Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: Sloski's simple berg build
Old 04-23-2015, 07:23 PM   #101
Default Re: Sloski's simple berg build
Just got into BendOver Ut...
roksloski is offline   Reply With Quote
Old 04-25-2015, 05:07 PM   #102
Let me have one of those
TANK is offline   Reply With Quote
Old 04-27-2015, 05:26 AM   #103
No problem.....
Stranger, what the hell is up.......???
Old 04-28-2015, 10:39 AM   #104
yep.......
looks just like rob_b's post #33........
this chassis is super sweet...
Big thank you to rob_b .....................]
OH yea, it does have a name... Chump AiR.......
Old 04-28-2015, 11:01 AM   #105
This reflected why I had a 40 and 2 50's at BOTW...........
I had another short side in this truck that I could have used in my currant truck, but I was a bit lazy and did not want take apart 2 trucks to swap them....
And still was not last place..........
Old 04-28-2015, 11:08 AM   #106
Sweet!
Not sweet.
rob_b is offline   Reply With Quote
Old 04-28-2015, 11:16 AM   #107
Originally Posted by rob_b View Post
Sweet!
Not sweet.
but I did do a swap in the hotel room...
Old 04-28-2015, 11:43 AM   #108
Hotel Crawler Porn
Old 04-28-2015, 11:48 AM   #109
Custom Carbon Fiber
Robbob's Avatar
Hotel Crawler Porn
50 shades of gcode
Robbob is offline   Reply With Quote
Old 04-28-2015, 01:46 PM   #110
Hotel Crawler Porn
Originally Posted by Robbob View Post
50 shades of gcode
That's Hella funny...............
Got a mock up of the re-released KL Design knuckle weight holders
need to order some 1/2oz weights .......
Thank you Robbob........
Old 04-28-2015, 02:00 PM   #111
Are the kl weights gonna be available to the public?
JeepinDoug is offline   Reply With Quote
Old 04-28-2015, 02:34 PM   #112
Custom Carbon Fiber
Robbob's Avatar
Yup
Krazed Buillds - Heavy Hangers for Berg 8* Vp Knuckles
Or the web store www.krazedbuilds.com
Old 05-06-2015, 09:17 AM   #113
thank you robbob......
Got my motors back from a rebuild at Jakes Performance Hobbies
My delrin cases are xtra thick where the motor bolts on...
but I like to use Lunsford's motor screw kit, cause it has awesome alum.
wide cone washers.......
the lower washer, you have to put a flat spot on the washer so it fits against the case bottom......
Old 05-09-2015, 09:56 PM   #114
So with blowing the ball off my super300's..
I have been on a quest to find something that will work...
so I thought I would try this:
STRC scx10 uni. / cvd's......... what ever... you know what they are.....
The scx shafts will work for the short side...
I have on order Wraith shafts only, for the long side to use on the berg long side.........
with a bit of measuring (well a lot of measuring ), cutting and grinding I got this............
they are a bit bumpy at full lock, but im hopein to work some of it out...
whats kinda nice they have a 2.47mm pin......
be able to tell more when the wraith shaft comes in and I grind and fit that one.....
Old 05-10-2015, 06:14 AM   #115
Nice work mang!
"A bit bumpy at full lock".... You could always mod them, while you wait.
When I got started, a venom creeper was what I had and the cvd's/steering was weak.
I would take a drill bit, the size of the pin, and run the side of the bit against the end of the ball where the pin came in contact with it.
This would allow full steering, without the bump, at full lock.
Cvd's lasted Much longer, without that bind in the steering.
winnerone23 is offline   Reply With Quote
Old 05-11-2015, 07:40 AM   #116
Originally Posted by winnerone23 View Post
Nice work mang!
Thanx winner..........
I have another option up my sleeve..........
Old 05-18-2015, 11:41 AM   #117
Got in my STRC wraith cvd's, so now I can finish up this test project...
wraith shaft, plenty long enough...
its in,.. after a bit of measuring and grinding...
Well since the season is over, I can now put these in this build and give them a bit of a work out......
well maybe I better decide if im going to AZ first...
BTW, I drove this new truck yesterday at the last comp of the season..
truck felt pretty good over all
it needs some fine tuning and its a little wider than my last truck
First set of VOODOO's , they take a bit to get use too...
Old 05-18-2015, 11:55 AM   #118
Mmmmmm pez
Curcal is offline   Reply With Quote
Old 05-20-2015, 10:44 AM   #119
How did the strc cvd hold up? Thinking about using them to shorten ar60 axle for a sporty rig. Seen a review where the ball end in the cvd busted....
tapped-out is offline   Reply With Quote
Old 05-20-2015, 04:08 PM   #120
Oh my.....
don't tell me that........
I only used them because they were cheap ...
and if they explode, I will try the VP ones........
I have something else up my sleeve...
I haven't not put them in the berg yet.......
AZ is coming up, and don't want to put them in then take them out before AZ, if I go...
not something I want to trust at that kind of comp.....
I will post the results, when I do try them......
Sloski's simple berg build - Similar Threads
Simple Build Texsun Losi Mini-Rock Crawler 18 12-07-2010 02:59 AM
Simple f350 scx10tr Build ttown180 1.9 Scale Rigs 19 11-21-2009 07:50 AM
Simple SCX Scout build Stburr91 1.9 Scale Rigs 10 08-03-2009 08:26 PM
