06-05-2014, 12:20 PM | #61 |
| Re: Dravpnir tries to build something even lighter
Great stuff going on in here. Keep up the good work Tobias |
06-06-2014, 02:46 AM | #62 | |
DravTech Join Date: Aug 2012 Location: Sweden
| Re: Dravpnir tries to build something even lighter Quote:
Now I am waiting on parts so I can make the axle tubes. Hopefully I will get them next week. Then it is time to start working on the servo placement. I have a couple of ideas how to place it, but regardless the servo mount will be combined with one of the axle tube flanges. It is really funny to design parts the way you want and not have to worry if I can make it in my mill or not. Edit: Axle tube parts has been shipped and will be here on tuesday Last edited by Dravpnir; 06-06-2014 at 01:40 PM. | |
06-08-2014, 02:05 PM | #63 |
Got a wheel design idea today and just had to draw it up. If the volume calculations from Shapeways is correct each wheel will weight about 5.5 g in their strong and flexible nylon material.. if it holds up it will be awesome The spokes are 2 mm in diameter and the wheel is 0.8" wide. Of course it is made for SLW style hubs. |
06-08-2014, 04:41 PM | #64 | |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
Later, Farmer | |
06-09-2014, 03:30 PM | #65 | |
While I wait on the parts for the axle tubes I made some 7075 aluminum tubes for the front axle tubes. In the rear I will use the thinner titanium tubes. First time I worked with 7075 Al and is was really nice | |
06-09-2014, 10:34 PM | #66 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
I LOVE them. While i prefer bead locks for foam tuning, I'd be in on these!! Very very cool!!! Plus I'm sick of drooling over your parts on the screen. I've got to get some on my rigs. Great job as usual.
06-10-2014, 01:35 AM | #67 | |
But, if all goes like I hope, the wheels will not be the only part you can get for a 2.2Pro rig If someone has some wheel design they would like to be realised I always enjoy a modelling challenge | |
06-10-2014, 08:31 AM | #68 |
I'm looking forward to seeing what happens bud. Have a great day!
06-10-2014, 11:08 AM | #69 | |
Rock Crawler Join Date: Jan 2011 Location: Portugal
Just messing with you... Love your work! I'm finding that 3d printing makes the design part more challenging because of what you can do wit it! (And thanks to let me know about shapeways!) | |
06-10-2014, 03:39 PM | #70 | ||
Never thought about a wooden wheel. Now I am almost sad that Shapeways do not offer brown color I find 3D printing a relief! Finally your imagination is not hindered by what was machinable or not. I did some small modifications on middle section of the gear boxes. First, I increased the thickness where it will have most contact with the rocks. 1 mm less ground clearance, but a much tougher part. I also changed the design so the increased area also cover the sides of the G10 plates where they are as most exposed to the rocks. I also added some commercial bling bling | ||
06-10-2014, 04:48 PM | #71 |
Let me know I'm sure I can put them to the test, wouldn't mind changing up my cases in the near future also Later, Farmer |
06-10-2014, 11:27 PM | #72 |
It's great to see all the " berg-ish" stuff coming out after having to read " berg is dead " in xr threads in my first year. I hope this trend continues! I do have some wheel design ideas I will PM you. I have some sketches laying around from a deal that fell through with a machinist. Could you just do faces so Dlux bead channels can be used? For me, it's still the best wheel system IMO. Perhaps once I've nailed foam tuning for all the tires, the glue ons won't bother me so much |
06-11-2014, 12:24 AM | #73 | ||
Send me a PM and we will see what will crawl out in the end. I have no machining capabilites regarding CF or G10, but I bet Dlux or some other vendor can step in in that case. | ||
06-11-2014, 03:52 PM | #74 | |
06-18-2014, 01:10 PM | #75 |
Started a little side project to these axles... you cannot have to many projects, right It is not a Berg, but do not know where to place it so it will parasite on this thread. I really like the NCD RC4WD transmission for the shafty, so why not use the same gears for a Berg-ish kind of gear box? The final gear requires some work to be useful but I think I got the rear one figured out today. The gear boxes will be really compact and by using a 6 or 7T pinion the gear ratio is around the same as a stock Berg. Last edited by Dravpnir; 06-18-2014 at 01:12 PM. |
06-18-2014, 01:18 PM | #76 | |
06-22-2014, 02:00 PM | #77 |
Been modeling some rear gear box for the RC4WD R2 gears. I am thinking of one part in printed nylon and one CF plate. I got some more work to do. I think I atleast have to reinforce the bearing pockets among other things. Of course I now realised that my spool will not work... but I got a new solution. Lathe time after work tomorrow The printed side have the axle tube flange as a part of the gear box. For the CF side I will make a separate one of printed nylon or lathe aluminum. To give a hint of how compact this gear box is I added a cylinder in the size of a "normal" 540 motor (36 mm diameter and 50 mm long). |
06-22-2014, 02:05 PM | #78 |
Are the r2 gears redesigned? A lot of us had problems with them when they first came out. Edit: I guess rigs were a lot heavier back then too. |
06-22-2014, 02:33 PM | #79 |
Rock Crawler Join Date: Jul 2012 Location: Long Island, NY
What about pinning the joints on those carbon/aluminum axle shafts to help keep the one from spinning in the other.
06-22-2014, 06:01 PM | #80 |
On the box how can you adjust the pinion? Is there something missing? What program do you use for those models? |
Dravpnir tries to build something even lighter - Similar Threads | ||||
Dravpnir tries to build something light | Dravpnir | EnRoute Berg | 125 | 04-23-2014 06:01 AM |
new lighter weight build | evan03 | 2.2 Scale Rigs | 1 | 10-23-2013 06:44 AM |
On a lighter note.... | F250 | Chit Chat | 3 | 02-20-2008 05:29 PM |
which is lighter | ballercrawler | General Crawlers | 2 | 08-02-2006 10:14 AM |
