03-11-2014, 09:25 AM | #21 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: Crawllifes Mark2 build He could wire the BEC, straight to the servo or to the receiver either way with how its wired up now.( depending on the voltage of his bec). My bet is he will wire directly to the servo, ESC will power the receiver and the motors.
03-11-2014, 06:29 PM | #22 |
Rock Crawler Join Date: May 2008 Location: The Beautiful South
| Re: Crawllifes Mark2 build no, I meant it looks like he has the bec wired into the output of the esc, not the battery side. That would give power only when power goes to the wheels.
03-11-2014, 06:44 PM | #23 | |
| Re: Crawllifes Mark2 build Quote:
An easier giveaway is that the capacitors on the BR Mini's is located on the battery side of the PCB, and as you can see, all the capacitors are on the side to which the BEC is wired to. Last edited by TSK; 03-12-2014 at 12:13 AM. | |
03-11-2014, 11:19 PM | #24 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
Thanks for jumping in tapped-out and Trav. My boys are right. Chris wires my smashes the same way every time. The reason I stick with creation fab is because of the education he freely gave when I was VERY new to this stuff. He made it simple to understand. How many times are you jammed up or needing to " servo wiggke" yourself into a better line or slot. We'd be sol if your servo didn't give full power in those moments. Chris knows how picky I am and stacks my stuff a certain way. Sorry if my pick confused you and please don't let it deter you from asking other questions bro. I'll check into my threads more frequently.
03-12-2014, 03:10 PM | #25 | |
03-12-2014, 08:10 PM | #26 | |
When you get her running, take some temps of the esc as Matt seems to want al the temp data he can get on the BR Mini setuip | |
03-12-2014, 11:06 PM | #27 |
| Re: Crawllifes Mark2 build Lmao..... but he's right I would like to know your average running temps and esc settings. |
03-13-2014, 01:02 AM | #28 |
I certainly will and thanks for giving my " bridge thingy" the appropriate name.
03-13-2014, 02:10 AM | #29 |
| Re: Crawllifes Mark2 build |
03-13-2014, 07:51 AM | #30 |
I cant wait to see this car together. LOL
03-13-2014, 08:46 PM | #31 |
03-13-2014, 10:23 PM | #32 |
03-14-2014, 11:23 PM | #33 |
Rock Crawler Join Date: Jul 2007 Location: central PA
KILLER build thread man. cant wait to see this one and comp with you again soon!
03-15-2014, 01:44 AM | #34 |
03-22-2014, 11:10 PM | #35 |
| I thought I owed Will a better shot of these gears. They are art. Sent from my iPhone using Tapatalk |
03-22-2014, 11:12 PM | #36 |
| 2 mini brxl's with a castle bec. Controlling the 30t vapor's from brood. They are type " R"'s. Sent from my iPhone using Tapatalk |
03-22-2014, 11:18 PM | #37 |
| A lot of little stuff done to rig the last week. Erik D was of course a huge part of the progress. New uppers, inserts in the delrin hubs, a change in the revers cap end mod ( made them too short for the desired affect/ performance or the rig), raised the side plates up a notch to drop the skid a 1/4 of an inch and improve the lower link lines and a bit of inspiration from my friend at BC paints with mocking up the mini beetle Sent from my iPhone using Tapatalk |
03-22-2014, 11:54 PM | #38 |
Looks good, which bug is that? Looks like sitting it back with the right trim can get that guy slammed.
03-23-2014, 11:31 AM | #39 |
Looks good! The idea of this chassis being able to drop the belly like it does is intriguing to me. It confuses me and makes total sense at the same time. Good thinking 5th D! |
03-25-2014, 12:05 AM | #40 |
| Re: Crawllifes Mark2 build That is one of the last mrc, proline beetles I have before I start hunting again. It's far from cut all the way. Sporty lid first, than this will have the paint drying on the way to Sundays comp.
Crawllifes Mark2 build - Similar Threads | ||||
Tamiya CC-01 Landfreeder Build Thread (Build Complete) | TheBlueKnight | Tamiya XC/CC01 | 29 | 11-24-2014 11:21 AM |
Tamiya Bronco Kit Build; 1st Build | Boxcarcustoms | 1.9 Scale Rigs | 2 | 07-29-2013 07:37 PM |
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
RcBros LCC Build, Hi-Res pics & More Build!! | RcBro | Team Losi Comp Crawler | 30 | 06-03-2009 07:26 PM |
