01-22-2014, 07:52 PM | #1 |
Newbie Join Date: Oct 2012 Location: akron
| pinion
Ok here I go proably ding ? What pinion for motor do I need I switched from Xr to berg axles
01-22-2014, 09:15 PM | #2 |
RCC Addict Join Date: May 2012 Location: Folsom
| Re: pinion
metric pinions steel Robinson Racing makes them part number RRP11** the *'s equal the number tooth you want to run. I for example run a 13 tooth RRP1113 |
01-22-2014, 10:27 PM | #3 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
| Re: pinion
I also run the 13t from Robinson. Careful if you space issues in your gear case. The Robinson pinions vary in physical size. I was surprised at how much bigger the 13 was from 12
01-22-2014, 10:49 PM | #4 |
Quarry Creeper Join Date: Jul 2009 Location: Woodburn, Oregon
I run a 13T
01-22-2014, 11:02 PM | #5 |
Quarry Creeper Join Date: Jun 2009 Location: Way down under!!!
| Re: pinion
Pinion class is Mod 0.5. Not as easy to find as you'd think. I am running a 16T in the rear and 14T up front from some involuntary over/under drive. |
01-22-2014, 11:27 PM | #6 |
Newbie Join Date: Sep 2013 Location: italy
| Re: pinion
mod 0.6 berg
01-23-2014, 04:52 AM | #7 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
| Re: pinion |
pinion - Similar Threads | ||||
Helical ring and pinion gears sets with an offset pinion? | Calderwood | General Crawlers | 6 | 09-14-2013 09:06 PM |
65:1 Pinion | JeremyH | RC4WD Bully | 5 | 06-02-2010 08:10 PM |
what pinion? | dodge44 | Newbie General | 0 | 02-03-2010 11:03 AM |
55T 20 pinion or 45T 14 pinion | GP40X | Electronics | 0 | 11-10-2009 10:46 PM |
8t pinion ?? | BrockGrimes | Newbie General | 6 | 03-02-2006 01:41 AM |
