03-27-2014, 12:46 PM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: Cullman
| Berg axle thickness
I have an extra set of V1 tubes, I was going to get them milled down to save weight. My question is, how much can you take off one so that the tubes aren't too thin.
03-27-2014, 01:21 PM | #2 |
Rock Crawler Join Date: Dec 2008 Location: Displacement
| Re: Berg axle thickness
The id is roughly 8mm. I've taken them down to 11mm od without any issues, it may be a bit thin for fronts on a plus sized rig. 12mm for fronts is a good safe diameter. For rears, I've taken plenty to 11mm with no issues and one set down to 10mm but that was for a sub 4lb truck. |
03-27-2014, 02:08 PM | #3 |
RCC Addict Join Date: May 2012 Location: Folsom
^ he lives! Easy E in the house!
03-28-2014, 07:20 AM | #4 |
I am right at the mid 4lb rtr weight. I thought I had a spare set laying around but couldn't find them. Would I be better off to try to mill these down or buy a set of delrin or aluminum tubes?
03-28-2014, 10:54 AM | #5 |
That can only be decided by you really. Things to consider: -Access to machinery -Value of your time -Do you like building/modding your own parts -and so on All the tubes offered by the other vendors here are nice products. You can't really go wrong either way. |
03-28-2014, 01:20 PM | #6 |
I just got into the MOAs about two months ago when I traded for one. Now im addicted. Here is the current list of what it has. Trying to decide the next upgrades. Stuck between tubes, gear cases or a few other odd and ends. Dlux chassis and links V1 bergs with vp knuckles with 4mm mod 86jeep style steering fubar rear lockouts super 300's Smashed HH dual ESCs HH 35t hw's Hitec 7950 Castle bec Traxxas bb's Y-Town CF 3 piece wheels with CI double deuce foams and shaved rovers |
Berg axle thickness - Similar Threads | ||||
RC Axle Master Berg Rear Straight Axle Kits | LetsHandleit | Axles, Trannys, T-case | 150 | 08-14-2012 10:44 AM |
axle thickness | Redfinger | EnRoute Berg | 5 | 02-17-2010 11:48 PM |
RC Axle Master HR and Berg Straight Axle Kits IN STOCK | RPP Hobby | RPP Hobby | 1 | 11-01-2009 06:45 PM |
