Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: 5Th Dimension Mark ll Chassis Swap.
Old 10-08-2013, 12:17 PM   #1
Default 5Th Dimension Mark ll Chassis Swap to Dominator.
I received some new side plates from 5TH Dimension to replace the Minimal Chassis.
5Th Dimension new MOA Chassis " Mark ll"This chassis is cut from G10 has more adjustability for tuning, Double sheer side plates for added strength, plus looks better than its predecessor.
This is going be a easy/fast chassis swap. I will continue my berg build in this thread. I wasn't able to use all the cross braces from the Minimal chassis the shock mount cross braces are to short for the new chassis. I orderd a few cross braces from Erik D-lux should have them Thursday.
above is a quick mock up picture.
I'm really digging the look of this chassis.
Thanks 5D (Travis).
tapped-out is offline   Reply With Quote
Old 10-08-2013, 12:28 PM   #2
Default Re: 5Th Dimension Mark ll Chassis Swap.
5TH Dimension Minimal berg rebuild
Rig specs:
5th Dimension chassis
Berg axles
*front*drilled gears, Rcbro locker, turned down alum tubes, super 300's.
Rear drilled gears, Rcbro locker, Dlux tubes, CreeperBob ti inner axles.
ShocksSCX10 W/losi green F/R
MotorsHH red label 16T motors.
Elec.Holmes Hobbies br-minis esc x2, CC BEC, 5995 servo, 4pl radio.
wheels
VP DH & V4
Old 10-14-2013, 12:34 AM   #3
Just a few pics chassis is packed with Holmes Hobbies br mini x2 esc's. These little sucker have a lot of power, only half my batteries out of 30 can handle the power draw that these esc demand (for now). I'm going to pick up some 430mah max amp 100c batteries maybe these can supply/feed the br mini's the voltage they need..
Thanks 5TH Dimension..... Can't wait to get this rig on the rocks.
Old 10-14-2013, 02:20 AM   #4
TSK
Shelf queen
TSK's Avatar
Looking good brother man
TSK is offline   Reply With Quote
Old 10-14-2013, 06:11 PM   #5
5th D Owner/Driver
cboggs's Avatar
Those BR minis will definately weed out any bad batteries you got!
cboggs is offline   Reply With Quote
Old 10-14-2013, 06:36 PM   #6
TSK
Shelf queen
TSK's Avatar
Maybe I better not install mine then.. The BR mini's and some Axle Busters are beginning to sound like the death of all my packs
Old 10-14-2013, 10:59 PM   #7
Got bored today and smashed my CC Micro pros. As back up esc's
Before
After
Above 2 CC micro pro's & a CC bec
Old 10-15-2013, 10:02 AM   #8
The crawler looking great. I'm also going to get some of the max amp packs for the same reason.
Beerman Crawler is offline   Reply With Quote
Old 10-15-2013, 12:42 PM   #9
I ordered 1 430mah max Amp battery today, hope to test it out Sat @ comp practice.
I'll post up if it holds up or not to the the br minis.
Old 10-22-2013, 07:16 AM   #10
https://www.youtube.com/watch?v=S6-M...e_gdata_player
1st run on this Mark ll chassis . Great job 5D. I'm stoked can't wait for the next WCRCC comp November 2nd.
Old 10-22-2013, 07:26 AM   #11
There's some pretty cool transitions in there
ittybitty is offline   Reply With Quote
Old 10-22-2013, 07:28 PM   #12
5th D Owner/Driver
cboggs's Avatar
Looking good.
Old 10-22-2013, 07:45 PM   #13
TSK
Shelf queen
TSK's Avatar
looking good brotha
Old 04-08-2014, 05:21 PM   #14
Been a while since I've updated this thread been running the Mark II chassis all season @ our club comps WCRCC this chassis just plane works, I Placed
3rd this weekend..... here's a video from this weekend...
Old 04-08-2014, 11:32 PM   #15
D-Wray 4 Prez!
Frankenwheely's Avatar
Thanks for the update Matt. I forgot about this chassis. Been looking for a new one.
Frankenwheely is offline   Reply With Quote
Old 04-09-2014, 02:42 PM   #16
If you make it out to our next comp you can get an up close look & test drive if you'd like.
Old 04-10-2014, 12:19 AM   #17
D-Wray 4 Prez!
Sounds good.
Old 04-20-2014, 02:49 PM   #18
Quick video from WCRCC season #3 finals this was the most challenging course of the day, my score from this course -7
Only 5 guys scored low negative on this course...
Old 04-20-2014, 03:01 PM   #19
TSK
Shelf queen
TSK's Avatar
Soon say only some guy named Jake wright got a better score than you on that course? Never heard of him
Old 04-29-2014, 02:23 PM   #20
Default Re: 5Th Dimension Mark ll Dominator Chassis Swap.
Picked up a package from post office yesterday look what was inside Mark II Dominator chassis.
Swapped out my original Mark II bodied chassis getting ready for AZ SHOOTOUT this weekend.
5th dimension did an awesome job on this chassis can't wait to get it on the rocks.
Thanks Travis.
Chassis geo is a less cluttered version of the Mark II, which has been in testing for about 6 months now with lots of positive feedback. I placed 6th in our series points this season (WCRCC) with my Mark II chassis bodied rig.
These are currently cut from 1.5mm CF. Lexan side panels will act as "sliders" for the rear shocks and get us over the 3" minimum.
5Th Dimension Mark ll Chassis Swap. - Similar Threads
Tapped-out's 5th Dimension Sucker Punch tapped-out Axial AX-10 Scorpion 109 08-11-2015 03:17 PM
5TH Dimension Minimal berg rebuild tapped-out EnRoute Berg 70 10-01-2013 02:40 AM
Tapped-out's 5th Dimension Sucker Punch tapped-out Videos! 0 08-11-2013 01:37 PM
