01-27-2016, 02:44 PM | #1 |
Newbie Join Date: Jan 2016 Location: Canada
| Berg 2.2 v3 chassis fit t1e?
Hey guys I picked up a used t1e this morning for $400 Canadian. Wondering if the v3 chassis will work with the berg t1e axles? If not I can rig up a similar chassis on my own since I own a machine shop. I have access to a used v3 chassis online but only if it works I'll buy. Thank you,
01-27-2016, 03:15 PM | #2 |
Rock Crawler Join Date: May 2009 Location: Calgary
| Re: Berg 2.2 v3 chassis fit t1e?
Pictures please....
01-27-2016, 03:17 PM | #3 |
RCC Addict Join Date: May 2012 Location: Folsom
T1E is a group/guy that makes the Chassis. Berg is the company that makes the axles...... You'll be able to mount any chassis you want to those axles. |
01-27-2016, 03:32 PM | #4 |
Thank you Curcal. Good info. I'll post pics as soon as I get time..
01-28-2016, 02:24 PM | #5 |
Hello folks, pictures will arrive on the weekend. Electric wiring help now. I've seen a few diagrams thru the archives here but I a mechanical guy not electric. If someone can explain in caveman terms the way I need to set up this rig. I have the following electronics. Obviously I would like the motors to run independent and is it possible to mix the motors as well? 2 motor. 2 speed controller. No receiver and no radio. I need to buy a 3 channel radio I assume? Once I purchase my radio then I assume the one receiver module will be enough to hook up the 2 motors 2 speed controllers 1 servo and maybe add a second servo later if need.. Hope all this info is needed. I also noticed thru the archives mention a bec?? All this electric stuff gets me nervous.. Thanks for any help. |
01-28-2016, 03:03 PM | #6 | |
| Re: Berg 2.2 v3 chassis fit t1e? Quote:
You will definitely need to run a BEC or your servo will "brown" out (i.e. - it wont have the turning power you want). What motors do you have? What speed controls do you have? Last edited by Krawler Kev; 01-28-2016 at 03:04 PM. Reason: Comp crawling will never die | |
01-28-2016, 03:19 PM | #7 |
Thank you I meant 4 channel. 2 brood 35t- working motors, just not sure if these motors are good quality or if I need to upgrade to better? 2 tekin fxr speed controllers. Now where exactly does this bec fit into the pic? And everything else,lol, ? Cheers. Last edited by Elektrpwr; 01-28-2016 at 03:43 PM. Reason: Spelling error. |
01-28-2016, 06:00 PM | #8 |
RCC Addict Join Date: Aug 2009 Location: Earth?
Use the T1E chassis. I'm sure it will be MUCH better than a Berg V3 chassis.
Berg 2.2 v3 chassis fit t1e? - Similar Threads | ||||
Berg t1e chassis on venom | Skier | Venom Creeper | 8 | 04-19-2011 08:30 PM |
