09-04-2014, 10:12 AM | #1 |
| ♣♣New♣♣ DLUX REPLACEMENT gear cases Setup information: Bearings on the motor plate: All flanged The 4th and 3rd gears have the flange on the outside of the case, obviously the flange will be in the inside on the aluminum puck holding the 2nd gear bearing. Bearings on the non motor side: All NON flanged The locker bearings will kinda "float" and not be held in by anything. This is what I am assuming 95% of people are doing with success. Some ideas to hold the bearings in, if it bothers you or you have issues would be to super glue the bearings to the carbon (which actually works great), loc tite the bearings to the locker or you can build some shims to go between the bearings and the tube bearing relief. Yes, plug is for a hole to access for easy gear mesh since all motors and pinions can put it in a different spot. The plug works great. Its a pretty big hole that the plug uses and I can actually reach behind my 2nd gear to get to my motor screws with a standard driver. The reason I dont like the tape is because of looks and I also dont carry tons of tape on the trails with me and its nice to replace the plug that easily. To each their own though. The main intention of producing these was to produce a case where you could not only benefit from the design but, first and foremost was to really bring the cost down. I would really like to help keep the hobby going, possibly bring some new people in all while giving them a product that not only has a low entry price but at the same time give a quality part that can be the heart of their axles even through many upgrades. From darn near stock to extremely modified, these should be a great building block. These will be a close copy of my super lite axles. The main difference is that these will not have the benefit of being narrower at the gear case and therefore they will also not be narrower from kingpin to kingpin like the super lites. The narrowness of the super lites is still a huge advantage so this new design is not intended to take over but rather to help fill a void in the lower cost category. Since these axles will be similar in many ways to the super lites, they share a lot of the same advantages.
Centers now have the added logo so there is no question who's cases you bought. Width is in check! Last edited by Erik D_lux; 04-22-2015 at 06:37 AM. |
09-04-2014, 10:12 AM | #2 |
| Re: ♣♣New♣♣ DLUX REPLACEMENT gear cases Last edited by Erik D_lux; 09-08-2014 at 12:00 PM. |
09-04-2014, 10:12 AM | #3 |
All stock except centers.... RCbros setup looks great on these! (I am now stocking these tubes FYI) Dlux tubes and upper mount obviously work too. Last edited by Erik D_lux; 09-08-2014 at 12:17 PM. |
09-04-2014, 10:21 AM | #4 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
Tease!!!!!! Later, Farmer |
09-04-2014, 01:36 PM | #5 |
DravTech Join Date: Aug 2012 Location: Sweden
This is just plain mean!
09-04-2014, 06:06 PM | #6 |
Not to worry. I'm sure it's got the trademark Dlux stamp on it. And if you see the crown, you know they're down. Last edited by TSK; 09-04-2014 at 06:42 PM. |
09-05-2014, 06:57 AM | #7 |
Quarry Creeper Join Date: Jul 2008 Location: Hesperia ca.
At least tell us what there going to be made out of!!
09-05-2014, 07:38 AM | #8 |
Gold
09-05-2014, 10:38 AM | #9 |
| Re: ♣♣New♣♣ DLUX REPLACEMENT gear cases There are going to be a lot of possibilities. I am trying to get the final details on this and I will let you know. At this point, the design is in its final stages and is out being tested. I should know more and be selling these very, very soon. Yeah, I can do that. Cost is going to be a bit more than the "standard" materials. Looks like about $15,000 for 18k gold. Of course you could always MAN up and get the platinum versions. They will run $30,000. If anybody thinks I am joking about doing the above.... try me. |
09-05-2014, 10:49 AM | #10 | |
| Re: ♣♣New♣♣ DLUX REPLACEMENT gear cases Quote:
09-05-2014, 10:54 AM | #11 |
A diamond encrusted toilet is worthless without its bidet compliment. I wish I were rich enough for a bidet.
09-05-2014, 11:07 AM | #12 |
| Re: ♣♣New♣♣ DLUX REPLACEMENT gear cases |
09-05-2014, 12:30 PM | #13 | |
09-05-2014, 12:40 PM | #14 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
I am guessing parts are 3d printed:P Later EddieO |
09-05-2014, 12:50 PM | #15 |
Erik, did you take that "Releasing a new product" class that Axial teaches? |
09-05-2014, 01:01 PM | #16 |
No tech, no pictures, etc... We tend to move or delete these kind of things... |
09-07-2014, 07:33 PM | #17 |
09-07-2014, 08:16 PM | #18 | |
Rock Crawler Join Date: Oct 2012 Location: Casper
09-08-2014, 12:09 PM | #19 | |
Ok, so I was really slow on getting the info and pictures up. I will not be slow on getting product out though. I expect these to start shipping in just a week or two. TI probably wont be an option unless you want to spend some coin. I just checked and raw material would be close to $125. All I would have to do then is find somebody that wants to machine it! | |
09-08-2014, 12:11 PM | #20 |
Updated with info and pics. Let me know if you guys have questions. Only thing I really cant answer in here is cost and I will have that ASAP. They will be the cheapest Berg option on the market and they will probably make the Bully guys feel like they spent a lot. Ok, ok, sorry for the jab Bully guys.
♣♣New♣♣ DLUX REPLACEMENT gear cases - Similar Threads | ||||
Replacement cases (where to get them?) | khwilliams | EnRoute Berg | 1 | 08-22-2011 03:17 PM |
ROBITRONIC / RCP ♣ GIVEAWAY ♣ Free Servo Horn | RobiUSA-James | General Crawlers | 215 | 07-10-2009 12:29 AM |
AL Gear Cases | reedpowell33 | Tamiya Clod Buster | 14 | 11-27-2004 10:15 PM |
