Go Back   RCCrawler Forums > Miscellaneous > Formula Offroad
Thread: Formula Offroad Picture Archive
Old 02-18-2015, 07:19 PM   #101
Default Re: Formula Offroad Picture Archive
Here's alittle something for a go at f-off.
bbolden516 is offline   Reply With Quote
Old 02-19-2015, 08:48 PM   #102
I joined the Band!
My next project!
That is a Yeti XL cage and those are 1/5 Trenchers. I will be buying 2 sets of RC4WD 1/5 paddle tires soon after the buggy is complete.
Specifications:
Outer Diameter: 193mm/7.59inch
Width: 3.04" (77.3mm)
Each tire weight: 13.1 oz / 371
Width: 76mm/2.99inch
Advanced X4 Medium Compound
twissted is offline   Reply With Quote
Old 03-29-2015, 03:28 PM   #103
Made a Foff of a Wrecker
AngelowDoom is offline   Reply With Quote
Old 05-24-2015, 01:20 AM   #104
Well it's been a while since some body posted "almost 2 month"so a guess it time for a new blood this is a start of something possibility #1....
Possibility #2
#3 is coming.....
rustneversleeps is offline   Reply With Quote
Old 06-25-2015, 11:35 PM   #105
GVJCT 4WD Nitro Truggy-converted to brushless
Castle Creations Mamba Monster 2
NeuCastle 1515 2200kv
2x Turnigy Bolt HV 4S 65-130C 2400mah(parallel)
3.2 Panther Paddle Tyres
3.2 Maximizer bead lock wheels
Alloy roll cage/carbon fibre body
Salita illimitato-Starting my first Unlimited FOFF.
Bully2RockRomper is offline   Reply With Quote
Old 06-30-2015, 11:18 PM   #106
Old 07-02-2015, 12:11 AM   #107
Well it's been a while since some body posted "almost 2 month"so a guess it time for a new blood this is a start of something possibility #1....Possibility #2
#3 is coming.....Hell this is number #3 [/QUOTE]
SCX10 chassis rails
SCX10 skid plate
Wraith skid plate
AR60 front end "Diff Reversed"
SCX10 rear end 25mm "Wider"
Yeti rear shock tower
Yeti rear shock tower "In Front"
Yeti gas tank "Modified"
Internal Springs shocks "Traxxas"
Integy all metal gears trans
Proline Sand paws 2.70 x 5.22
AX3 ESC TX 3150 Kv Vanguard
Turnigy 2X 2200 Mah 3S 40C
Custom cage
Custom links
Custom battery tray
2X Fans
Towardpro MG996R Servo
Old 07-11-2015, 08:57 PM   #108
Finito
Old 07-12-2015, 12:39 AM   #109
I joined the Band!
Wait till you see this Beast with some 1/5 RC4WD SandStorm Paddles!
Here is a set of Full Race Sand Paddle tires mounted.
Old 07-18-2015, 08:12 AM   #110
EDIT:Post 107 gives details of this build
Old 08-02-2015, 03:45 AM   #111
My wraith FOFF , Novak Crusher/ballistic 550
Castor-Troy is offline   Reply With Quote
Old 09-04-2015, 10:01 AM   #112
I joined the Band!
Old 09-04-2015, 09:30 PM   #113
ItsDaKine is offline   Reply With Quote
Old 09-04-2015, 09:33 PM   #114
Damn Al.....it looks killer scale.
How's it run?
JeepinDoug is offline   Reply With Quote
Old 09-04-2015, 09:45 PM   #115
How's it run?
Thanks! runs freakin awesome I'll get a vid up soon
Old 09-04-2015, 10:08 PM   #116
I joined the Band!
I like it! Tires are a little small for my taste, but it is very nice work!
Old 09-17-2015, 10:16 AM   #117
Thanks bro
Old 01-02-2016, 07:59 PM   #118
robn69 is offline   Reply With Quote
Old 01-18-2016, 05:51 PM   #119
The Wraith going airborne hours after a rocket launch from Vandenberg a couple miles to the north...
GrimJeeper91 is offline   Reply With Quote
Old 05-04-2016, 09:14 AM   #120
I joined the Band!
It's got the 40 series tires mounted on 1/5 beadlock rims and brushless power. wheelbase is 17.75'' 1/6 jeep next to it for a size comparison.
