06-04-2011, 08:49 PM | #1 |
Rock Crawler Join Date: Feb 2006 Location: sunny acres
| FOFF A-Ma-Jiggly Last edited by redrustbucket; 06-04-2011 at 11:39 PM. |
06-05-2011, 01:35 PM | #2 |
Rock Crawler Join Date: Aug 2009 Location: milton,wv
awesome rig and a great video
06-05-2011, 01:58 PM | #3 |
RCC Addict Join Date: May 2009 Location: In the warmth!
Yo that rig is doin' work man Nice vids as well! So what electrics did ya settle on? Motor, batts and gearing? |
06-05-2011, 02:48 PM | #4 | |
| Thanks. Quote:
Motor's a 3300kv Reedy, battery is 3s 65c 2250(?) mah Thunder Power or 3s 25c 1300mah Turnigy, gearing is 14/56 32p. Has more punch w/ the Thunder Power but the Turnigy's lighter so they come out fairly close performance wise. | |
06-05-2011, 07:15 PM | #5 |
Newbie Join Date: Mar 2011 Location: hixton
those videos are awsome
06-05-2011, 07:33 PM | #6 |
Thanks! |
06-06-2011, 10:55 AM | #7 | |
Rock Crawler Join Date: Apr 2008 Location: Albany
Evan | |
06-06-2011, 06:03 PM | #8 | |||
I pulled this from another thread: Quote:
I'd like to get a better understanding of this. I've searched till my brain hurts. I bought this battery and motor for my next build but I still don't know how to even guesstimate the probable amp draw of the motor. Any help would be appreciated. | |||
06-08-2011, 10:42 AM | #9 |
I looked and looked. CC pisses me off because they don't list the performance (max amps) of there motors. I would call CC and ask. I have done this for other CC motors. There web site was made for kids ??? They never tell you the info that you need. Example: They at one time listed there mamba max as being able to deal with 210 amps. I called them and asked. 10 secs @ 140 amps Call CC and get max amps@ ??? volts for that motor. I can help you from there. Evan |
06-08-2011, 12:49 PM | #10 |
Couldn't get through so I sent them an e-mail. In the meantime I found some info over on Rcshortcourse : Car Setup Info Slash 4x4 SCT MMP 2400kv Combo Geared 21/52 (22/54 or 20/50), Slipper Proline Streetfighter Tires No body shell on car Gradual rolling start to full throttle high speed tarmac passes Theoretical speeds listed from scriptasylum calculator Batteries were fully charged Ambient Temp was 72f 20 minute cooldown between tests 2s 5000mah 40c Turnigy Max Amps - 165a Min Voltage - 6.99v Max Power - 1167w Theoretical Speed - 32 mph / 51 kmh GPS Measured Speed - 37 mph / 59 kmh Motor Temp - 110f 3s 5000mah 40c Turnigy Max Amps - 157a Min Voltage - 10.5v Max Power - 1670w Theoretical Speed - 48 mph / 77 kmh GPS Measured Speed - 53 mph / 85 kmh Motor Temp - 135f 4s 5000mah 40c Turnigy Max Amps - 159a Min Voltage - 14.7v Max Power - 2360w Theoretical Speed - 64 mph / 103 kmh GPS Measured Speed - 67 mph / 108 kmh Motor Temp - 145f The Thunder Power is rated for 146A cont. and 292A bursts but I may need more? Thanks, Jeremy. |
06-09-2011, 12:18 PM | #11 | |
Evan | |
06-09-2011, 12:37 PM | #12 |
Thanks very much for your input Evan. Good to know the batt. will work, I'll probably grab another one. Dyno sounds awesome. You have a thread going on it at all? Best of luck with your health.
