08-03-2015, 01:16 PM | #41 |
Pebble Pounder Join Date: Feb 2015 Location: Mount Morris
| re: Blandons Berg DLUX...2.0 thanks, & now that im remembering better, i did have to mod my ci foams for them to fit. i had a hard time figuring out the best way to do it also. going on dlux's advice i used a dremel and a sanding drum. if i remember correctly theres also a line on the foams that i used as a guide. it was my other foams that didnt have to be cut (pit bull dos piezas) but they sucked with the loaded dice, the soft inners got chewed up by the weights.
08-04-2015, 09:00 PM | #42 |
Rock Crawler Join Date: Dec 2010 Location: Ct.
| re: Blandons Berg DLUX...2.0 I'm running the 5.5's and after trimming it still seems like there is enough meat left on there to function nicely. If not there is always the 6.0's I could trim and try. Next week I will finally have the rig all put together and start running the Sh&$ out of it to see where we stand. I really hope the foams are right because I do not want to try to take these Beeatch's apart now to change foams unless it's really necessary!
08-04-2015, 09:18 PM | #43 |
RCC Addict Join Date: May 2012 Location: Folsom
The 5.5s should be totally on point.
08-07-2015, 11:09 AM | #44 |
Yes sir! |
08-07-2015, 01:06 PM | #45 |
| re: Blandons Berg DLUX...2.0 |
08-12-2015, 08:33 PM | #46 |
Finally all together!!!!!!!
08-12-2015, 08:54 PM | #47 |
Some more pics
08-13-2015, 04:30 AM | #48 |
Quarry Creeper Join Date: May 2012 Location: enfield CT
Oooo no |
08-13-2015, 08:52 AM | #49 |
Awesome! Looks exactly like I would have built it. I think you need to swap your tie rod end for end. I think the bends are at the wrong ends but its hard to tell from your pictures. The tie rod should sit on top of the gear case tucked away from the rocks. Cant wait for you to drive it! |
08-13-2015, 11:20 AM | #50 | |
| re: Blandons Berg DLUX...2.0 Quote:
08-13-2015, 12:16 PM | #51 |
Had a chance to run a few packs through it today and I am impressed! This is a heavier truck than I am used to but having the weight low and wide makes it feel really planted to the ground and very stable. Here's a couple pics of the rig out in the wild.
08-13-2015, 12:17 PM | #52 |
08-13-2015, 01:06 PM | #53 |
Rock Crawler Join Date: Aug 2013 Location: Norway. Bodø city
nice... you are gonna fall in love with these axels, the fact that you get all that weight low in the wheels is the key to sucsess.. I feel I can do everything with my sudu on the superlites.. my old xr10 belongs in a museum compared to the dlux axels I have 400g off brass and slugs on my axels,, and even with 400g in weights I am still under 2kg |
08-13-2015, 01:10 PM | #54 |
I took a couple videos so as soon I figure out how to upload them from my iPhone I will post em!!
08-13-2015, 02:37 PM | #55 |
I would like more pictures of the spot you crawled at |
08-13-2015, 03:54 PM | #56 |
| re: Blandons Berg DLUX...2.0 I will post some pics of a couple different spots I crawl at. I would like to see if we can get some guys together down here this fall to do a comp with 2.2P and 2.2S. Ill try to post up some pics over the weekend and you can let me know what you think. It's kind of a long drive for some of you but it might be worth it. One of the spots is great at low tide. I may be putting together a sporty soon also!! |
08-13-2015, 08:20 PM | #57 |
My Custom Fiber guards for the Puller 400's and servo came in today. They look awesome!! Thanks Troy |
08-13-2015, 11:18 PM | #58 |
how are you supposed to mount the servo guard??
08-15-2015, 04:35 PM | #59 |
A little birdy told me that a boxer is in the future for a contender |
08-15-2015, 11:32 PM | #60 |
Blandons Berg DLUX...2.0 - Similar Threads | ||||
new to berg/dlux.... | FLOKI-81 | Newbie General | 20 | 03-02-2015 07:29 AM |
