06-14-2015, 03:08 AM | #1 |
Quarry Creeper Join Date: Jun 2010 Location: brisbane
| The riddler loaded with dlux super lites
Time for change. First up HULKSTA- RIDDLER CHASSIS A set of DLUX super lite diffs. Center section: 7075, Gears: RC4wd with big pin mod, Tube Diameter: Fit AX10 chubs, C hub: AX10, Knuckles: Dlux, Front Shafts: OFNA style stub shaft, Rear delrin hub width: Approx 10.25" wide, Steering links: , Hardware: Titanium and aluminum, Elecs Twin sidwinders, bec Brood 40t Stubbys Hitec 7950 MR LINKS CUSTOM LINKS Hulkstas CF rims with super skinny silver dot Voodoo's |
06-14-2015, 03:11 AM | #2 |
| Re: The riddler loaded with dlux super lites |
06-14-2015, 03:15 AM | #3 |
06-14-2015, 03:17 AM | #4 |
06-14-2015, 03:57 AM | #5 |
Rock Crawler Join Date: Aug 2013 Location: Norway. Bodø city
Great bulid... All the right parts to make on hell off a crawler... I have been wanting the riddler or the remedy chassis for some time myself.. But the sudu chassis is working great for me,, But I will go for this riddler once I start to build up my ccc axels.. PS,, Is there room for the electronics in the cab,, I mean with the 5`th shock in there... |
06-14-2015, 04:08 AM | #6 |
Thanks mate, the new chassis from Hulksta is killer. My esc's and bec fit inside the chassis and my receiver is on the back board of the chassis. First comp with it today pulled a 1st. |
06-14-2015, 04:32 AM | #7 |
what is the rtr weight?? without weights on.. around 1500g??? |
06-14-2015, 01:12 PM | #8 |
RTR with knuckle weights and running S/Steel links is 1555grams. once change over to TI links RTR will be around 1500grams. Without knuckle weight RTR around 1450grams.
06-14-2015, 01:57 PM | #9 |
about the same as mine.. only I have 380g in weights.. 148 on each knuckle in the front and 46 on each side rear.. I will go down to around 100g on each knuckle in the front |
06-14-2015, 11:23 PM | #10 |
have you tried to mount the shocks on the top link/shock mount hole?? when I did that with my sudu on the superlites the rig did get alittle lower and the shocks did also travel alot smoother,, hard to explain,,, but it works,,, he he he |
06-14-2015, 11:53 PM | #11 |
Rock Crawler Join Date: May 2012 Location: Australia
Looks good Steve. You will love driving this when you get used to it. |
06-15-2015, 08:21 AM | #12 |
cool Nick,, LuxenBERG,,,, he he he
06-15-2015, 08:22 AM | #13 |
and you have a luxus berg BTW
06-16-2015, 02:29 AM | #14 |
A big shout out to Hulksta ENGINEERING ONETEN CRAWLERS MR LINKS custom links OTTSIX TIRES DLUX For all there help and suppling me with the best RC crawler gear around. |
06-16-2015, 06:05 AM | #15 |
Rock Stacker Join Date: Apr 2014 Location: Hobart
Super sweet looking rig mate!! Keen to try one of these riddlers myself. |
06-17-2015, 03:35 AM | #16 |
Thanks mate. You'll love the Riddler |
06-19-2015, 03:47 PM | #17 |
06-19-2015, 05:48 PM | #18 |
Quarry Creeper Join Date: May 2012 Location: enfield CT
Thanks for the video what do you have in the mono shock for oil and spring?
06-19-2015, 06:20 PM | #19 |
The spring i got from a team driver, it's quit a long spring about 1 and a 1/2 times longer than the shock body and quite hard spring rating. The shock it self is a scx10 shock shaft and body cut down 10mm. The oil is 20000 rc diff oil.
08-24-2015, 03:03 AM | #20 |
Latest vid from the riddler https://www.youtube.com/watch?v=hfemTwYVHQ0 |
The riddler loaded with dlux super lites - Similar Threads | ||||
Hulksta Riddler with a dash of Dlux | filotr14lsdude | EnRoute Berg | 43 | 11-08-2015 04:27 AM |
