07-01-2016, 06:22 AM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: Norway
| Dlux delrin axle tubes on v3 axle?
Is it possible to modify Dlux delrin axle tubes to fit Berg v3 axles?
07-02-2016, 03:37 PM | #2 |
Rock Crawler Join Date: May 2012 Location: Australia
| Re: Dlux delrin axle tubes on v3 axle?
Yes it it. You will have to drill different holes in the tubes to match the smaller pcd org the v3 cases. The thing you will need to look at will be overall length. The v3 tubes are shorter then standard berg tubes, so if your using the standard axle, you will need to trim the tubes. I don't remember the dlux bearing diameter, you may have to find bearing that fit inside the dlux tubes and suit your stock axle |
Dlux delrin axle tubes on v3 axle? - Similar Threads | ||||
Dlux Delrin Axle Tubes | jdacus | EnRoute Berg | 11 | 11-15-2012 08:08 AM |
delrin axle tubes | STEEL_CITY_CRAWLER | Tamiya Clod Buster | 4 | 10-19-2006 03:16 PM |
