Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: Ride height/belly clearance
Old 11-08-2016, 01:37 PM   #1
Default Ride height/belly clearance
Hey guys,
What ride height/belly clearance do you have?
I'm using Chaotic switch chassis and still trying to figure it out what will be the best for me.
ssh22 is offline   Reply With Quote
Old 11-08-2016, 04:09 PM   #2
Default Re: Ride height/belly clearance
which generation of switch chassis. OG switch, Switch Zero, and I dont remember the name of the last chassis they put out... this will make a huge difference though.
Curcal is offline   Reply With Quote
Old 11-09-2016, 02:07 AM   #3
Hm... good question. I really don't know which version is. It's called "Chaotic Switch Bodiless Carbon Chassis".
Old 11-09-2016, 07:17 AM   #4
Do you have pictures to share?
Old 11-09-2016, 08:31 AM   #5
I don't have pictures with me, but it's like this:
Old 11-09-2016, 10:13 AM   #6
since you are posting in the berg section, i assume you swapped over your berg axles etc onto this new chassis..?
asking because if this is the case i would like to do something similar with my enroute 2.2.!
nice looking chassis..!
nicos is offline   Reply With Quote
Old 11-09-2016, 10:33 AM   #7
I'm using berg v1 axles. This pic is just to show the chassis. Axles doesn't matter... chassis is the same. Only links are different according to the axles.
But since I'm using my own links I want to know what will be the best for belly clearance/ride height
Old 11-09-2016, 12:30 PM   #8
Shoot for about 3 1/2 inches of belly clearance..... with that chassis
Old 11-09-2016, 12:43 PM   #9
great..!
would like to see a picture when its done..!
Old 11-09-2016, 01:56 PM   #10
That is the regular Switch chassis. I used to have the Switch Smash which had the smaller cab. Switch was a great chassis! Curcal is spot on with the 3 1/2" belly, you should be in good shape with that.
blandon is offline   Reply With Quote
Ride height/belly clearance - Similar Threads
belly skid height TacoCrawler Axial Wraith 38 08-11-2015 08:26 PM
wheelbase vs belly height BBCorvette18 General Scale Talk 9 12-14-2013 05:40 PM
ideal belly height? neuro242 Axial AX-10 Scorpion 23 09-26-2009 05:41 PM
belly height crawlinlosi Losi Mini-Rock Crawler 5 09-07-2009 04:25 PM
Belly height kid rock Iowa 1 05-29-2008 08:31 PM
