Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: Lockout help
Old 03-08-2015, 09:35 AM   #1
Default Lockout help
Slowly starting a Berg build from the parts bin. I think these are clover rear tubes. I'm missing the lockouts. Anyone know what lockouts fit these? The outer diameter of the shaft is 13mm and the length I needs seems to be about 22mm.
new2it is offline   Reply With Quote
Old 03-08-2015, 10:04 AM   #2
Default Re: Lockout help
If memory doesn't fail me , Axial .
Tom G is offline   Reply With Quote
Old 03-08-2015, 10:23 AM   #3
Thx. The axial ax10 lockout looks close. They're too long, but can always be cut. I'm trying to find the inner diameter on them. Was hoping there would be a bolt...
Old 03-08-2015, 10:16 PM   #4
Some one correct me if im wrong, but those are not Clover Tubes.....
Those Axial lock outs should be some where around 13mm ID...
and take a 5x11mm bearing , but in your case a 6x11bearing..........
roksloski is offline   Reply With Quote
Old 03-09-2015, 04:21 AM   #5
Thanks for the info on the Axial lockouts
Think the tubes are custom or turned down bergs? I bought them years ago from a member here, Aussie Nerd. i looked him up but he hasn't been on in 9 months.
Old 03-13-2015, 06:26 PM   #6
Tried the Axial lockouts - didn't fit. Any other ideas? Axle tube diameter is 13mm and total length of lockout would need to be 22mm (or longer if it can be cut).
Old 03-13-2015, 09:47 PM   #7
My rear tube is turned down to 13.2 mm
and I run an Axial plastic lockout on it..........
total length of lockout is about 33.45mm.........
I think that covers it.......
Old 03-14-2015, 11:35 AM   #8
I dont think those tubes need additional help from lock outs.
They should have some kind of bearing retainer like a circlip or snap ring inside the end of the tube.
JeepinDoug is offline   Reply With Quote
Old 03-14-2015, 12:22 PM   #9
5th D Owner/Driver
cboggs's Avatar
Definitely NOT clover tubes.
cboggs is offline   Reply With Quote
Old 03-14-2015, 01:43 PM   #10
I took them off a crawler a couple of years ago and just dug them out. Unfortunately I don't seem to have all the pieces and never took a photo of them built. If I remember correctly I'm pretty sure there was a locker. Here's what the end of the tube looks like. I think I need the locker to hold that bearing in.
Old 03-14-2015, 01:47 PM   #11
No ring to hold the bearing in so it must have had an aluminum cap that screwed on to the end to keep the bearing from falling out.
Old 03-14-2015, 02:22 PM   #12
Yep. There are threaded screw holes in the tube. I'll have to keep searching for a lockout that fits. Unless someone wants to make me those aluminum caps
Lockout help - Similar Threads
axle lockout help richierm Venom Creeper 8 09-13-2011 01:11 PM
Rear Lockout steakman Redcat Crawlers 10 10-30-2010 08:07 AM
need lockout roy 2 Duratrax Cliff Climber 4 10-06-2009 04:35 PM
