Sic's 1st Berg has a Bounty! This will be my 1st berg ever so here we go....been talkin this over with Erik for some time now so talks over, Thanks DLUX! PARTS: Dlux Bounty Hunter chassis Dlux superlites Dlux loaded dice wheels/weights Dlux 7075 knuckles 3.5 Big bores modded with mip pistons HH br minis with cc bec HH 11t pullers(one day?) 7950 Really other than motors I should be good, all but finishing touches. Pics http://i1321.photobucket.com/albums/...psgnhdeqrx.jpg http://i1321.photobucket.com/albums/...psxvdzmgjx.jpg http://i1321.photobucket.com/albums/...psvhofp2um.jpg http://i1321.photobucket.com/albums/...psv5qpgk5p.jpg http://i1321.photobucket.com/albums/...pshoj6csvn.jpg http://i1321.photobucket.com/albums/...psirsq3j52.jpg Now if i can get some electronics goin & assemble another set of tires/wheels a BERG is born"thumbsup" Oh yeah gonna have some colorful skins made by Krawler Konceptz"thumbsup" |
Re: Sic's 1st Berg has a Bounty! I would be careful with 11t pullers. I have 16ts in my rig right now ( very similar setup, only different chassis) and they are a little weak on the drag break. Which helps with some smooth down hill applications, but if I'm climbing and switch into dig I have to keep a little power to my rear so it doesn't roll back (this I can do easily with a twin stick). So I would caution going to an 11t puller because there is even less drag break/holding power in this application. Other than that gotta love that parts list |
Re: Sic's 1st Berg has a Bounty! Quote:
I run 13t pullers in my xr so just assumed the 11t's would be close to same with mo speed? Ty for that info I will prob not go 11t then cause 13t is plenty! |
Re: Sic's 1st Berg has a Bounty! Ish is about to get real! Nice! You and your mounting of the loaded dice backwards.... LOL |
Hey I tried to flip em around & they don't seem to fit that way? The Bottom of the knuckle stops the brass holder from goin up far enough to bolt it up. Is there something else i need to do cause I seen your thread where urs are other way. |
Re: Sic's 1st Berg has a Bounty! Really liking the clean look of that chassis! |
Re: Sic's 1st Berg has a Bounty! Is that like 45° of caster? |
Re: Sic's 1st Berg has a Bounty! Gotcha yeah my xr is alot lighter at 3.7lbs. I will be shooting under 4lbs but a lil over is cool too"thumbsup" |
Re: Sic's 1st Berg has a Bounty! Ok I dont feel that stupid then! I tried to flip em but not clearanced enough. Once the wheels are built we see how it comes together"thumbsup" |
Re: Sic's 1st Berg has a Bounty! That's how my weights are mounted.. What's wrong with 11t's!? It's what I run! ;) |
As Curt mentioned, they don't lock your axle solid.. Buuuutttt.. I ran the 13t and FXR's and always liked that it let the rear axle roll a little. (At times) The BR's lock up solid, so I have to have some, give, somewhere.. You get use to it and don't notice.. IMO.. |
Re: Sic's 1st Berg has a Bounty! I may try the 11t's just to see what im missing:twisted: The real question is wth is goin on at that magnificent monster madness motor makers house.....JEEZ LOUISE JRH I only need 3 pullers & couple mini's mang:ror: |
Re: Sic's 1st Berg has a Bounty! 13T and 4S is a lot of fun"thumbsup" |
They are setup at approx 35* with the gear box flat so if you bring the box up about 10*, youre only looking at 25* or so. You can also rotate the chubs for less caster if you want since there are multiple holes on the AX10 chubs. My guess is that they are about 28-30* right there. Should be a great start. Lengthen the uppers a hair to get more clearance under the box if needed. |
Re: Sic's 1st Berg has a Bounty! Ahhhhhhhhh relief!!! The caster is a bit more to what im used to runnin...however this is not bad learning new things! I'm about to strip my xr of its elec's to get this thing on the rocks asap:) |
Re: Sic's 1st Berg has a Bounty! That car will be setup exactly like mine except maybe how much knuckle weight you run. You will be good. |
