06-23-2014, 04:41 AM | #81 | |||
DravTech Join Date: Aug 2012 Location: Sweden
| Re: Dravpnir tries to build something even lighter Quote:
One of the motor screws is fixed and you use the other screw to tilt the motor so you can use different pinions. I use Autocad Fusion 360 to make the models. | |||
07-02-2014, 02:36 PM | #82 |
Some progress Front and rear axle bolted together and I have started to determine the length on the titanium tubes for the rear axle and the 7075 aluminum tubes for the front axle. Front axle with Dlux Axial style drive shafts, RCBros locker and light weight 4th gear, the rest of the gears are stock lightened Berg V3 gears. Rear axle with all lightened Berg V3 gears and my aluminum/carbon fibre rear drive shaft. I am quite satisfied with the weight of the axles. The rear misses some bushings in the end of the axle tubes and the front lacks a servo mount. Then I also started to put toghether some matching shocks, thanks RCBros for releasing the white shock body Lessons learnt: * Choose the polished white printed material... the rough white one capture dirt miles away... * Gotta make the axle tube flanges a bitt beefier as I think the ones in the picture will be a bit too much on the risky side. |
07-02-2014, 05:31 PM | #83 |
Rock Crawler Join Date: May 2008 Location: The Beautiful South
how much for sale?
07-02-2014, 06:46 PM | #84 |
Rock Crawler Join Date: Jan 2011 Location: Portugal
That's just another level...
07-02-2014, 07:14 PM | #85 | |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
Later, Farmer | |
07-02-2014, 09:43 PM | #86 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Looking good!
07-03-2014, 01:38 AM | #87 | |
| Re: Dravpnir tries to build something even lighter First some other questions have to be answered, will it hold up, do the design work, etc... but if it end up somewhat near like the axles in the pictures the price would be very affordable. Thanks, 3D printing is really really nice! Quote:
If I start to offer them, then I would like the sides and tubes to be in woven CF and the printed parts in either, black, red, blue, green, yellow, purple, pink, orange, white or a mix of these colors. So, a blacked out version will be possible Also, if, or when I offer the axles I will also be able to offer some other part for the axles that is really awesome and color matched to these axles Thanks | |
07-14-2014, 07:50 AM | #88 |
Great work as usual...looking forward to seeing them under a rig. As far as the tube flanges go...you won't know if they need to be "beefier" unless you try them... |
08-03-2014, 02:58 PM | #89 | |
Of course I will try out the tube flanges. I want to get some use for what they cost me But now it is time to start making the chassis, and complete the axles ofc... Btw, your old nicely decolored AX10 chubs will probably end up on this rig. The black plastic chubs is perhaps a bit lighter bit the silver ones looks so much better. | |
Dravpnir tries to build something even lighter - Similar Threads | ||||
Dravpnir tries to build something light | Dravpnir | EnRoute Berg | 125 | 04-23-2014 06:01 AM |
new lighter weight build | evan03 | 2.2 Scale Rigs | 1 | 10-23-2013 06:44 AM |
On a lighter note.... | F250 | Chit Chat | 3 | 02-20-2008 05:29 PM |
which is lighter | ballercrawler | General Crawlers | 2 | 08-02-2006 10:14 AM |
