03-06-2018, 01:22 PM | #21 |
Rock Crawler Join Date: May 2012 Location: Australia
| Re: ssd pro scx10 c-hubs with berg knuckles Yeah a matching set. 0degree chub that suits xr/wraith spline 0 degree knuckles to suit xr/wraith universals As it stand, the dlux knuckles are the only ones that allow this combination without modifications. I’m lead to believe that the rc4wd Bully axles will also fit with a little bit of modification. The main issue with the dlux knuckles it’s there big and bulky, not really an issue on a 2.2 comp rig. The issue comes from the scale side of things. While I know this conversation is happening in berg section, it’s relevant to the whole conversation. The dlux knuckles don’t look scale and struggle to fit inside some of the 1.9 wheels on the market unless you space them out. This then introduces a whole different level of scrub. I know most are running the xr width or narrow xr width. Personally I use full width xr in my scale trucks with minimal hub offset, this allows me the similar width with zero scrub.(this doesn’t work with dlux knuckles due to the shape of the wheels) If there was a normal style knuckle on the market it would make this a much easier set up to have. Personally I don’t really like the 8 degree, never really have. I’ve just had to settle for it because there is nothing in the market that fits the needs. |
03-07-2018, 06:42 AM | #22 |
RCC Addict Join Date: Oct 2014 Location: UK
Ok so although 8 degree KPI is not needed for crawling is a disadvantage? Will 0 degree knuckles perform better?
03-07-2018, 08:41 AM | #23 | ||||
| Re: ssd pro scx10 c-hubs with berg knuckles Quote:
The problem with that was that there are still some of us running 0* and we can compare. Its funny to me because I have been a long time 0* guy. I think people thought I was crazy. The time it started switching back to 0* is when the Bully2 came out. It comes standard with 0* so they started driving 0* and liked it better. So, really, it boils down to people being too lazy to swap parts and try new things. If you have a car like an XR10, people will swear by 8*. Its kinda like people ditching Bergs using super 300's that get 50* of steering for a stock XR10 that also gets 50* of steering but they swear the steering is so much better. Quote:
Think of a Wraith. If this Wraith does nothing but crawl at very low speeds, I would put 0* on. If this Wraith has a brushless system and goes pretty fast most of the time, I would run 8*. If you go fast with 0*, the outside tire gets so much traction that it will roll you with speed. If youre going slow, you want that outside tire to have as much traction as possible. | ||||
03-07-2018, 09:32 AM | #24 |
Yes when I designed Bully2 0* was requested. Then 8* options were also requested by team drivers! Ok so I definately wont be making any 0* option parts. |
03-07-2018, 10:04 AM | #25 |
RCC Addict Join Date: Mar 2009 Location: The REAL Nor-Cal
Annnnnd full circle back to making one off custom parts. LOL
03-07-2018, 11:10 AM | #26 |
| Re: ssd pro scx10 c-hubs with berg knuckles |
03-08-2018, 03:03 AM | #27 |
I'm not going to make any more but it turns out I have a few spare sets that were not packed with front axles. So I will make them available some way.... |
03-08-2018, 04:56 AM | #28 |
Myself and Erik D_lux will take a pair each and I'd bet @BC-Brian will take a pair too.
03-08-2018, 06:25 AM | #29 |
Rock Crawler Join Date: Sep 2011 Location: truckee
I’d buy a pair if there is any left.
03-08-2018, 09:42 AM | #30 |
RCC Addict Join Date: Jul 2009 Location: Near Boston
I am definitely interested in a couple pairs. Sent you an email. Thanks very much for reaching out to us. Sent from my SM-N950U using Tapatalk |
ssd pro scx10 c-hubs with berg knuckles - Similar Threads | ||||
New SSD SCX10 II Knuckles/C Hubs | SSD | Axial SCX10 II | 142 | 06-05-2017 02:16 AM |
New SSD Pro Knuckles & C Hubs for Ascender | SSD | Vaterra Ascender | 30 | 02-24-2017 02:53 AM |
New SSD CVDs, Pro Knuckles & C hubs for Wraith | SSD | Axial Wraith | 3 | 04-14-2016 08:45 PM |
New SSD CVDs, Pro Knuckles & C Hubs for RR10 | SSD | Axial RR10 Bomber | 6 | 03-28-2016 02:34 PM |
SSD pro knuckles for SCX10 axles | joe.bielski | Axial AX-10 Scorpion | 5 | 10-20-2015 07:50 PM |
