire lifting after our next comp. Last edited by tapped-out; 12-31-2015 at 11:07 PM. |
01-09-2016, 07:40 PM | #110 |
01-10-2016, 01:54 PM | #111 |
I placed 2nd place @ BLC comp #4 Ramona ca, always a blast comping with some really great guys.. already looking forward to next months comp... more videos posted in video section on rcc & my YouTube channel soon. Last edited by tapped-out; 01-10-2016 at 08:10 PM. |
01-11-2016, 09:30 PM | #112 |
few more videos. |
01-27-2016, 11:20 AM | #113 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
Rig looks great bro. I'll have feedback on the pins you gave me at worlds very soon. Smart, calm driving. My practice this spring is going to be working on seeing the big picture. I saw a lot of that in the vids.
01-27-2016, 11:40 AM | #114 |
01-27-2016, 11:52 AM | #115 |
| Re: 5Th Dimension Mark ll Chassis Swap to Dominator.
I can always count on you J Sent from my iPhone using Tapatalk |
01-27-2016, 12:01 PM | #116 |
I do what I can buddy. |
01-30-2016, 09:45 AM | #117 | |
Thanks for the kind words, staying calm with the timer counter counting down is really hard sometimes but a must to finish the course many times @ gate 10 with seconds left I've choked and not finished the course. Good luck digging out of the 3' of snow to practice, it's been 4yrs since I've had that much snow | |
01-31-2016, 07:38 AM | #118 |
01-31-2016, 08:58 AM | #119 |
First of all, you guys know I'm a rock star. That face was simply a normal reaction to learning there wouldn't be a 4seasons At the next comp Sent from my iPhone using Tapatalk Last edited by Crawllife; 01-31-2016 at 09:10 AM. |
01-31-2016, 09:00 AM | #120 |
And yes. Rowdy should return. We shared no sponsors and he was always down to help me. Stand up dude. You get a lot less crap when he's spottinglot compared to getting screamed at by winner! Thanks captain patients Sent from my iPhone using Tapatalk Last edited by Crawllife; 01-31-2016 at 09:12 AM. |
5Th Dimension Mark ll Chassis Swap. - Similar Threads | ||||
Tapped-out's 5th Dimension Sucker Punch | tapped-out | Axial AX-10 Scorpion | 109 | 08-11-2015 03:17 PM |
5TH Dimension Minimal berg rebuild | tapped-out | EnRoute Berg | 70 | 10-01-2013 02:40 AM |
Tapped-out's 5th Dimension Sucker Punch | tapped-out | Videos! | 0 | 08-11-2013 01:37 PM |
