03-15-2014, 09:58 PM | #21 | |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: The U help me pick build thread Quote:
03-18-2014, 02:26 PM | #22 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
| Re: The U help me pick build thread |
03-18-2014, 04:52 PM | #23 | |
| Quote: T1e is owned by Rockpayne now and last I talked to him he was having some issues with the machine to make parts... Sent from my iPhone using Tapatalk | |
03-18-2014, 06:04 PM | #24 | |
Pebble Pounder Join Date: Feb 2014 Location: The other Vancouver
Thanks Tom, So it is not T1E. Not quite the same in Orange and without body panels. I guess I like the lower slung fastback look over the tall boxy look. I just cannot decide what to go with. Of course I want whatever I get to perform great but I also want it to look good as well. The things that appeal to me seem to be the hardest to get. My choices are below unless I missed something. NCD sudu RCbros YTC Double Dlux Classi, Either one Classi and Dlux both offer links for their chassis but for the other ones I would have to figure it out. Quote:
Ok it is time to start making decisions and get ordering I am going to get Dlux knuckles for sure but I need help to choose how to order them. I was thinking maybe Delrin or AL on top and brass on the bottom with slug holes plus lower brass half circle weights. I think that combo would give the most adjustability. Empty with no slugs would be fairly light and then I could add brass or tungsten slugs to first the lower half then the upper half and then lower brass rings. It would also keep the weight down low Opinions needed I also need to figure out what CVD's I will be using. I want the 70 degree steering if possible and want strength and durability are important as well. Are the OFNA ones the kind that use the pinned on hubs? Can I use that kind ? If not what kind of steering angle/strength would I get from the XR/Wraith stub choice? I am planning on using RCbros tubes and I am not sure what Dlux stuff will play nice with RCbro stuff. Help Pleeeeease Last edited by THX_138; 03-22-2014 at 01:30 PM. | |
03-19-2014, 10:01 AM | #25 |
Quarry Creeper Join Date: Jul 2009 Location: Woodburn, Oregon
Spend some time talking with Dlux he will make sure you're taken care of. I use the Dlux shafts with the RcBro tubes. I did have to grind down the shafts a little to fit in the tube.
03-19-2014, 11:00 AM | #26 |
| Re: The U help me pick build thread So you have his AL rear tubes with his Delrin hubs in back? What are you running for CVD's/hubs up front? You may have told me on Sunday but we were covering a lot of topics in a short time |
03-19-2014, 11:50 AM | #27 |
| Re: The U help me pick build thread I only use the Dlux shaft in the front and creeper bob ti shaft in the rear. Up front im using Vp hubs but most guys use the shift hubs and if i was buying new i would get the shift hubs. Up front i use the axail stub but Dlux is a big fan of bully stubs because they are stonger and beefer. With a u-joint front shaft you go get a lot more steering but they are not as smooth roating as a CVD. Tom uses a CVD on his Xr and a u-joint on his sportman. Tom has never lost because his CVD didnt turn enough.
03-22-2014, 01:01 PM | #28 |
So I spent all week reading, PMing and learning to figure out what to do. This is a tough hobby to get started or restarted in. I finally settled on a chassis. I ordered a YTC Double Agent. I like the low slug look, its proven and I can get my hands on one quickly. It also helps me spread the love with vendors and will keep my final build parts list unique. When I build or upgrade a mountain bike I don't buy a complete bike or use complete groups of parts I use many companies products and it turns out pretty cool. Now I need to get all of the other parts going. I wanted to use RCbros tubes but they present some challenges. I am going to use Erik's front universals and I am debating on the rears as well but that means modifying both front and rear tubes as well as the non 8 degree chubs so they will play together. It also leaves me in a case crunch. I am staying away from Classi which leaves me with the plastic M/Ts or stock berg cases and while either would work they are not what I was hoping for. The only other way is to just go with Erik's complete axles which would be much easier but would leave a few vendors I was going to use out of the mix. Thoughts anyone...... |
03-22-2014, 05:33 PM | #29 |
Pebble Pounder Join Date: Oct 2009 Location: underground
My OPINION is if your using rc bros tubes they look great polished up with stock shaved cases.My axles are dlux,classic cut customs and rc bros using non 8 with the option of 8 and I couldnt be happier good luck with your decisions
03-24-2014, 12:30 PM | #30 |
Ok everyone the ordering has begun! After much deliberation I decided to get everything chassis down from Mr Dlux. It was going to take to long and going to be to difficult doing things any other way. This choice will have me driving by the end of April instead of June I ordered, His complete bad boy axles with Ofna stubs, RCbro gears and SDS 2nd and 3rd's as well as brass inserts for the hubs. His V2 knuckles solid brass with slug holes and 16mm bearings along with a couple of thick and thin brass rings. Lathed and modded Big Bores with springs. A complete set of links with sliders for the D/A. The D/A chassis is coming with the AL braces and their fancy skid as well. I am still working on motors and electronics. Last edited by Session; 03-25-2014 at 05:11 PM. |
03-24-2014, 02:55 PM | #31 |
You're going to be very happy with what you got. Look forward to seeing you out on the rocks.
03-24-2014, 03:17 PM | #32 |
Rock Crawler Join Date: Mar 2008 Location: Not painting
| Re: The U help me pick build thread Great chassis choice
03-24-2014, 03:22 PM | #33 | |
Slight update. My credit card is getting warmer by the minute! 2 13t 500 Pullers and a BR mini dual from HH are ordered. CCbec and castle link on the way from Amazon. Now I need a set of tires to use until EY can get me some narrowed Voodoos. He says June I am going to order these (see pic below) from Tomi when he gets back to use with the Voodoos but TCS has a good deal on Rovers and some SLW's that might make a good alternate set. Thoughts anyone? | |
03-25-2014, 12:59 PM | #34 |
Just buy some Voodoo's and cut-n-shut them yourself. Order them today and you'll have them in a few days...instead of a few months |
03-25-2014, 01:07 PM | #35 |
RCC Addict Join Date: May 2012 Location: Folsom
Why narrow the tire at all? Guys round here are using full width voodoos with alot of sucess. Silver compound. All around.
03-25-2014, 01:36 PM | #36 | |
I have been thinking about doing that not the cutting but buying a uncut set direct. I hope your tires come with a bag of chips...... Last edited by Session; 03-25-2014 at 05:13 PM. | |
03-25-2014, 05:53 PM | #37 |
Chips? No. But they have been known to come with state, national, and international trophies |
03-25-2014, 06:55 PM | #38 | |
And yea know, for $80.00 a set would it kill you to throw in a bag of chips? I like chips | |
03-25-2014, 07:25 PM | #39 |
haha, I knew exactly what you were getting at |
03-25-2014, 07:39 PM | #40 |
I wanna be Dave Join Date: Aug 2008 Location: Having fun again...
keep an eye out in the for sale section... a set might just pop up soon |
Sessions YTC Dlux berg build - Similar Threads | ||||
Dual Dingo build thread-My first build thread | juswin24 | Axial SCX-10 | 205 | 09-19-2013 12:42 PM |
Pick-Up Build-Off | minifaron | 1.9 Scale Rigs | 0 | 11-15-2009 09:22 AM |
1.9 Scale Pick Up Build off! | minifaron | New Mexico | 5 | 11-15-2009 09:14 AM |
Which Truck Should I Pick To Build | Ben's Madness | Newbie General | 15 | 07-13-2009 05:13 PM |
Yep'er Another Merc build, Pick up that is... | tjb | 1.9 Scale Rigs | 116 | 09-09-2008 03:52 AM |
