07-16-2015, 02:46 PM | #1 |
Rock Crawler Join Date: Dec 2010 Location: Ct.
| Blandons Berg DLUX...2.0
A little white box of joy just showed up from the Dlux compound and it might contain a little more than that awesome gas mask t-shirt. I'll dig in tonight after work👍🏻
07-16-2015, 06:41 PM | #2 |
| re: Blandons Berg DLUX...2.0
Down with the Crown!!!! Time to start wrenching |
07-16-2015, 06:52 PM | #3 |
The parts list: -Rear Axle: Dlux Superlite / 7075 rear shafts / 7075 center housing / Rc4wd lightened gears -Front Axle: Dlux Superlite / OFNA Dlux Uni's / 7075 center housing / Delrin front hubs / Rc4wd lightened gears / Dlux steering links / Ax10 C-hubs / Dlux knuckle system / full set of Dlux links / Dlux Ultra chassis / HH 33t 400 Pullers / HH dual BR mini's / Dlux wheels Last edited by blandon; 07-17-2015 at 07:01 AM. |
07-16-2015, 07:54 PM | #4 |
Rock Crawler Join Date: May 2009 Location: Calgary
Great looking heap o' parts. Dlux makes the best shizz. Make sure and pick up the loaded dice set-up as well. EDIT: Chassis??? Last edited by Krawler Kev; 07-16-2015 at 07:55 PM. Reason: Comp crawling will never die. |
07-16-2015, 08:20 PM | #5 |
| re: Blandons Berg DLUX...2.0 Thanks Kev, I am running the Dlux Ultra chassis also, I went back and forth on whether to get the Loaded Dice now or not. The only reason I didn't go with them yet is because I have to change the wheels to use that system, but I'm sure they will be getting ordered sooner than later!!,
07-16-2015, 08:26 PM | #6 |
I wanna be Dave Join Date: Dec 2006 Location: here
Enjoy the build, I'd love to build myself a set of those axles.
07-16-2015, 08:32 PM | #7 |
Making Head Way!!! |
07-16-2015, 08:40 PM | #8 |
These axles really are a work of art!! The fit and finish is absolutely awesome! Dlux definitely knocked it out of the park with the design and craftsmanship of the Superlites. The tolerances if everything is perfect, the pieces just lock together with no slop and buttery smooth!!!
07-17-2015, 10:58 AM | #9 |
Rock Crawler Join Date: Aug 2013 Location: Norway. Bodø city
does not dlux have rcbros gears??? You will LOVE the superlites.. Perfection... |
07-17-2015, 11:00 AM | #10 |
I believe Rcbros gears are out of stock everywhere at the moment
07-18-2015, 07:56 AM | #11 |
Quarry Creeper Join Date: May 2012 Location: enfield CT
Looking good |
07-19-2015, 07:49 AM | #12 |
Very nice!! You will not regret the purchase. Money well spent. |
07-19-2015, 01:18 PM | #13 |
| re: Blandons Berg DLUX...2.0 Thanks Harvo, your DLUX build thread is one of the reasons I ended up going with all the DLUX goods!! I have been running the Ultra chassis for a while now with XR axles and finally pulled the trigger on the Superlites. I have to say I am more impressed with every piece I install. |
07-19-2015, 08:15 PM | #14 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
You have the best working setup out there. I run a bodied version of the same chassis and it is the best chassis i have used. I would highly recomend the Loaded Dice kw. They are one of my favorite mods. When you say lightened rc4wd gears, are they just rc4wd gears or did Erik lighten them up more? |
07-19-2015, 10:00 PM | #15 | |
| re: Blandons Berg DLUX...2.0 Quote:
07-21-2015, 06:56 PM | #16 |
Decided to add inserts to the Delrin hubs and make em bomb proof!
07-21-2015, 07:34 PM | #17 |
Finally had some time tonight, rear axle is complete and ready for the Puller!!
07-21-2015, 07:45 PM | #18 |
Front axle almost done, waiting for some other cool parts to roll in this week👍🏻
07-21-2015, 08:31 PM | #19 |
One mod that will definitely make your life much easier with these axles is to drill two 6mm holes for access to the adjustment screw for the motor and a viewing hole for the gear mesh on both axles. Dlux includes some nice plugs to block the holes or some tape would work just fine too
07-21-2015, 11:23 PM | #20 |
I use the small krawler Konsepz stickers over the screwhole to the motor adjustment screw,,, they are perfect in size,, just like a stamp |
Blandons Berg DLUX...2.0 - Similar Threads | ||||
new to berg/dlux.... | FLOKI-81 | Newbie General | 20 | 03-02-2015 07:29 AM |
