01-20-2009, 10:59 AM | #61 |
Rock Crawler Join Date: Sep 2007 Location: Denmark
| Glad to hear you got your new tranny Now go get it coverīd in snow |
01-22-2009, 04:13 PM | #62 |
Newbie Join Date: Nov 2008 Location: Davie
Now THATS COOL! I think I'm gonna have to build one of those! |
01-22-2009, 06:59 PM | #63 |
Rock Stacker Join Date: Nov 2008 Location: in the middle
what kinda power do you get out of that motor i'm trying to find one for my rock racer and will that esc work good for rock crawling,thanks
01-24-2009, 05:28 AM | #64 |
| Did you see the vid he made ? It has plenty of power He has a 5700kv motor I use a Velinion 3500kv motor in my Foff some guys even use the 3500kv motor in Maxx trucks And the ESC that Cyberdog uses can easily run a brushless crawler motor |
01-24-2009, 10:21 PM | #65 |
sry I ment torque
01-25-2009, 05:54 PM | #66 |
| I believe brushless motors have more torque then a brushed motor of the same size |
01-26-2009, 01:52 PM | #67 |
Quarry Creeper Join Date: Jul 2008 Location: SWEDEN
Got my Pede transmission and Diff Locker today. Stampede transmission Difflock Inside transmission Diff Gears gone Difflock Things not needed anymore Now i will meassure the transmission and then cut it down in size so it fits in my Foff. Also making a small alu plate to strengthen it. Also have to make a new plate for the electronics since this transmission is much higher than the rshd |
01-29-2009, 01:35 PM | #68 |
Started putting the FOFF back together again. Soem small work still remaining on the aluminium. Also going to waterproff it before i am done. Some Pictures Comparison between R2HD transmission and Stampede From the side. Starting to look like it did before. Above. Cables will be secured to be safe from shorting out. Lengtened shaft Underside. Have some work there todo aswell From the front. There u see how much the Stampede transmission sticks up. R2HD transmission was below the electronics plate. So thats why i had to make a hole. More updates to come shortly.... |
01-29-2009, 02:00 PM | #69 |
| Looks great |
01-30-2009, 02:00 PM | #70 |
Now its put together and this is how it looks atm. Been driving 30 mins with the new transmission and it works great. After 30 mins the fun ended because i broke a piece of plastic ( Plastic gets brittle in minus C degrees ) in the rear so i ordered some aluminium replacements And HERE is a vid with the Pede transmission. In the end the cars dowsnt wanna function properly and thats where i saw the broken parts |
01-30-2009, 03:02 PM | #71 |
Newbie Join Date: Sep 2008 Location: Independence, KY
That truck is cool! I was thinking about doing something like that to my ax-10, but not that much power.
01-31-2009, 08:49 AM | #72 |
Cant stand not driving with this till the new alu parts arrive so i deicided to do a quick fix. Will hold just fine untill i get the parts. Parts for repair Mounted in place A perfect fit |
01-31-2009, 11:44 AM | #73 |
Wanted to see how it would look with a body on it. Both look kinda cool but i like the beetle the best. Would need some trimming on the bodies to work |
01-31-2009, 01:36 PM | #74 |
Was out driving with the MGT 6x6 and the FoFF and was great fun until a "small" jump ended the fun... Was at full throttle going for a small jump and that was fine. it jumped maybe 15-20 feet and landed on the front axle so i broke the same things i had broken before in the rear Going to make same custom alu pieces for all axles so its bulletproof... Carnage FoFF and MGT 6x6 |
02-01-2009, 02:06 PM | #75 |
Quarry Creeper Join Date: Feb 2008 Location: New Rochelle
lets get a video!
02-13-2009, 07:56 AM | #76 |
Alu parts mounted. Rear Front Just a flex shot. Dont have that much flex with the shocks i have atm since i dont want to much flex when its a FoFF. But good to know it can fles much if i wanna crawl with it this summer. |
02-13-2009, 09:21 AM | #77 |
Rock Crawler Join Date: Nov 2008 Location: CO
do the beetle body! cut off the fenders and make it like a baja bug. this is a sweet build! can't believe i never saw this awesomeness sooner! this is awesome, now i want one!
02-13-2009, 02:15 PM | #78 |
Put together both of my 1/10 now since i bought an extra pait of cr-01 axles. Comparison pics |
02-13-2009, 02:18 PM | #79 | |
There are no fenders on that chassis Here are my drawing that cyberdog used for the chassis | |
02-13-2009, 02:26 PM | #80 |
| They look Awesome together |
