12-06-2018, 03:35 PM | #21 |
Pebble Pounder Join Date: Jun 2010 Location: Alcobaça, Leiria, Portugal
| Re: Building my dad a 5th dimension berg
great step by step build project. thanks congrats for this great rig |
12-06-2018, 04:07 PM | #22 |
no talent hack Join Date: Feb 2007 Location: Redwood City
| Re: Building my dad a 5th dimension berg |
12-07-2018, 12:39 AM | #23 |
I didn’t get much done today, but did finish up the front axle. I started by making a servo mount out of 3mm carbon. It is held to the axle with 3 screws and red loctite. Then I fired up the dremel again and made a battery tray for behind the motor. It will it will use a piece of inner tube for a strap aswell as get covered in velcro. I also added steering stops to the axles using a 3mm spacer and button head screw which can be seen in the previous pictures. I figured out that a straight xr10 tie rod is an almost perfect fit with the Dlux knuckles and his proper ackerman arms. I put a slight bend at both ends to bring the tie rod closer to the gearbox and called it good. This might be the last update for a couple days. I have a comp this weekend and I need to make some tires and do some maintanence to my personal trucks. |
12-07-2018, 09:24 AM | #24 |
RCC Addict Join Date: Mar 2009 Location: The REAL Nor-Cal
Looking good Nabil! |
12-07-2018, 10:33 PM | #25 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
12-07-2018, 10:39 PM | #26 | |
| Re: Building my dad a 5th dimension berg Quote:
Oh, by the way...Have you tried the single bend links? If so, how are you liking them? | |
12-08-2018, 12:17 AM | #27 | |
| Re: Building my dad a 5th dimension berg Richmond this Sunday, Folsom next Sunday Quote:
12-10-2018, 07:59 PM | #28 |
The brass weight holders are actually supposed to go on the other way, but you can probably get away with running them that way... |
12-10-2018, 11:30 PM | #29 | |
To add some tech for people who may not know. If you look closely you can see I flipped the knuckles upside down from how Dlux says to put them together so I have more clearance for the loaded dice weight at the bottom. I just learned this trick recently, and while it only works on non 8 deg, it allows for the button head screws to be at the bottom, which fit into the loaded dice weight better Last edited by Nabil; 12-10-2018 at 11:33 PM. | |
12-11-2018, 12:34 AM | #30 |
12-11-2018, 10:49 AM | #31 | |
I think stubs thought that one up. I set up greengo that way, makes it easier to deal with the brass dice for damned sure. Delrin are no big deal since Erik cuts those correctly. | |
12-12-2018, 10:32 PM | #32 | |
Quarry Creeper Join Date: Feb 2009 Location: Glendale Az
12-12-2018, 11:19 PM | #33 |
| Re: Building my dad a 5th dimension berg Thanks Brandon. I still have another set here, but I wanted to use these. I don’t know why but I’ve always liked these tubes.
12-13-2018, 12:07 AM | #34 |
Had some time today to work on it today. Since it’s pretty much impossible to find vanquish ti links anymore I kinda guessed on some lower link length measurements and sent the info to hardcore rc over on facebook. I ended up having to put a bit more bend in the links then I wanted, especially the rears, but I think it should be fine for my dad. The extra clearance might actually help him while he is learning how to pick his lines. I made the uppers myself using 1/8 ti, a hand drill, and a 6-32 die. I’m not entirely happy with how the rear axle is sitting. I will probably play with the lower link mounts on the axle to get it to sit more to my liking. Incase anyone was wondering about the weight, it is currently sitting at 3.8ish pounds. Only things missing are 2 speed controllers, rx, bec, and battery. I still have steel hardware everywhere but the chassis aswell as a couple of other places to cut weight if I wanted. The loaded dice are still empty, so that’s up to 8 ounces of tungsten that I could potentially add to the knuckles aswell. |
12-15-2018, 12:42 PM | #35 | ||
12-15-2018, 10:53 PM | #36 |
| Re: Building my dad a 5th dimension berg I’ve thought about it, my ocd wouldn’t let me do just the rear though. Depending how much he enjoys it and uses it will dictate what I actually do but either way it will probably wait until I have to rebuild it. I did end up rotating the lower link mounts and lowering the motor from the pictures posted. It’s definitely let better now, I think it should be fine.
12-19-2018, 10:49 AM | #37 |
I wanna be Dave Join Date: Dec 2006 Location: here
Hey Nabil remember this video? This is my all time favorite berg video. https://youtu.be/8bRldkeCWWc |
12-19-2018, 11:02 AM | #38 | |
12-19-2018, 11:10 AM | #39 |
Nice, glad I could help lol. Axles look very similar to the axles on your Dad's rig. Don Hughes has a chump RT chassis it's Doncrawla's old chassis it had xr axles. If your looking for one. Sent from my SM-J737V using Tapatalk Last edited by tapped-out; 12-19-2018 at 11:24 AM. |
12-19-2018, 11:58 AM | #40 |
Love watching those VP wheels and Rovers do work...!
Building my dad a 5th dimension berg - Similar Threads | ||||
5th Dimension Suckerpunch | bassbusta01 | Axial AX-10 Scorpion | 16 | 04-02-2018 12:20 AM |
5th dimension dominator chassis | Foxracer11 | RC4WD Bully | 20 | 02-09-2017 02:43 PM |
5TH Dimension Minimal berg rebuild | tapped-out | EnRoute Berg | 70 | 10-01-2013 02:40 AM |
